Results 1 to 18 of 18
Should I tear it apart????
| Scrap Metal Tips and Advice
    lastchance started this thread.
    lastchance's Avatar
    ft walton beach fl
    37
    I have 3 riding lawnmower engines. Should I break them down or just take them to the yard as is?
    LadyScrappers's Avatar
    Lakes Region, NH
    163
    339
    Tear one apart, take one whole, and compare prices when you bring it to the yard - then you can see for yourself whether or not its worth it to tear apart the last one.
  3. The Following 7 Users say Thank You for This Post by LadyScrappers:
    I think we tried to help you answer this in a previous thread. Do you have more money then time or more time then money? What is your yard going to pay for the two different options?
    Me...I would take it in, drained, and turn it in as aluminum breakage or transmission price, which ever is greater.
  5. The Following 2 Users say Thank You for This Post by KzScrapper:
    61
    19
    I'd take the engines in as irony aluminum
    lastchance's Avatar
    ft walton beach fl
    37
    In the previous post I asked about tearing down the lawnmowers. I ended up tearing them down because they were to heavy for me to load them up. I have way more time then money lol I got a load to take to the yard today so ill ask them what they suggest.
    585
    76
    If you got a lot of time I would pull the engines and transaxles people buy those on CL
    ks
    2,187
    2,513
    If you don't have another project to jump on right now I'd tear em down especially if their aluminum block
    Green Bay, WI
    377
    38
    Careful asking what the yard suggests. They may tell you to bring them in whole, when it's worth more to tear them apart, just because they want to pay out less. Get what i'm sayin?
  11. The Following 3 Users say Thank You for This Post by Gnraxlrose88:
    2,864
    350
    I wouldn't break them down, to much work for a few extra cents. Lawnmower blocks have steel cylinder sleves thats almost imposible is to get out. The yard will only pay you irony aluminim. Take the gas tank off and drain the oil and take it in whole. My 2 cents
    brandon's Avatar
    North Carolina
    787
    if its aluminum i would break it down, not all lawnmowers have steel cylinder walls, the ones that do are no match to my hammer, couple of hits with a 16# sledge it pops right out.
  14. The Following 2 Users say Thank You for This Post by brandon:
    5,728
    6,814
    Then what, with the gas tanks? There's several old tanks around here i'm not sure what to do with. I just noticed an old car tank behind the old barn, the whole end has rusted through on it. will they take anything like that?
    Bear-I usually take the plastic tank off mowers, empty and toss. That way the yard knows it's empty if its not there. As for metal tanks, if the hole is big enough and empty, maybe they will take it.
  17. The Following User Says Thank You to KzScrapper for This Post:
  18. #13
    I break engines down because i get more for the aluminum that way. I always wait until I have a couple and then work on them. the more I do the easier they get to taking apart! Only once did I have one with the steel cylinder walls and I just sledgied as much aluminum off around them as i could.
  19. The Following User Says Thank You to newattitude for This Post:
  20. #14
    danielms's Avatar
    mississippi
    133
    71
    i have been thinking about building a hammer mill for things like that, or some kind of crusher hydraulic powered if possible.
  21. #15
    2,864
    350
    The yards I use take gas tanks if you cut a large hole in them or cut them in half.Then again all yards are diffrant, might want to check with your tard first.
  22. The Following 2 Users say Thank You for This Post by happyscraper:
  23. #16
    5,728
    6,814
    can i say you told me to?
  24. #17
    ks
    2,187
    2,513
    My yard takes em as along as their drained and have holes in em, plastic or otherwise
  25. #18
    2,864
    350
    yea Bear thats cool
    1. 5.25 floppy drives...dont tear apart!
      By Ecycle Atlanta in forum Scrap Metal Questions and Answers
      Last Post: 08-21-2013, 10:33 AM
    2. Microwave Tear Down
      By CMHN in forum Scrap Metal Videos
      Last Post: 07-05-2013, 01:24 PM
    3. my most efficiant e tear down.
      By EcoSafe in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 10-21-2012, 08:48 PM
    4. LCD Monitor tear down
      By street_sweeper in forum General Electronics Recycling
      Last Post: 02-11-2012, 02:53 PM
    5. Starting a Mobile Home Tear Down
      By ocedy in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 09-20-2011, 09:18 PM
