Results 1 to 16 of 16
First Dishwasher - What to Look For
    BigRyan started this thread.
    BigRyan's Avatar
    206
    134
    So I'm picking up my first dishwasher today, and I was curious as to what I should look to remove on it?
    I'm not real familiar with them so any hints/advice would be great.
    Thanks!
    rca987's Avatar
    939
    Motor on bottom- cast aluminum with copper inside
    sometimes there's stainless steel inside the dishwasher
    the spinner might be sheet aluminum
    wire harness
    magnet test everything, do it for everything if unsure.
  3. The Following 2 Users say Thank You for This Post by rca987:
    matt018's Avatar
    Southeast PA
    174
    x2^^^ and i use a sawzall you cut the tub up in 5 pieces and the trash guys take it.
  5. The Following 2 Users say Thank You for This Post by matt018:
    BigRyan's Avatar
    206
    134
    Thanks guys!
    2,701
    My yard takes the plastic tubs. It has a steel frame around it.
    Other tubs have been stainless. Nearly all of them have a brass fitting where the incoming water goes. The bracket holding it might look like brass, but it's not. Test everything with a magnet.
    Spinner thing is usually plastic or stainless. The sheet on the front of the door is sometimes aluminum. Pull all the wires. Pull the motor and cut it apart for the copper. The motor case might be aluminum.
    There's also another piece on there, not sure what it's called but the one's I've done, look like a small black film canister that 35mm comes in. Smash that apart for a small spool of copper.
  8. The Following 2 Users say Thank You for This Post by IdahoScrapper:
    4,756
    6,022
    Yards by me will not take them too much plastic! Check with your yard if you need to break it down or if they will take as is!
    165
    23
    I believe that is an inductor.
    Be careful about the plastic. Too much is never good, so be knowledgable about your yard's policys.
    2,701
    Quote Originally Posted by TheIrrationalist View Post
    Sounds about right. It closes/opens a valve I think.
    Sounds like a solenoid valve to me, that's what those do, open/close back/forth. Mike
  13. The Following 3 Users say Thank You for This Post by Mechanic688:
    165
    23
    Of course, a solenoid makes more sense. Probably regulates the water flow.
    YoungScrapper's Avatar
    Middlesex NC
    30
    Just make sure u yank the wires leading to the controls on the dishwasher. On my first dishwasher i scrapped i didnt do it. I dont know what i was thinkin i lost out on another ft n a half of copper wire. Iv been savin the motors to. I got 12 electric motors 7 from vacuums smaller than motors from appliances but its still got copper in em 5 from appliances(dishwashers dryers n washer) cant wait to scrap a refridgerator or freezer.
    Dallas TX
    1,979
    158
    If you have a good amount of CLEAN plastic your yard may want to buy it. I have a buyer for my plastic at .12 a pound.
    2,701
    Quote Originally Posted by YoungScrapper View Post
    Take a file to the windings. Some are copper clad aluminum.
    kcscrapper is offline Metal Recycling Entrepreneur
    585
    76
    I just got a dishwasher and pulled the tracks
    racks out cleaned them and put them on eBay for $20 a piece the ones that sold on eBay went for $30 to $50
  19. The Following User Says Thank You to kcscrapper for This Post:
  20. #15
    2,529
    2,906
    If the spinner arms are ok, same with the other inner parts, they do sell on ebay etc.
    The wearing part on the spinner arms can wear thru and they drop down and the dishes don't get sprayed properly.
    Just grab the end of it, if its loose & moves up & down too much its probably worn out and thats all thats wrong with the dishwasher.
    The solienoid, use a screwdriver to pop off the bit of steel around its outside, pull it off the spindal.
    Shove a steel rod or screwdriver into each end of it, now bend them so the solienoids in the centre and the plastic housing cracks and it breaks in 1/2 & you can pick he 25gms of copper wire out.
    Be carefull with stainless steel, its edges are really sharp. Dishwashers will slice you more often than anything else you scrap down. Wear wrist protection of some sort and be extra carefull when you Push something to break or move it.
    Stainless is mostly nonmagnetic, if its magnetic its classed as 'steel'.
    If its very slightly magnetic, its actually probably 'High grade stainless'.
  21. The Following 2 Users say Thank You for This Post by eesakiwi:
  22. #16
    NHscrapman's Avatar
    new hampshire
    1,584
    4,066
    I remove the steel the same way but then lay the case on it's side and 2 or 3 good whacks with a 5 lb sledge opens them right up. Just like you said, right in half.
    1. dishwasher motors
      By freonjoe in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 08-23-2012, 06:57 AM
    2. Update on dishwasher motors
      Last Post: 04-19-2012, 07:18 PM
    3. Scrapping a Dishwasher - Video by KennyChumsky
      By BiggerHammer in forum Scrap Metal Videos
      Last Post: 12-17-2011, 09:29 AM
    4. Newbie Question Dishwasher?
      By bailey in forum Scrap Metal Questions and Answers
      Last Post: 10-07-2011, 07:33 AM
    5. Newbie Question Dishwasher?
      By bailey in forum Scrap Metal Tips and Advice
      Last Post: 09-08-2011, 11:42 AM
