Results 1 to 11 of 11
heat sinks for passive solar
| Off Topic Discussions
    beardo is offline Metal Recycling Entrepreneur
    beardo started this thread.
    beardo's Avatar
    Mar 2013
    NE South Dakota
    220
    56
    I am planning on building a passive solar heater for my garage. I was thinking about using aluminum heatsinks instead of pipe or cans, due to the surface area the fins would provide. Any advice, it seems like a good idea in my head.
    "And if your train's on time, You can get to work by nine, and start your slaving job to get your pay. If you ever get annoyed, Look at me I'm self-employed
    I love to work at nothing all day" -BTO
    3,419
    If I remember right the cans allow for hot air to move through the sytem. Heat sinks would get hot but would absorb the heat, how would it generate the hot air to move into the space you want to heat?
    beardo's Avatar
    Mar 2013
    NE South Dakota
    220
    56
    I would use a fan to bring air in and then over the heat heat sinks. I'm thinking of basically a backwards air conditioner the air would heat as it channelled over the warm heat sinks and back into the room. I believe the term to describe what I am thinking is an air to air heat exchanger.
    How about something like this?? There's tons of info available.
    Types of DIY/homemade solar air heater
    Here's a bunch of links,
    home made window solar heater - AVG Yahoo Search Results
  5. The Following User Says Thank You to Mechanic688 for This Post:
    beardo's Avatar
    Mar 2013
    NE South Dakota
    220
    56
    thank you for the links, I haven't seen the first one before. I'm just trying to build the smallest most efficient system I can. I'm just going to have have to build it and see if it is any better than the traditional models.
    This may be a case of me trying to find a use for my favorite scrap. I don't even like selling them
    travistemple202020's Avatar
    ames iowa
    1,326
    266
    I do mine a weird way that's not as good but cheap and effective at raising room temp about 15deg but I use black 2mil plastic its cheap and cover my window at the outer edge so its like a box not taped to the window glass itself. then I use 2 solar fans that are 2in small ones holes cut and taped off fans to the plastic drawing room air cold from the bottom and out through the top this way I still am not paying for electricity lol
  8. The Following 2 Users say Thank You for This Post by travistemple202020:
    Insanity is offline Metal Recycling Entrepreneur
    Insanity's Avatar
    97
    An idea here...
    If you were to build a box, and put the fins into the air flow, with the bottom, that would normally attach to the CPU chip, facing the sun. That might work, you'd basically be using it in the same manner as a computer.
  10. The Following User Says Thank You to Insanity for This Post:
    beardo's Avatar
    Mar 2013
    NE South Dakota
    220
    56
    thank you guys for the respinses.I just need to find some time to build some and see how it works.
    Scrappah's Avatar
    1,056
    318
    Okay ... it sounds like you're going for convective heat ? You probably wouldn't need fans because hot air naturally rises and draws cold air in from the bottom of the collector to make up for it. It's a convective air current ?
    Ever thought about using thermal mass instead ? Radiant heat is a lot more comfortable.
    Why, they can usually bring around .60 a lb.
    matador's Avatar
    Nov 2013
    Big Wonderful Wyoming
    2,309
    1,782
    Out here, it's way less than .60 per pound.
    I'll have to try a little heater setup. It sounds like a cool project.
    By the way, heatsinks can make great business card holders!
    1. cpu with out/with heat sinks ?
      By EcoSafe in forum Computer Recycling
      Last Post: 08-12-2013, 12:12 PM
    2. Ceramic Heat Sinks
      By Ecycle Atlanta in forum Scrap Metal Questions and Answers
      Last Post: 07-04-2013, 10:13 AM
    3. Copper heat sinks?
      By ilyaz in forum Batteries, Capacitors, Heat Sinks
      Last Post: 05-19-2013, 09:05 PM
    4. alu looking copper heat sinks
      By EcoSafe in forum Scrap Metal Tips and Advice
      Last Post: 12-22-2012, 05:32 PM
    5. 320 pounds of heat sinks....
      By Scrapcrazy in forum Batteries, Capacitors, Heat Sinks
      Last Post: 07-28-2012, 06:25 PM
