Results 1 to 20 of 34
im a new scrapper and need help
    scrappergirl4200 started this thread.
    11
    well i have taken apart a lot of appliances and came
    acrossed this spool of copper wraped in tape with what
    resymbols a real heavy steel square around it
    can someone tell me how to get the copper out of those
    and what are they? please and ty
    89
    Check out jackshmuc eather here or on youtube Should help
  3. The Following User Says Thank You to maxa for This Post:
    those are transformers. If you dont have an air chisel, set the transformer on the floor. At the weld up against the copper spool set an ax. Use a short armed sledge hammer to whack the ax. A few good whacks and the one side of the transformer will come apart and you can get the copper spool out. sometimes I just cant get them apart and I turn them in as is. If you have a vise big enough to hold the transformer while you whack it - even better!!
    http://www.scrapmetalforum.com/showt...t=transformers
    heres a video showing you how to use those tools to take one apart - its at about 2:50 or so into the video where he shows how he does it. This works!!
  6. The Following 2 Users say Thank You for This Post by newattitude:
    Hi scrappergirl....welcome to the forum. There are several threads here that answer that question for you. Type in tranformers in the search feature and it will direct you to a thread on getting the copper out. There is also a video by Jackshmuck, but I don't recommend that you use that method unless you have experience in another trade involving tools. Also, we'd like to get to know you. We have an introduction section and I'd like to invite you to tell us a little about yourself there.
  8. The Following User Says Thank You to Dumpster-Dee for This Post:
    I see that three of us were typing at the same time...you'll get your answer !
    101
    40
    More than likely it's a transformer or type of relay . I just put them in with elec.motors , as seperating the wire from the tape is not cost effective how ever if it is a solid coil of wire just cut some of the wire and it should begin to unravel with out to much problem. I still put those kind in the elec. motor bucket. Hope this helps. wb
    101
    40
    Hello Dee I think four of us were typing at the same time.
    11
    thank you to all im about to watch the video now ill let you all know
    what i think,,,lol
    If you do it this way, wear good eye protection as your likely to have a steel chip come flying off one of those tools like shrapnel. Their not made to smack together, their both a hi-grade steel. You could use a hammer and chisel.
  14. The Following 4 Users say Thank You for This Post by Mechanic688:
    Mechanic, the ax I use has a flat head on the opposite side like a hammer head so I'm not hitting a sharp edge against a flat edge - its two flat sides hitting together. Or are you saying those flat sides could still break a pice off when hitting together? I do wear glasses anyways but if the OP doesn't wear glasses they could at least wear some sunglasses if they dont have safety glasses.
  16. The Following User Says Thank You to newattitude for This Post:
    Port St Lucie, FL
    176
    128
    If you have already seen the video. The transformers in the video are from microwaves. What you have described sounds to me to be a smaller transformer. The transformers that have the copper wrapped in a yellow taped are too time consuming for me to scrap. (not cost efficient - time is money) Though I did have to learn the hard way & scrap a few to learn this.. LOL Instead I put them in my CBM pile (Copper Bearing Motor) pile and get paid around 15 cents per pound. Because of the heavy steel square around it they do add up quickly! Hope this helps!
    If you like to Scrap the Crap & Cash the Trash - Then Check out our Videos on Youtube!
  18. #13
    The weld is the key....if it doesn't have a weld this method won't work. (I mean if the metal is complete or something that looks like tiny slices vs. welded together)
  19. The Following 2 Users say Thank You for This Post by Dumpster-Dee:
  20. #14
    Quote Originally Posted by BiggerHammer View Post
    Yeah, depends on how that tape is wrapped in the transformer the OP has. Sometimes the copper is wrapped in tape in many many layers - i dont take those apart. But if the tape is just on the outside of the copper spool those are worth taking apart.
    scrappergirl - if you get the spools out be sure to cut the wire and see if its actually copper or aluminum. I have had transformers that have one spool of copper and one of aluminum, some with two spools of aluminum and some with two spools of copper. So be sure to check what kind of wire you have after you get it out.
  21. The Following User Says Thank You to newattitude for This Post:
  22. #15
    With all due respect to newattitude, I would suggest that you scratch the wire BEFORE you try to take it out....if it's all AL, don't bother.
  23. The Following 2 Users say Thank You for This Post by Dumpster-Dee:
  24. #16
    its two flat sides hitting together. Or are you saying those flat sides could still break a piece off when hitting together?
    Yes, like I stated (you can google it) they are both hi-grade steel and can chip pieces off, does not mean it will; just could happen. Be forewarned, that's all,,
  25. The Following 2 Users say Thank You for This Post by Mechanic688:
  26. #17
    another tamer method is to cut one side of the copper loup off with an angle grinder or saw and punch out the rest of the copper. this is my prefered method. im too old to chase the transformer arround when you dont hit it squarely with the ax. also sooner or later almost every one says Ill just try to hold this one with my fingers while I whack it with the ax.
  27. The Following 3 Users say Thank You for This Post by EcoSafe:
  28. #18
    An angle grinder with a thin cutoff slices nicely through these things.
  29. The Following 2 Users say Thank You for This Post by IdahoScrapper:
  30. #19
    On the small transformers I cut one side with a sharp wood chisel then flip it over and tap a screwdriver under the windings then just pry up on the wire.
    No muss no fuss.
    I have yet to take a load to the yard and have any motor grade scrap. Copper fluctuates a great deal but what they pay for motors does not.
  31. The Following 2 Users say Thank You for This Post by injunjoe:
  32. #20
    Usa
    763
    67
    I just take any and all transformers and throw them in my hillbilly death machine aka the INCINERATOR>>>HE HEH!1 Then after 2 mins of copper the copper just falls out into a nice pile. Speaking of which I got to go burn some snow out and sift the ashes from yesterdays run.....
  33. Similar threads on the Scrap Metal Forum
    1. New scrapper here.
      By dirtymoney in forum Introduce yourself
      Last Post: 02-06-2013, 03:19 AM
    2. Bigger hammer, jack scrapper, and mike the scrapper
      By jackshmuc in forum Off Topic Discussions
      Last Post: 12-04-2012, 12:12 AM
    3. New scrapper
      By Soyoubara in forum Introduce yourself
      Last Post: 10-23-2012, 02:33 AM
    4. New scrapper in MN
      By Darren in forum Scrap Metal Spots
      Last Post: 11-14-2011, 09:31 PM
    5. New Scrapper
      By Dzldawg in forum Introduce yourself
      Last Post: 07-29-2011, 10:11 PM
