Results 1 to 14 of 14
armoured bx cable
| Scrap Metal Tips and Advice
    ozzy214 started this thread.
    Usa
    763
    67
    armoured bx cable
    My yard around here only pays 10c for the armoured bx cable. The type of romex where it has a metal sheathing. Anybody got any tricks or advice to get the copper wire out of it?>
    ah man I hate that stuff. I usually just cut it in short enough lengths I can pull the romex out of it easier. stick one end in a vice and pull it out in 2 or 3 foot lengths.
  3. The Following User Says Thank You to newattitude for This Post:
    Nottingham
    181
    26
    I was in attic other day and noticed that the wiring from before the mental hospital was changed into flats that the old wiring was still left over and not in use. I started to take it off and noticed that it had no insulation -only normal wall paint covered it. It was around 6mm and hollow inside filled with some white powder. Anyone come across this type of wiring before?
    Its called "Pyrex" or 'pyro' here I think.
    Its a copper tube filled with the white powder & theres a rather thick copper wire running down thru the center of that.
    The scrappers here have a separate price for it.
    The only place I have found it is in street lamp posts.
  6. The Following User Says Thank You to eesakiwi for This Post:
    Nottingham
    181
    26
    Thanks for that, it's a real pain to get off as its screwed to walls and they have rusted so whave to pull them out leaving holes on the plaster. Shouldn't be an issue though as whoever did the conversion didnt seem to care about the attic. Big holes everywhere allready and there are all sorts of wires just propped up with bits of wood. I reckon i can maybe salvage roughly 10kg of it how much does it go for?
    old mental institution..."Pyro" wire....anybody else think..."Norman Bates" ???!!!
  9. The Following 4 Users say Thank You for This Post by Dumpster-Dee:
    High Voltage Processing's Avatar
    Allentown PA
    316
    63
    Ozzy how much of it do you have?
    Jim Dwyer
    President/Founder High Voltage Processing
    www.highvoltagepro.com
    484-226-9323
    Copper Head's Avatar
    Up North
    1,883
    579
    Quote Originally Posted by harrisvh View Post
    I would cut them about 1 to 2 ft in length wash them up let them oxidize a bit then mix them with some nice #2 like another 10kg put some nice #2 on the bottom then gently mix the the remainder till holding box is filled 44 plus LB of #2 ready to go to market
    Nottingham
    181
    26
    Sounds like the way forward
    Ontario Canada
    205
    45
    if you have a backyard aluminum forge you can throw it all right in and you can skim off the solid copper with the dross you.
    and if you are doing that you might as well start up your copper forge and then melt down the copper right after to save on fuel and all.
    wavecrazed's Avatar
    219
    I've heard it called mc cable Metal clad. sometimes its aluminum and or steel. I use tin snips and cut it about 3 feet or so and pull out the number 1 wire.
    wayne's Avatar
    UK
    319
    117
    In the UK we call this MI or MICC cable (Mineral Insulated Copper Clad). The copper wires in the centre of the cable (usually two, but can be more) are surrounded by white magnesium oxide powder to insulate them from each other. The wires and the oxide insulation are all contained in a copper tube which is often covered in a pvc coating. The most common coloured coating I have seen is orange/red.
    MICC is fire resistant, so it is often used in the UK in commercial premises in fire alarm circuits.
  16. The Following 2 Users say Thank You for This Post by wayne:
    Midnight's Avatar
    McHenry County, IL, USA
    242
    41
    Any pics?
    wayne's Avatar
    UK
    319
    117
    1. Cable shears
      By Amnelson in forum Tools and Equipment
      Last Post: 06-06-2012, 09:30 PM
    2. Coax cable
      By ozzy214 in forum Scrap Metal Tips and Advice
      Last Post: 10-24-2011, 09:17 PM
    3. RG59 Cable
      By Kalrith in forum Scrap Metal Questions and Answers
      Last Post: 09-22-2011, 09:48 AM
    4. data cable
      By kcscrapper in forum Scrap Metal Questions and Answers
      Last Post: 09-02-2011, 11:02 PM
    5. Steel cable
      By trapper in forum Scrap Metal Questions and Answers
      Last Post: 01-16-2011, 09:44 PM
