Results 1 to 20 of 30
don't get cheated on comp heat sinks
| Scrap Metal Tips and Advice
    EcoSafe started this thread.
    I have see this come up now and then, and it was tried on me.
    thgere are two different types of conputer heat sinks. there are the ones stamped out if plate or sheet alu, and ther are those that are extruded.
    it is easy to tell the difference, but many yards are not particularly familiar with e waste, and will many times try to count the extruded ones as eith plain alu sheet or cast alu. don't let them do this. you may have to educate them, a little concerning e waste.
  2. The Following 6 Users say Thank You for This Post by EcoSafe:
    CMHN's Avatar
    Berwick, Pa
    380
    49
    Thanks for the warning, I will have to keep my eye on this the next time I take my aluminum in.
    CMHN Recycling
    Dallas TX
    1,979
    158
    Make sure you take out the copper heat sinks. They may look like aluminum but they are copper plated with nickel. If you are unsure scratch test the bottom of the heat sink and see if you see copper.
    The copper heat sinks that are plated with nickel will be very heavy..a good clue for you to check it.
    My Name Stephan Harz
    My YouTube page
  5. The Following 10 Users say Thank You for This Post by easyrecycle:
    CMHN's Avatar
    Berwick, Pa
    380
    49
    Wow, even more to keep an eye out for thanks easy.
    New Jersey
    102
    53
    At my yard aluminum is aluminum is aluminum.
    Only difference is clean or dirty..
    Then your getting took,, Smile and wait for the kiss.
    ScrapperNJ26's Avatar
    Clementon NJ
    512
    537
    The one's on the cpu's are up to 70% nickle
    195
    10
    Quote Originally Posted by ScrapperNJ26 View Post
    Not to be negative but this seems unlikely... any link to proof? I'd love to be proven wrong and find out my heat sinks are worth a lot more.
  11. The Following 2 Users say Thank You for This Post by bjybjy:
    Clementon NJ
    512
    537
    I have to find it again, don't have the link anymore.
    New Jersey
    102
    53
    What's the difference in payout, .10/lb? I don't move enough aluminum to have it make a noticable difference.
    Quote Originally Posted by easyrecycle View Post
    Where are these found? Computers? Servers? elsewhere?
    195
    10
    I've been getting a lot of them in Dell P4 era computers. At first glance they look sort of like extruded aluminum, but tend to be a little shinier and the bottoms are a little thicker and definately more dense. The plating can be pretty thick so take a thick screwdriver or something and really scratch the bottom good. Go deep enough and you'll see that nice copper pink show through.
    Often it is aluminum fin soddered to a plated copper base.
  16. The Following User Says Thank You to bjybjy for This Post:
    195
    10
    Here are a couple pics of one type I encounter frequently:
    Dallas TX
    1,979
    158
    the photos that are posted above this post are dead on some copper type. I have some at the warehouse if I remember to take a photo of the diffident types...I just took a 55drum full of them in so don't as much as I did but hey..I needed the drum.
    Filthy's Avatar
    Northern New Jersey
    780
    850
    what do i do with my laptop heatsinks like this one
    i have a couple and im not really sure how to process them
    We're the renegades of Junk!
  20. #16
    Dallas TX
    1,979
    158
    Quote Originally Posted by Filthy View Post
    Cu+AL metal...I would not even spend the time to clean it. You should make around $1.60 (non-dealer) pricing.
  21. The Following User Says Thank You to easyrecycle for This Post:
  22. #17
    Filthy's Avatar
    Northern New Jersey
    780
    850
    thanks brother
  23. #18
    I get the same most days for sheet and extrusion but my guy likes it separated at least. Sometimes there is a few cents difference. Only one time did I ever run across a heat sink with a copper circle in the center. Knocked it out in the vise.
  24. #19
    How can that be newattitude ?? You say "my guy". I would understand if you had different "yard men" each time, but why would "your guy" change from time to time. All "you guys" have to do is google aluminum extrusion and you'll come up with plenty of pictures of extruded stuff....one, forget the name (Armstrong?) is a co. that makes heatsinks. You can print out a picture and take it to your yard. Don't let them get away with this nonsense, cause in my book, every penny counts.
  25. The Following User Says Thank You to Dumpster-Dee for This Post:
  26. #20
    I have no idea Dee, sometimes he will leave mixed aluminum together and sometimes he wants it separated. *Shrugs* Extrusion isn't always the exact same price at the yard I use, sometimes its a couple cents different. *Shrugs again*
  27. The Following User Says Thank You to newattitude for This Post:
    1. alu looking copper heat sinks
      By EcoSafe in forum Scrap Metal Tips and Advice
      Last Post: 12-22-2012, 07:32 PM
    2. AL heat sinks glued to processors
      By Scrap man in forum Batteries, Capacitors, Heat Sinks
      Last Post: 09-28-2012, 12:45 PM
    3. Newbie question...Heat Sinks?
      By missmargaret in forum Batteries, Capacitors, Heat Sinks
      Last Post: 09-11-2012, 06:55 PM
    4. 320 pounds of heat sinks....
      By Scrapcrazy in forum Batteries, Capacitors, Heat Sinks
      Last Post: 07-28-2012, 08:25 PM
    5. How to identify CPU heat sinks?
      By ilyaz in forum More than Scrap Value
      Last Post: 07-05-2011, 11:58 PM
