Do most yards take restaurant grease traps? I found one. Wondering if I shud grab it
I would think that it would need to be empty. Also where are you going to dump the grease if it is full?
It's already empty. It was removed and put aside
Make sure you introduce yourself in the intro catogry and others will chime in and give you some help with this.
Is that a payphone case next to the grease trap?
I know lying is wrong, but if the elephant man came in now in a blouse with some make up on, and said, "How do I look?" Would you say, bearing in mind he's depressed and has respiratory problems, would you say, "Go and take that blusher off you mis-shapened elephant tranny?" No. You'd say, "You look nice... John""
Your yard will probably require a good sized hole in the tank or cut in half.
BTW the yard I go to is ecology wrecking. These guys have every imaginable thing to scrap. They scrap eveything and they got their own grinder machine thingy. They also use torches to cut dowb trains like freight trains
That might be good enough...you will have to call and ask.
I have scrapped one of these and didn't have a problem if that helps
BUYING ALL COMPUTER SCRAP WORKING OR NOT
CHECK OUT MY BUYERS THREAD http://www.scrapmetalforum.com/scrap...nic-scrap.html
https://getjunk.net/Knox-County-TN-0...Recycling.html
I ask cuz I'm a one man operation and some random dude helped me load it. I know where to get another one. Might not wanna get it if it don't weigh Enuff. 1. Being hard to load. And 2. Being takes up my whole truck for anything else
Wow as much as I thought my normal yard would take it. They didn't! Anyways I drove right across the st and their compeititor took it. I stopped going to the competition because their pricing was a lot less compared to my normal yard. But I guess each has their own pros and cons
