Results 1 to 20 of 29
Engine Block in the Marsh
    Taylor586 started this thread.
    Poquoson, VA
    33
    Okay, so behind my grandpa's house in the marsh is an old engine block on a wrecked boat. I'm trying to think of a way to get it out of there.
    It's too far back to take my truck without it getting stuck. So, I'm kind of stumped.
    Any ideas? :confused:
    Saint Louis, MO
    762
    One long ass chain lol.
  3. The Following 2 Users say Thank You for This Post by PistoneScrapProcessing:
    Maybe a quad and winch (or a wench if your so inclined). LoL
  5. The Following 2 Users say Thank You for This Post by Mechanic688:
    Ocala fl
    100
    73
    If its a smallblock v8 it probably weighs about 300lbs at the most. Lever it onto a car hood or sheet of plywood and skid it out.
  7. The Following User Says Thank You to fordsix for This Post:
    Usa
    763
    67
    Yep skid it out and use a winch.....
    I prefer a wench.
  10. The Following User Says Thank You to miked for This Post:
    Poquoson, VA
    33
    I don't have a winch though. D: And I don't have the money for one either. Sliding it out is probably the best way to do it right now! Thanks!
    VA
    52
    I say, DO IT, this is a real good time to learn what works. Don't give up. Keep asking for idea's and trying your own.
    1st....How far from stable ground?
    2nd...How big is it? (The Block!!!!!)
    Poquoson, VA
    33
    Oh, no. I decided from the second I saw it I was getting in out of there one way or another! It's about a hundred feet or so from stable ground and it's a small block. I think it's a 350. There was also a pretty big drum and some other metal parts to the boat laying around too.
    VA
    52
    100' is not very far. So lets start with the weight...a 350 fully dressed will clock in about 575 lbs. Stripped about 180 lbs.
    I would get 3 2x10x12' boards and nail 4 2x4x48" board to them and make sort of a sled with them. Strap the block near the end of the sled and pull with a rope from the other end. Making it that long and putting the block near the rear will help keep the nose up so you can pull it out. Also 48 wide will help with stability.
  15. The Following User Says Thank You to Divemaster920 for This Post:
  16. #11
    Poquoson, VA
    33
    That sounds like a pretty good idea! I think I might try that!
    fresno, california
    146
    Pixs Of it and the area?
  18. #13
    Would a plastic type snow sled work or do you think thats too heavy for it? if your near waterways maybe there are some floats lying around you could use under the sled
  19. #14
    Poquoson, VA
    33
    I don't have any pics right now. I think getting it out wouldn't be as much trouble as actually getting it in the truck. I don't have a trailer, so I can't just slide it onto that.
  20. #15
    Poquoson, VA
    33
    And there's a creek next to it, but it doesn't go anywhere close by.
  21. #16
    Ohio Scrapper's Avatar
    NW Ohio
    336
    467
    Quote Originally Posted by Taylor586 View Post
    A chain, a heavy tree limb and a come-a-long should get it into the truck easily enough.
  22. The Following User Says Thank You to Ohio Scrapper for This Post:
  23. #17
    A pallet with a piece of plywood nailed to it might work in a pinch, and if you need to chain it out just remove a fairly long bolt and put it thru one of the end links of chain and screw it back in and tighten. Might need a washer. Also an alum round kids saucer for winter could be used to set the motor on and pull.
  24. #18
    Poquoson, VA
    33
    Thanks for the ideas guys!
  25. #19
    thortek's Avatar
    Scrap biz in OHIO, but I live in south Florida!
    513
    153
    A comealong, or $60 electric Winch from Walmart, and pull the whole boat out! scrap the engine and sell the hull on Craigslist!
  26. The Following User Says Thank You to thortek for This Post:
  27. #20
    matt018's Avatar
    Southeast PA
    174
    Just get a chain and put the truck in drive, No need for a winch but it would be helpful, Just use your trailer hitch for a spot to hook the chain.
    1. Aircraft Turbine Engine - Jet Engine Recycling & Buyers
      By Aeroturbinetech in forum Introduce yourself
      Last Post: 08-08-2019, 07:53 PM
    2. I got my first engine block...
      By xhalt in forum Vehicle Recycling
      Last Post: 12-13-2012, 05:53 PM
    3. Piece of engine block?
      By bcoop in forum Vehicle Recycling
      Last Post: 03-16-2012, 03:05 PM
Tags for this Thread
