Results 1 to 8 of 8
    Pattyb started this thread.
    Pattyb's Avatar
    New Jersey
    16
    Help! I need to strip an old Johnson Outboard motor.
    Hey everyone. I have an old Johnson Outboard with a cast aluminium casing, but I need to take the motor out. Can anyone tell me how. Thanks again, Patty.
    4,918
    15,581
    I haven't torn down any outboards but have owned several. Lots of small bits of ferrous to remove. If you don't remove them all you will get the irony Al or dirty Al price. I sugguest you call your yard and determine if it is worth the effort. You will never be certain til you try. I would get out the angle grinder, large hammer, and a magnet. Best of luck and take pictures, Mike.
  3. The Following User Says Thank You to miked for This Post:
    Midnight is offline Metal Recycling Entrepreneur
    Midnight's Avatar
    McHenry County, IL, USA
    242
    41
    I've got one to tear down myself. If I get a chance to get to it before you get your answer, I will let you know.
    submarinepainter's Avatar
    1,026
    1,230
    I would start with draining any fluids Patty , then I would just do as mentioned above some tools and a magnet , me myself I would do it just to see whats there!!
  6. The Following User Says Thank You to submarinepainter for This Post:
    Pattyb's Avatar
    New Jersey
    16
    Hey mike this is a old one I just want the engine. Entire casing is cast aluminum I just want to separate the engine from the casing and scrap the casing.
    4,918
    15,581
    You may be correct but I doubt it. Check the cylinder to see if it has a ferous sleeve if so it would have to be removed.
    As far a seperating the upper from the lower there are a few bolts that hold them together. There is the drive shaft coming out of the bottom of the engine(aka power head). In addition there is a shift shaft that is in front of the drive shaft.
    I just re-read what you wrote. Hit the casing very hard with a big hammer. It will break into bits. Check for any ferous still hanging on. And wear eye protection. Mike.
    PS the engine is mostly Al but it will take time to clean up. The lower unit is also mostly Al except the internal shafts and gears. Also the lower should contain gear oil. This is an unvented area so it STINKS. Do not drain indoors or get that stuff on anything you care about. Mike.
  9. The Following 2 Users say Thank You for This Post by miked:
    2,529
    2,906
    The two strokes normally have a sleeve thats put in from underneath the engine (crankshaft end) basically the barrels a dead end & the sleeves gotta be taken out the same way as it was put in.
    On the other hand, because the things mostly Ali &/or Magnesium, with thin wall sections, a good bashing with a sledge hammer will work wonders.
    Use your safety glasses, & earmuffs, you can shut your eyes, but not your ears....
  11. The Following 3 Users say Thank You for This Post by eesakiwi:
    1,308
    1,247
    I like the way you say that!
  13. The Following User Says Thank You to injunjoe for This Post:
    1. Reminder about whether to strip wire or not
      By Scrap man in forum Scrap Metal Tips and Advice
      Last Post: 11-07-2017, 09:01 AM
    2. BX Wire - Strip or Not?
      By BigRyan in forum Scrap Metal Questions and Answers
      Last Post: 12-22-2012, 12:34 PM
    3. How to strip copper from a constant motor
      By demillo in forum Scrap Metal Questions and Answers
      Last Post: 07-30-2012, 04:23 PM
    4. Outboard Motor
      By injunjoe in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 11-29-2011, 06:39 AM
    5. To strip or not to strip
      By ozzy214 in forum Scrap Metal Questions and Answers
      Last Post: 11-06-2011, 06:45 AM
