Results 1 to 20 of 20
Stainless Steel what to do
    skipster316 is offline Metal Recycling Entrepreneur
    skipster316 started this thread.
    Mar 2013
    Greenwich Ct
    Question Stainless Steel what to do
    I just got 4 sheets of high end stainless steel. It appears to be 16 gauge (1.5 mm thick) 78" long X 48" wide folded along its length into a right angle 24" X 24". This stuff is "non magnetic" shiny brushed finish and its heavy weighing 61lbs a sheet (X4) The guy said he used it for a trade show display.
    so the question is do I scrap it? and how do I know the grade? or should I sell it? and where would I do that.
    I live in Greenwich CT
    I'm new to the forum so I don't know how to attach photos or where to see replies ... But I'm learning... Thanks
    Mar 2013
    Greenwich Ct
    Also, when I checked it said not allowed to use attachment. How can I change that? Thanks
    MattInTheHat's Avatar
    rock hill, sc
    1,464
    1,140
    talk to some fabrication shops. that should be worth more than scrap
  4. The Following User Says Thank You to MattInTheHat for This Post:
    webuyselltradestuff's Avatar
    May 2013
    Watkinsville, GA
    948
    131
    Craigslist...check what an average sheet runs at lowes and sell a little under. Trust me someone will want it for sone project or for their shop.
    Russell's Avatar
    Chicago,Il
    815
    495
    Check if its magnetic. If it is most yards only by as reg steel. In your case its only going to be worth $20-25 depending on your yards price. If its non magnetic its scrap value is $100-$140 depending on your yards price. In either case try to sell 1st (which is easier said than done)... good luck to you.
    I know Ive made large bundles on old stainless steel gas grills some run over 300 pounds. I had one about 7 or 8 ft wide that netted nearly $300.
    [IMG][/IMG]
    sawmilleng's Avatar
    Central Kootenays, BC, Canada
    859
    712
    Russell, Wow!
    You are scrapping a grill that my wife and I would kill to have in our backyard!!
    Jon.
    Perrysplace is offline Metal Recycling Entrepreneur
    14
    At my yard that grill would have to be completely stripped down. Stainless is at .36# here.
    Russell's Avatar
    Chicago,Il
    815
    495
    I looked into fixing it up. The replacement parts would not have been worth it. New this is an $1,000 grill, I believe it had 6 burners. I don't remember exactly, but parts plus cleaning time wouldn't have netted me more than just zipping it apart and scrapping it.
    6,810
    Quote Originally Posted by skipster316 View Post
    upload your pics to photobucket or imgbox etc, save the link to the photo from there, and insert it into the "insert image" box in your posts
    Depending on your area and how populated it is, you should find those sell easily on craigslist. Having been used in a display I'd guess they're in good condition, and could be used in a lot of places. Be sure to include keywords in your ad such as "restaurant", "builders", or "builder supply" etc
    Nov 2013
    new york
    Stainless steel can be magnetic. 316 has a slight magnetic pull to ans 316L will have even less as you move up on the ladder to the high end of the type of stainless material the lower the carbon will be found in the material. if this was used for display it most likely a 316 or 316L stainless, it could have been made out of 304 stainless if it was a higher end display. if the sheets are in production condition you might want to find a fab shop in your area they may offer allot more for them then the scrap yard. The only way to find out the grade for sure is to have it tested with a PMI gun or chemical analysis. I hope this helps out )
  12. The Following User Says Thank You to Macdemore377 for This Post:
    sledge's Avatar
    Central Indiana
    2,716
    4,531
    Wish I lived closer to CT, I'd buy them off you and see if someone could "press" those sheets for me to make new fenders for my trailer. 16 gauge is what trailer fenders generally max out in thickness. Dang!
    6,810
    Quote Originally Posted by sledge42 View Post
    I made my own fenders Sledge, you could too
    Mar 2013
    Greenwich Ct
    I went to a company that sells steel studs, I bought 10 inch wide studs, picked the length and gauge. Great value! cut the sides in 4 places bent them over and wala, had new fenders for the trailer cheep. Black paint and job done in 45 min.
  16. The Following User Says Thank You to skipster316 for This Post:
    Mar 2013
    Greenwich Ct
    Quick update, put them on CL and sold them for $50 each... total $200... not bad for free and way above what the scrap yard wanted to pay
  18. The Following 6 Users say Thank You for This Post by skipster316:
    sledge's Avatar
    Central Indiana
    2,716
    4,531
    Do tell Mr. Bear!
  20. #16
    whogivesascrapmetal's Avatar
    Oct 2013
    United States
    Here in Phoenix, the guy we take our non-ferrous metals to, he said the prices are real low for stainless steel. He told us we should hang onto our stainless steel for now.
    I know its bugging the s... out of my husband. He can't stand it having scrap metals not being turned in on a regular basis.
    Anyways, if the stainless steel prices are real low where you are at, you should try to sell. Just about every time we have metals that are too good to scrap, and we list them for sale, the metals sell fast. Take to an auction, list on eBay, Craigslist, or... Shipping in your case will be a challenge, local pickup delivery or
    maybe have the buyer make shipping arrangements.
  21. The Following User Says Thank You to whogivesascrapmetal for This Post:
  22. #17
    sledge's Avatar
    Central Indiana
    2,716
    4,531
    You are correct whogivesascrapmetal: Stainless here is paying a whopping .30 cents/lb. Only thing that pays less is shred steel!
  23. #18
    Usa
    762
    67
    Quote Originally Posted by Russell View Post
    [IMG][/IMG]
    I( have never seen a stainless grill. ALthough one grill I seen appeared to be stainless was magnitc.
  24. #19
    4,756
    6,022
    Quote Originally Posted by whogivesascrapmetal View Post
    Yea I only got .35 for mine in Tucson last month!
  25. #20
    Washington
    24
    Its probably more than likely 304 S/S or something similar. Its just to expensive to make sheets like that out of a higher grade
    1. Stainless steel
      By rooka21 in forum Scrap Metal Questions and Answers
      Last Post: 04-27-2022, 01:49 PM
    2. stainless steel ?
      By taterjuice in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 06-15-2017, 02:38 PM
    3. how can you tell if its stainless steel?
      By lastchance in forum Scrap Metal Tips and Advice
      Last Post: 04-06-2012, 03:43 PM
    4. Stainless Steel
      By nyjetsfanx93 in forum Scrap Metal Questions and Answers
      Last Post: 03-09-2011, 06:56 PM
    5. stainless steel
      By 708bigbuck in forum Scrap Metal Questions and Answers
      Last Post: 01-24-2011, 07:17 PM
There are currently 10 users browsing this thread. (0 members and 10 guests)
Tags for this Thread
