Results 1 to 19 of 19
what items are made of zinc
Hybrid View
    redcrossnj is offline Metal Recycling Entrepreneur
    redcrossnj started this thread.
    redcrossnj's Avatar
    central jersey
    465
    28
    what items old or new are made of zinc besides pennies and wheel weights? thanks guys
    2,529
    2,906
    Dry cell battery cases, anodes from boats.
    rca987's Avatar
    939
    Some pipe couplers
    2,417
    664
    I have an old baker's table that has a zinc covering on it. I believe some old wash tubs/sinks may be as well.
    It is typically not used by itself, but with other metals such as copper to make brass, or used for galvanizing.
    vamped400's Avatar
    Exeter, maine
    204
    72
    the most zinc ive found was in shingle piles. they go around the chimneys
    2,161
    Gah! Zinc is the bane of my scrapping existence!! lol. Just when I think I know what all contains zinc and seperate my stuff the yard guy pulls something out of my cast pile and calls it zinc. Anywho, some heavy parts of a lamp middle are zinc, faucet handles are zinc, mmmmm.....the round part at the end of grill hookups too - the part that screws into the tank that has the brass nose in it. You have to go by weight too, zinc/die cast is heavier. I used to go by the color of an item but they really isn't good either because some darker stuff I think is zinc he tells me is cast. I hate figuring out zinc!!!!!!
  7. The Following User Says Thank You to newattitude for This Post:
    Oro Valley, AZ
    72
    71
    Gah! Zinc is the bane of my scrapping existence!! lol. Just when I think I know what all contains zinc and seperate my stuff the yard guy pulls something out of my cast pile and calls it zinc.... I hate figuring out zinc!!!!!!
    If you put a drop of acid, pool acid for instance, on zink it will fizz. Aluminum will not fizz.
    Starbits
  9. The Following 6 Users say Thank You for This Post by starbits:
    1,213
    sacrificial anodes from hot water tanks,
  11. The Following User Says Thank You to gustavus for This Post:
    harrisvh is offline Metal Recycling Entrepreneur
    Nottingham
    181
    26
    And steel boat hulls
    4,756
    6,022
    The brackets that hold celing fan blades in place
  14. The Following User Says Thank You to hobo finds for This Post:
    2,161
    ^^^Yep! I forgot about those!
    junkelly's Avatar
    Detroit
    The couplers and elbows and other fittings from electrical conduit are zinc. So are some of the handles for screen doors.
  17. The Following User Says Thank You to junkelly for This Post:
  18. #13
    4,756
    6,022
    Yes lots of items as said. I have turned in 41 lbs of "die cast zinc" this year and only made $5.10 on it! LOL
  19. #14
    rca987's Avatar
    939
    I have been to 10 or so different scrap yards, and never have seen a zinc price, or had any problems with yard workers pulling out said zinc items...It's all Aluminum, same price...Cast and extruded can be mixed in same bucket too.
  20. #15
    2,529
    2,906
    Are the two bearing brackets on these motors zinc?
    I find a lot of these, easy work, sometimes the brackets are Ali which are easy to tell apart.
    I undo the 2 screws & pop out the armature & bearings.
    Then just bash that end sideways & the part with the copper coil falls out, then push the inner part out & break off one end of the plastic bit & unwind the 50Gms of copper wire on it.
  21. #16
    Filthy's Avatar
    Northern New Jersey
    780
    849
    zinc sells as "die-cast" for me, .20/lb. the last bucket i sold was like $12 or something, half full. stupid zinc
    We're the renegades of Junk!
  22. #17
    wayne's Avatar
    UK
    319
    117
    And sacrificial anodes from the bottom of caskets - not that you're ever likely to come across one to scrap!
    I know lying is wrong, but if the elephant man came in now in a blouse with some make up on, and said, "How do I look?" Would you say, bearing in mind he's depressed and has respiratory problems, would you say, "Go and take that blusher off you mis-shapened elephant tranny?" No. You'd say, "You look nice... John""
  23. The Following User Says Thank You to wayne for This Post:
  24. #18
    3,703
    3,699
    Hard drive mounting brackets on rack mount server hot swap Hard drives. I have literally a ton of them. not worth fuel to haul them. Last year they were calling them cast alu.
  25. #19
    Alabama
    764
    1,062
    Trophies that aren't plastic or brass are die cast. Some call this zinc.
    Olddude, next time I'm in your area, I need to come by and look at that stuff. I might be able to move it for you. I'll check on it.
Tags for this Thread
