Results 1 to 16 of 16
Metals in a washing machine
    MindfullyMetal started this thread.
    United States-indiana
    Question Metals in a washing machine
    I recently picked up 3 washing machines from a contact but the thing is that im not too educated on how to tell steel from aluminum parts or stainless steel from steel. Is there anyone who can help me maybe figure out what types of metals there are so I can break it down. I know the basics like the motor and the wires. I need to know what the shell is made of and the supports inside. There is a panel in the back that covers the board that i think might be alu.The model is speed queen Model# awm573w2. Thanks guys for any help.
    boise, ID
    1,605
    469
    On Speed Queens, check to see if the inner tub is non-magnetic stainless. Pull the motor and wiring harness. Check the faceplate (where the timer is) to see if it's sheet aluminum and throw the rest in your shred pile.
  3. The Following 4 Users say Thank You for This Post by freonjoe:
    Shakopee, MN
    21
    Take a magnet to the metal parts, if it sticks its steel, if not its most likely aluminum. if you cant tell by looking at it then tap it with an angle grinder, if it doesn't throw any sparks its aluminum.
    wayne's Avatar
    UK
    319
    117
    The drum where you put your clothes will be a bright shiny silver colour. This is stainless steel. Stainless steel can be magnetic or non-magnetic. Get a magnet (you can find then on the back of speakers) and try and stick the magnet to the drum. If it sticks it is magnetic stainless steel, which pays the same as the magnetic steel in the case of the machine.
    If the magnet does not stick the drum is non-magnetic stainless steel. Separate this and sell it separately as it pays more than magnetic steel.
    I know lying is wrong, but if the elephant man came in now in a blouse with some make up on, and said, "How do I look?" Would you say, bearing in mind he's depressed and has respiratory problems, would you say, "Go and take that blusher off you mis-shapened elephant tranny?" No. You'd say, "You look nice... John""
    Green Bay, WI
    377
    38
    I've found stainless doors on some (the door you dump the soap in, not the one you put the clothes in) also the plate under the knobs (with the numbers/selections printed on it) to be stainless
    thanks guys
    2,864
    350
    Magnet, magnet, magnet-#1 tool of a scraper, you should always have one with you, in your truck/car,your work bench,your pocket. If the magnet sticks it is steel/iron if not than it is a more valuable metal. A grinder is my #2 tool, if the magnet doesn't stick then hit it with the grinder,if it sparks it is ss,if no sparks and looks like steel it's aluminum, brass has a yellow color, copper has a more reddish color. Hope this helps.
  9. The Following User Says Thank You to happyscraper for This Post:
    Upper Michigan
    95
    107
    make sure to strip the motor and put it in a separate pile to sell whole or to cut and pull the copper.
    Kansas
    50
    19
    So is the wire in washing machine motors sometimes aluminum? I have cut two open so far and neither one look like copper.
    Quote Originally Posted by jmurrow3 View Post
    Yes.
    Kansas
    50
    19
    Do these motors just get thrown in the motor pile?
    coast of nc
    110
    261
    if it has AL wire in motor, my favorite yard calls them Breakage(dirty cast AL). Every place has their own way/rules. Whenever I am unsure about something I keep it separate and ask whoever is working the scale.
  15. The Following User Says Thank You to shootsitall for This Post:
    Theres silver or silver/copper contacts in the switches, timer module & actually on the motor, which I can't find out if its copper or ali windings.
    I like those motors though, Its a Aluminium housing glued (Glued!!!) to the iron core.
    Use safety specs, gloves, earmuffs & a large hammer & the Ali housing breaks up into the Ali & the Iron core with the windings attached.
    Cut the wire loops off one end (after you have checked to see if its Copper or Ali. If its Ali, don't bother pulling it apart any more, sell it as 'motors')
    & pull the rest of the windings out, remove any insulation & string & add it to the rest of your bare Copper wire.
    Yah might get 2Lbs of copper #2.
    Although those motors come in a few different lengths, which affects the amount of copper in them a lot.
    The Ali castings have to have all other metal removed from them before selling, ie remove any screws & bearings etc.
  17. The Following User Says Thank You to eesakiwi for This Post:
    Kansas
    50
    19
    Thanks for the useful information!!! I will take that info and run with it.
    recyclocan's Avatar
    May 2013
    SW Ontario
    17
    Hidden copper
    FYI. (Or maybe everyone already knows) I discovered attached to the plastic valve assembly these cylindrical plastic things with electric contacts. I cut one open out of curiosity and BOOM. Full of copper!
  20. #16
    99problems's Avatar
    Jul 2013
    Atlanta
    72
    Quote Originally Posted by recyclocan View Post
    please explain
    1. Washing Machine Fire Pit
      By KzScrapper in forum A Day in the Life of a Scrapper
      Last Post: 02-28-2014, 06:40 AM
    2. I saw a washing machine
      By charn in forum A Day in the Life of a Scrapper
      Last Post: 06-25-2012, 08:31 PM
    3. Washing Machine
      By chrisblackcat in forum Scrap Metal Questions and Answers
      Last Post: 05-31-2012, 08:53 PM
    4. New use for an old washing machine
      By Bear in forum Off Topic Discussions
      Last Post: 02-19-2012, 01:21 AM
    5. Washing Machine $$
      By chaseonthego in forum More than Scrap Value
      Last Post: 09-04-2011, 02:31 PM
Tags for this Thread
