Page 1 of 25 12311 ... LastLast
Results 1 to 20 of 500
The Gustavus Thread
| Vehicle & Auto Recycling: Cores, Converters & Dismantling
    gustavus started this thread.
    1,213
    The Gustavus Thread
    Both cars stiffed to the nines, bottom car was so heavy I had to jack the RPM's up to 1500 then crowed the jib in to get her loaded, 2nd car almost lost the roof.
    But still not as heavy as the bottom car.
    Bonus having air on the truck, easy removal of aluminum rims using the impact.
  2. The Following 8 Users say Thank You for This Post by gustavus:
    boise, ID
    1,603
    464
    How much weight total did you end up with? If I remember right, Gus had a set-up like that.
  4. The Following User Says Thank You to freonjoe for This Post:
    1,213
    One and the same, came back with better manners, and fewer stories.
    It's been a rough winter buying that truck tapped me out, right now I'm down to my last $7.00 in my bank account. Had to do a bunch of small repairs to get the truck passed on this recent safety inspection and just finnished up this morning and plated the truck this afternoon had to remove the insureance from my pick up to swing it.
    I now have some competition, the guy has a trailer and does not take cars without wheels, which is almost everything on the reserve - aluminum rims are an easy case of beer.
    Wont know what the weight is until I hit the yard with that load, for the curious the truck empty weighs 8780 kg currently has 1/4 tank of fuel.x 2
  6. The Following 2 Users say Thank You for This Post by gustavus:
    corycouch's Avatar
    jonesboro ar
    1,405
    3,755
    i like your setup, ive been thinking about a lumber truck with a piggyback forklift, have any of you ever seen anyone try this scrapping cars? the forklift would be great moving cars around the yard and a snap to take off the aluminum wheels, take off all four and set it down on the truck? before anyone asks most of them have a 5000lb capacity
    1,213
    Quote Originally Posted by corycouch View Post
    Your going to have problems loading from the side of the truck if your going to stack em, to load that top car. Forklifts do not have very good reach before the mast runs up against the deck.
    To load that top car, I attach a tag line so that I'm able to steer the load where I want it from a safe distance. Removing rims, just take the lug nuts off while the car is still on the ground when you lift they stay behind.
    When I'm cutting the catylitic off, I rest the rear bumper onto the side of the deck making it secure to go under. Most cranes come with a safety feature if a hydraulic hose burts the sudden loss of fluids shuts off a valve located at the cylinder. The load will remain put until repairs have been made.But why put yourself at unessesary risk.
  9. The Following 2 Users say Thank You for This Post by gustavus:
    Dunemaul's Avatar
    East Orlando FL
    1,062
    154
    Quote Originally Posted by biscuit View Post
    Am i reading this right Gus has been lurking here this long and no one else said anything Smh. Biscuit did i get that right? And if so my hats off to you.
    Born to think, destine to succeed.
    3,392
    993
    welcome back GUS
    Dunemaul's Avatar
    East Orlando FL
    1,062
    154
    Ok glad im not the only one
    corycouch's Avatar
    jonesboro ar
    1,405
    3,755
    i hadnt even thought about double stacking until your pic, just ideas running thru my head, ive got a wild kinda mind always trying to find a better way the good thing about me is im not afraid to fail finding out. ive also looked at blue ox knuckleboom trailers, ive not got the money for either one right now but ill get lucky someday
    corycouch's Avatar
    jonesboro ar
    1,405
    3,755
    boy alot happened while i was typing that, ive heard of gus, nice to meet you and i see why the posts ive read about you why you are so liked
    1,213
    Blush, well you guys are the brother I never had and leaving you all was kinda hard. Its time to make ammends with the admin I applogize for my harsh words which got me banned. Hopefully we can all let by gones be just that and get on with the business of scrapping.
    Its off to bed, road bans are still in effect so its an early start for me to beat the D.O.T. out of the coffee shop. I need to familurize myself with the weighs and placement of those weights before I will have enough confidence to make day trips.
    My last truck had a GVW of 19.500 kg and this one is smaller at 14,500 kg so my legal load weight is 5720 kg or 12584 lbs less 15% for the road bans.
  16. The Following User Says Thank You to gustavus for This Post:
    1,213
    Be pesitant Cory it will come to you one way or the other. I started this show with a home built car trailer which was licensed 1rst of Sept I ran it until middle of November then made a useless trip to Ontario to buy a crane truck which would not pass a safety, on the way home found this truck. As for the truck not the best deal I've ever made, but that Palfinger makes up for all the bad points.
    In that 2 1/2 months made a bit over $19,000.00 but I put in some long hours to pull it off.
  18. The Following 5 Users say Thank You for This Post by gustavus:
    boise, ID
    1,603
    464
    Welcome back Gus, you've been missed!
  20. The Following 2 Users say Thank You for This Post by freonjoe:
  21. #14
    4,918
    15,581
    Gus, welcome back you have been missed, Mike.
  22. The Following User Says Thank You to miked for This Post:
  23. #15
    6,996
    Glad to see your back Gus!
  24. The Following User Says Thank You to KzScrapper for This Post:
  25. #16
    admin's Avatar
    678
    336
    Apology accepted.
    PS - Don't think we didn't know you were back
  26. The Following 9 Users say Thank You for This Post by admin:
  27. #17
    2,701
    As soon as I saw that truck I wondered...is that Gus? Glad you're back!
  28. The Following User Says Thank You to IdahoScrapper for This Post:
  29. #18
    Ptscrapper is offline Metal Recycling Entrepreneur
    Henderson nc
    246
    Gus is a real scrapper we are just amateurs
    Abraham Lincoln
  30. The Following User Says Thank You to Ptscrapper for This Post:
  31. #19
    I don't know about you guys but I have kinda missed the detailed stories of some of the different adventures or paths Biscuit/Gus has taken in getting the job done scrapping, the trucks, ball mills, and different ways of breaking stuff down. Thank you sir,,,
  32. The Following 5 Users say Thank You for This Post by Mechanic688:
  33. #20
    boise, ID
    1,603
    464
    Thanks admin for letting him back!
  34. The Following User Says Thank You to freonjoe for This Post:
  35. Similar threads on the Scrap Metal Forum
    1. co op thread ?
      By EcoSafe in forum General - Let's talk business
      Last Post: 02-16-2013, 10:32 AM
