Results 1 to 17 of 17
HVAC System Break Down
    injunjoe started this thread.
    Equipment; Carrier 3 ton Condenser/heat pump and 3.5 ton air handler with 7.5 Kw emergence heat.
    Total Weight
    ; About 300 lbs
    Steel; 150lbs
    ACR coil; 57lbs
    Copper; 10.32 lbs
    NiCR; .45lbs
    Compressor 58 lbs
    Aluminum; Did not weigh
    Insulated #2 wire; Did not weigh
    These weights are without cutting open the compressor yet and I saved the blower assemble to make a exhaust hood to help keep my shop and lungs a little cleaner.
    I also forgot the reversing value and other Brass. I'll just chalk that up for fuel costs.
  2. The Following 4 Users say Thank You for This Post by injunjoe:
    boise, ID
    1,605
    469
    Are there a lot of heat pumps down there?
    Yes there are! Being the winter temps don't get to cold here. Seems they have been getting colder the last few years though!
    divapickers's Avatar
    Hamilton, Ontario
    155
    96
    Some on the A/C units we get are from roof tops. A crane takes it off the roof and sits it in our utility trailer. The big units we call a flatbed tow truck company. These are relatively easy to get but you'll have to pay the installer $100 but you'll receive $300 to $750 depending on the size.
    One day we got two $900 units but we paid $350 each and a $100 tow. Stripped them do at the scrap yard with our saw and drills in 3 hours.
    Got to grease the palms to get the good stuff up here in Canada. Everyone thinks the have gold.
    Quote Originally Posted by divapickers View Post
    That's the great part, I'm the installer and the scrapper! Win Win!
  7. The Following 2 Users say Thank You for This Post by injunjoe:
    Henderson nc
    246
    Thats like cheating injunjoe lol.
    Abraham Lincoln
  9. The Following 2 Users say Thank You for This Post by Ptscrapper:
    Ever have a dej'a vu moment?
    Scrap Master J's Avatar
    Alaska
    227
    82
    Having a efficient, well thought out plan, is not cheating. They are characteristics that lead to a success.
  12. The Following User Says Thank You to Scrap Master J for This Post:
    Louisiana
    255
    74
    Have an opportunity to buy a 7.5 ton rooftop unit. What should I offer and expect to get from it?
    Enduringlion's Avatar
    May 2013
    Madison, Maine
    21
    19
    This thread is just in time. I just scored a commercial ac compressor. How does one cut these open, or what is the easiest way? Torch, grinder or reciprocating saw?
    ryanw's Avatar
    TX
    1,312
    526
    I used an angle grinder to open one up once. Just my luck the steel was 1/4" thick, and this was a tiny unit...very old I guess. It took me 20 minutes to do it, and I've never done it again
    May 2013
    Madison, Maine
    21
    19
    Thanks for the info Ryan. This unit appears to have a thick shell as well. I was thinking reciprocating saw.
    corycouch's Avatar
    jonesboro ar
    1,405
    3,766
    ive tried all three, the easiest is the torch but the oil is going to burn, plasma cutter is best but only if you already own one
    cory couch
    c & c recycling
    JUNKERS AND CLUNKERS
    (870) 897-6484
    May 2013
    Madison, Maine
    21
    19
    Quote Originally Posted by corycouch View Post
    I don't own a plasma cutter but have access to a torch. Thanks.
  19. The Following User Says Thank You to Enduringlion for This Post:
  20. #15
    Some yard will let you drill a hole in it and drain the oil. Price is better then shred but not as good as motor and certainly not as good as recovering the copper.
    Freonjoe uses a table saw with a cutoff blade and it seems to work well for him. You need to drain the oil first though.
  21. The Following User Says Thank You to KzScrapper for This Post:
  22. #16
    May 2013
    Madison, Maine
    21
    19
    I have already drained the oil. The table saw idea I will pass on for now. I may use an old circular saw with the blade set low. Thanks Kz.
  23. The Following User Says Thank You to Enduringlion for This Post:
  24. #17
    Quote Originally Posted by KzScrapper View Post
    I believe he cuts the cases with the plasma, then cuts the windings with the table saw.
    OP, get a 4 1/2 grinder and some cutoff wheels. It's just about the 2nd easiest way to get them open. Plasma being 1st choice. JMO.
  25. The Following 3 Users say Thank You for This Post by IdahoScrapper:
    1. The Story of Money: From a Barter System to a Money System.
      By mrsamsonite in forum Off Topic Discussions
      Last Post: 01-10-2021, 09:09 PM
    2. Stainless Alloy in HVAC Units
      By TexasDeere in forum Scrap Metal Questions and Answers
      Last Post: 03-18-2012, 05:36 PM
    3. Phone system??
      By sabicp in forum General Electronics Recycling
      Last Post: 12-31-2011, 08:20 PM
    4. cooling system
      Last Post: 11-30-2011, 11:46 AM
    5. HVAC Hardware
      By Eradication in forum Scrap Metal Questions and Answers
      Last Post: 07-13-2011, 03:47 PM
