Results 1 to 20 of 37
Towing vs Hauling
| Off Topic Discussions
    matador started this thread.
    matador's Avatar
    Nov 2013
    Big Wonderful Wyoming
    2,309
    1,782
    Towing vs Hauling
    I hope I'm in the right forum section.
    Anyways, I have a question. I'm purging a lot of the "worthless" E-Waste that we have to make room for a computer refurbishing center. I'm moving gutted printers, scanners, computer cases, gutted, iMac G3s....
    I get paid $0.05 per pound for this stuff. It'll cost me $50 in fuel to make a trip. I'm using a 1987 Chevrolet 1/2 ton truck, so I can haul about 1200#, for a day's profit of $10.
    Now, I've towed more than 1200# with the truck. For shorter distances. I have 125 miles to go each way. Am I better to keep putting loads in the beds, or would it be best to hitch up the trailer? I don't want to damage the truck, and I cannot afford a larger truck for this project. We have a 3/4 ton being fixed up for us, but it'll be a while before it's ready for us.
    This is the truck and trailer in question:
    The trailer is rated for 5000# gross, and has brakes. The truck has a 305, 700R4, and an unknown rear end (I'm guessing a 3.31). Chevrolet didn't release towing numbers that I'm aware of.
    What would you do?
    Thanks for the help!
  2. The Following 3 Users say Thank You for This Post by matador:
    brandon's Avatar
    North Carolina
    787
    Keep it out of overdrive any time you have a load in the bed or towing to save the torque converter/ trans.
    My fortune cookie said:
  4. The Following 5 Users say Thank You for This Post by brandon:
    matador's Avatar
    Nov 2013
    2,309
    1,782
    Done and done!
    My father burned out a few E4ODs that way. His loads were heavier, but I still keep in in drive to be on the safe side. Plus, I like to go slowly when hauling/towing anyways. It gives me more time if an emergency comes up.
    Of course I'd like to maximize my trips as much as possible. I'm just not sure which way is best. I'd assume that it would be safe to tow over 1200# of stuff on a trailer, but I'll defer to those who know more than I do (Almost anyone!)
  6. The Following User Says Thank You to matador for This Post:
    Metalbestos's Avatar
    Mar 2014
    Baltimore md.
    985
    3,094
    I'm not over experienced with trailers and not knowing your rear end , I would put as much as possible in the truck bed and try to do without the trailer for safety sake .the only advice I found online was this ....
    Edit: Look inside of the glove box... it should give the actual towing capacities.
    Keep in mind:
    GCVWR - Gross Combined Vehicle Weight Rating, the max weight of the truck and trailer, everything loaded up, on the road
    GVWR - Gross Vehicle Weight Rating, the max weight of the truck loaded and on the road
    Curb Weight - Empty truck (I think they assume a half tank of fuel, no passengers)
    Trailer Dry Weight - worse than curb weight... stripped, empty trailer, no options installed, no LP, no batteries.
    Tongue Weight - This one can sneak up on your with toy haulers. They tend to be very nose-heavy since they were designed to carry heavy cargo behind the axle. A WD Class-IV hitch is a must, as tongue weights can easily exceed 1,000.
  8. The Following User Says Thank You to Metalbestos for This Post:
    matador's Avatar
    Nov 2013
    2,309
    1,782
    What Chevrolet used were called RPO codes (Regular Porduction Options?). They put all of these on a label in the glovebox. It looks like this (Not my truck, though):
    All of the codes mean something. It could be an engine size, suspension package, or just color-coded seatbelts. There isn't one for towing. The truck originally was rated for 5200# GVW (Truck + Payload). Being a 2x4 model with no options, 1300# puts me right around 5200# with me in it.
    The bumper hitch is rated for 7500#, and looks factory to me. The RPO code for the axle says that I have a 2.76 rear end, but I'm not buying it. According to a table of options, that axle was only offered with a 350. I have either a 3.08 or a 3.73 from the factory. What's there now is anyone's guess.
    My 1995 F150 could barely move a 5000# load down the road with the 3.31 axle. This truck pulled a similar trailer at 60 MPH without breaking a sweat. A manual in the Ford can't make it that bad, can it?
    Being a 30 year old truck, I don't know it's history. We bought it in 1996, but as for what the last owner did- all bets are off.
    I can't find any towing numbers from Chevrolet on these old beasts.
    If my understanding is correct, pulling a load is easier than carrying it, correct? Would you be better off with that load on a trailer, opposed to on the truck bed? 1300# fills the truck up. If I were to dump that load on a trailer, would the truck do better? Would it do worse? Would it matter that much?
  10. The Following User Says Thank You to matador for This Post:
  11. #6
    Mar 2014
    Baltimore md.
    985
    3,094
    Depends on your clutch fly wheel condition . If they were up to par on would imagine it would tow fine . But with the larger motor in the chevy I can see why it seems like it takes less effort .
    I think it would be less stressful on the truck but it would be a push when you factor in trailer weight . Shame the yard is such a distance from you . Hope you get the 3/4 ton back before expected . Just. To take some confusion off your hands . That chevy spec sheet is unreal it's more confusing than blindfolded underwater trigonometry .
  12. The Following User Says Thank You to Metalbestos for This Post:
  13. #7
    Mar 2014
    Baltimore md.
    985
    3,094
    U177b is your paint code
  14. The Following User Says Thank You to Metalbestos for This Post:
  15. #8
    Mar 2014
    Baltimore md.
    985
    3,094
    Here this might help .
    GM RPO Codes
  16. The Following User Says Thank You to Metalbestos for This Post:
  17. #9
    If it were me I'd put the load in the truck cause you have more chance of something happening with a trailer on. Plus the fuel mileage should be worse dragging a trailer. Better able to control your load with it on the truck. Course if the load is big enough for the truck and trailer then my advise is to take it easy on the speed and don't rely on a bumper hitch but a class 4 or 6 instead. Should have trailer brakes on that size of trailer also.
  18. The Following 3 Users say Thank You for This Post by Mechanic688:
  19. #10
    pjost's Avatar
    Apr 2014
    N & South Dakota
    995
    5,132
    Yes, you can tow much more than you can haul. For instance, a typical 1/2 ton pickup can legally haul about 1700 lbs. That same pickup can tow 10,500 lbs.
    And like Mech said, I wouldn't take this 100 mile trip with a bumper hitch. Maybe if the yard was just around the corner, but not on the Hiway.
    Edit: I'd wait for your 3/4 ton to get fixed.
    Money is not the root of all evil, the love of money is.
  20. The Following 2 Users say Thank You for This Post by pjost:
  21. #11
    matador's Avatar
    Nov 2013
    2,309
    1,782
    It would be nice. Sadly, our guy works on his own schedule. It may be ready next week, or it may not be ready until July. He still has projects from when I bought my Buick over two years ago. He's good, but not quick!
    The trailer does have brakes. We do have a receiver hitch on there now (Didn't in the picture).
    Thanks Metalbestos for the RPO code list. I saw a shorter list before, but apparently there are trailer towing codes. It's probably the closest we'll get to actual numbers from GM.
    The closest comparison numbers I could find were from Ford. This is for the 1993 F150s:
    For the 5.0L V8, Auto transmission, and the 3.08 ratio, I'd be able to tow a 5000# trailer. We'll call the Chevrolet rating 4000# until I can check the numbers. Now, for the Ford, the 3.55 ratio actually lowers the tow rating????
    I thought I had a graasp on the concept. This is really starting to get confusing!
  22. The Following User Says Thank You to matador for This Post:
  23. #12
    armygreywolf's Avatar
    Germantown, WI
    1,085
    193
    Can I ask why your not charging for removal? You realize every time you haul with a trailer, every single time you put the hitch on the ball you should stuff 20 bucks somewhere for a transmission overhaul. We (me too) drive and use half ton trucks for 3/4 ton purposes. Knowing all this, and knowing a beefier truck is not an option, sock away twenty bucks every time you tow or haul something truly heavy for that inevitable moment your transmission fails. Likewise the 305 doesn't last forever either working hard down low. I charge to take carcasses UNLESS I am getting significant e waste to go with the lot. a fist full of memory does not quantify the wear and tear on my truck for hundred dollar on the ton sheet iron.
    I guess if it's for a long standing client that's different, or if your trying to get your foot in the door...exceptions to be made and all that.
  24. The Following User Says Thank You to armygreywolf for This Post:
  25. #13
    bcrepurposing's Avatar
    Northern Central MN
    152
    Towing vs Hauling
    i can speak to Chevy but i can for ford (4 owned - 300 i6, 4/5 speed) and dodge (1 owned 318 / auto). all my trucks have had tranny coolers which makes a HUGE difference for towing by taking some heat off from added strain.
    the fords i have run 1000-2200 in bed with a 4500 pound tandem trailer with between 1000-7500 pounds in load.
    the dodge has regularly seen 800-1600 in the bed with a tandem trailer about 2000-4500 lbs and loads between 1500-8000.
    load your bed first after hooking up trailer. load the trailer next and shift weight to keep it over trailer wheels and towards the back more off the tongue and rear axle. with practice you can really pack in weight and not worry about damage.
    having a well designed trailer helps immensely to distribute weight and increase load.
    as for what it can pull every one is different. i pulled 3500 pounds regularly with a 305 th200 auto tranny on my 84 Pontiac Parisian ( Chevy caprice ) in the form of a trailer and toys or a boat. just used truck tires on the car to get more bite and weight capacity. so you should be fine at the very least with 1500-2000 pounds on trailer.
    "Reuse, Repurpose, Recycle..." - BC Repurposing Motto
    www.bcrepurposing.weebly.com
    https://www.facebook.com/bc.repurposing
  26. The Following User Says Thank You to bcrepurposing for This Post:
  27. #14
    matador's Avatar
    Nov 2013
    2,309
    1,782
    Quote Originally Posted by armygreywolf View Post
    Can I ask why your not charging for removal?...I guess if it's for a long standing client that's different, or if your trying to get your foot in the door...exceptions to be made and all that.
    I got a lot of usable stuff. I have about 10 pickup truck loads (No trailer) of junk to haul out, but I took in over 30 Intel iMacs that I sold, over 10 iBook G4s that I sold, and about 10 Quad core Mac Pros that I sold. My computer store has been well-packed with their stuff for the last three years. I have over 75 Core 2 Duo Dell desktops that are ready for refurbishing.
    And, I didn't get the gutted cases. I gutted them, and sold the RAM/Motherboard/.... This is just what I have left from the process- things like iMac G4s that are essentially an LCD screen attached to an empty base.
    I shouldn't complain- I've made over $10k from these two clients, and that money has helped to pay off the building that is now my office. I just have a ton of junk to remove before I can really get going on the refurbishing.
    If I had the money, I'd go and find a cheap Chevy 2500. I don't have $1500 to spend for 10 trips, though.
    @BCrepurposing Can you explain how you load? How much weight do you put on the bed, and how does that correspond against tongue weight? Are you better to put 500# or so in the bed, or are you best to put it in the front of the trailer, and leave the truck bed itself empty (Or close to)???
    The last load that was a combination tow/haul I did was in the picture. I drove it about 75 miles in Drive. There was about 900# in the bed, and another 2000# on the trailer (Not counting the weight of the trailer itself). The trans temperature (Have a gauge in there) stayed about right- maybe 10-20 degrees warmer. I'm just a little shy on the whole idea- this is a longer trip.
    Keep the thoughts coming! I've already learned a lot here!
  28. #15
    Focker is offline Metal Recycling Entrepreneur
    1,158
    I dont even know where to start.But the first thing is why are you driving 250 miles to make $10 or better yet at all for that matter.
    I would load the truck and trailer and roll with it.Or you could just load it all on the trailer
  29. The Following User Says Thank You to Focker for This Post:
  30. #16
    matador's Avatar
    Nov 2013
    2,309
    1,782
    We don't have any yard closer to us. We're in Wyoming, where there is nothing but miles and miles of miles and miles. It's either this or the landfill. I won't send stuff to the landfill for moral reasons, and it would cost more. I'm one of the only E-Waste processors in the entire state.
    If my truck can handle a load on the trailer, I'd be for it. I'm trying to get some numbers for what I can expect to do. I'd rather break even on loads than kill the truck. I'm interested in hearing some scrap loading tips, and other things. For example BC mentioned splitting the load- some on the trailer and some on the truck. Does anybody have any recommendations on how to split the load?
    If I can haul 2500# on the trailer with nothing on the bed, instead of breaking even, I'd be making $75 per trip instead of breaking even. That's a lot better! Now, how much weight is a resonable number???
  31. The Following User Says Thank You to matador for This Post:
  32. #17
    4,980
    1,244
    Can you not break the material down to increase the value (THE EMACS?)
  33. The Following User Says Thank You to mikeinreco for This Post:
  34. #18
    pjost's Avatar
    Apr 2014
    N & South Dakota
    995
    5,132
    Not trying to be a smart a$$ Matador, but nobody here knows your truck or your trailer. You Know your truck and trailer.
    Myself, I would not load the truck bed with anything and load the trailer up to 5000lbs. Gross. You load the bed up + the tounge weight and your suspension may not like it. Looks like your saggin pretty good on the pic. Rear pu tires are squatting some too. How are the brakes on your truck and trailer?
    The one thing you don't want is to be over 5000 on that trailer, get pulled over by the WY HP, and have them crawling all up inside your colon.
  35. The Following 3 Users say Thank You for This Post by pjost:
  36. #19
    matador's Avatar
    Nov 2013
    2,309
    1,782
    The iMac G3s are essentially a CRT with nothing of value now. I've pulled the logic board, hdd, ram, and the degausser cable. This is just the sludge from the process if you will. (Except the scanners- they just go straight to shred).
    The brakes are in good shape. The trailer ones were checked this spring, and the truck has new rear shoes and drums.
    No problem with the smart-a$$ stuff. It's understandable. I was hoping someone used a similar truck and would have some insight there.
    So, just load the trailer and leave the truck bare? Seems simple enough to me!
    Trust me, I'm not going over 5000# on the trailer. The flooring is a little sketchy in spots, and that would concern me with being too much weight.
    I was figuring on about 2500# load, plus 1500# for the trailer, for 4000# total. Does this seem reasonable?
  37. The Following User Says Thank You to matador for This Post:
  38. #20
    Northern Central MN
    152
    Towing vs Hauling
    a general ratio is 55% over wheels 15-20 % tounge and 25-30% on rear.
    keep heaviest stuff on axels. the reason for less on tougne is it keeps less weight on bumper. meaning less on shocks and springs. meaning bigger load.
    i load bed before trailer because it gives counter weight to rear of trailer and helps with traction and helps you plan the majority of the load on the trailer.
    next is over axels then i split between front and back as required to level the bumper.
    to much weight forward and you ruin suspension and risk breaking an axel. to much back and you you have no traction as it lifts the rear end of the truck and strains the reciever or bumper or in severe cases with a old rusty truck the frame between bed and cab.
    you need proper tires to do the job too. trailer tires have a stronger sidewall enabling a bigger load then car and truck tires and can skid or turn better without damage. also check pressures and keep them at max pressure or a little over on heavy loads.
    i usually run regular lt truck tires on my truck but when i find them cheap and with good tread i preffer load range E tires or 10 plies. i have required a more agressive tire that cleans better for my last few jobs so have been using all terain tires which can be difficult to get in higher load range. i suggest firestone transforce E range if you want good ballance between them. good snow ice and mud traction and heavy sidewalls for loads.
    also look at getting load helpers or if you got a solid frame and can handle the rougher ride add coil springs / coil overs or swap to a set of 3/4 springs. the shocks are essentially the same.
    brakes ( bigger, heavier duty ), springs ( 2-4 more leafs) and heavier frame (thicker by about 1/8") is the big difference between 1/2 & 3/4 tons. halfs get alot better milage normally due to exta weight on same drive train.
    motor wise 400, 350, 327, 305, and 283 are essintially same motor block. 283 parts makes a 307. use 327 parts and make a 317. 400 and make a poor mans 383. just because your 305 is smaller and doesnt eat the gas the bigger v8s do dont let them fool you into thinking it cant work for its fuel. a little work and it can melt the tires off with thier over expensive gas guzzling crate motors. only difference is you have cheaper parts because you didnt build as commonly used of a motor and wont have the mainence bills that comes with it.
    above it was suggested to squirrel for damage and i do agree. brakes get hit harder, it is extra strain on tranny and motor as well as steering / suspention parts get hit hard by towing. a fact of towing.
    You figure mainance costs for your truck right? you will hear various numbers and amounts you should save. I save a % of each load for mainence and upgrades. This will also potentially allow you to save for another truck & trailer too.
    mine is 10% i squirrel away for truck or car use and 15-20% for truck / trailer.
    you haul more with a trailer and make more money. i average about $150-300 per load of white goods (appliances) and would be at $30-60 with a just truck. by the time i figure gas costs i can make 1 trip for 2 mpg less with a trailer than the 4-5 required for same space.
  39. The Following 4 Users say Thank You for This Post by bcrepurposing:
  40. Similar threads on the Scrap Metal Forum
    1. Towing Out Shopping Cart From The Creek!
      By PickerBenny in forum Scrap Metal Videos
      Last Post: 09-19-2014, 02:00 PM
    2. Ventura County Towing in Oxnard, Ca
      By VenturaCountyTowing in forum Introduce yourself
      Last Post: 01-21-2014, 12:43 PM
    3. Ever see anyone hauling scrap in one of these?
      By MetalEarthRecycling in forum Scrap Metal Recycling Tools & Equipment
      Last Post: 09-27-2013, 05:27 PM
    4. Motorcycle Towing ???
      By DumbD in forum Scrap Metal Questions and Answers
      Last Post: 10-07-2012, 11:32 PM
    5. Towing AWD Subaru
      By RichardCourtney in forum Vehicle & Auto Recycling: Cores, Converters & Dismantling
      Last Post: 01-24-2012, 08:37 PM
