Results 1 to 18 of 18
What about LCD "screens"??
    metal gypsy started this thread.
    metal gypsy's Avatar
    Gulf Coast
    73
    108
    Hopefully Easy Recycle will respond as well.....I have desk-top computer screens as well as 40" and larger LCD screens.....any value?? They are the black or tinted part is what I'm asking about. The desktop ones also come with a thick piece of plexi-glass with the white dots on it.....does the plexi go for more than say ABS or PPS??? I have a stack of the black screen part, with the "flaps that plug into the circuit board strip.
    Dallas TX
    1,979
    158
    I will need to see photos...but its best to keep them whole an sell them whole...9 times out of 10 they can be repaired and or parted out an be worth more than scrap.
    Wow I have not done LCDs in years!
    Oh wait what? **** got the letters all mixed up again.
    Forget that, must have had a flashback there...
  4. The Following 3 Users say Thank You for This Post by injunjoe:
    Dallas TX
    1,979
    158
    lol
    LCD = Flat light weight an very easy to move around.
    CRT = you take a look...pull your pants up then pick it up.
  6. The Following 2 Users say Thank You for This Post by easyrecycle:
    94
    hahahahah i thought you meant lsd
  8. The Following User Says Thank You to dryvr12 for This Post:
    Quote Originally Posted by dryvr12 View Post
    What? LOL
    Glad someone got it!
    Gulf Coast
    73
    108
    Here we go.... now that I know how to do pics. After the flat screen is broken down (lcd) here's whats left the 2 circuit boards, a piece of acrylic? with dot matrix on it-1/4 inch thick, and the "black screen" that plugs into the circuit strips. The black piece has thin glass in the center. I didnt show the paper thin plastic sheets
    that are luminous like?(3). Anyone recycling these??
    CLR Solutions's Avatar
    Randolph, NJ
    160
    Quote Originally Posted by metal gypsy View Post
    The LCD pictured appears to be out of a laptop? I buy the complete desktop LCD but have not found an outlet for just the LCD yet unless it works and I know of someone who needs the part. The boards attached to the monitor with the gold plating are motherboard grade and pay the same. For buyers like me and easy alike it is generally better for the seller to leave the LCD monitor intact as you will get more for it that way than on the weight of those few boards attached to the LCD panel itself.
    http://www.clrsolutionsnj.com
    recycle@clrsolutionsnj.com
    877-CLR-SOLU
    CLR Solutions is Your Partner in Secure Data Management and IT Asset Disposition
    Gulf Coast
    73
    108
    Thanks CLR, and that is from a desk-top flat screen monitor. The weight sure would run up quick on these, even without the stand. I usually get 3-4 per week
    and most aren't worth the fix.......
    Kingsley, MI
    91
    41
    Quote Originally Posted by CLR Solutions View Post
    Are you saying I should just leave the monitor all together, or should I take the plastic bezel off as well as the base.
    pcscrapper's Avatar
    623 s Lyon st Suite 200 Sioux Falls SD 57104
    657
    576
    You could get up to about 8.00 per screeen, most people that buy them would want no scratches on them. if they do.. have scratches on them, they won't take em. You'll probably be charge a fee.. for them.
    So, best to take apart the bad lcd and keep the good one.
    One things for sure.. some of the LCD have mercury in them, be sure to be careful not to break them.
    along that there are plastic, and metal, save it, they are worth a penny here and there, and the VGA Cable and the monitor connector back board..
    If You've any question please feel free to contact Me.. thru pm.
    Mr G
    Please Add Us On FaceBook, PC SCRAPPER Sioux Falls SD
    also our Prices are listed here http://pcscrapperS.com
    PC Scrappers LLC
    623 S LYON ST SUUTE 200Sioux Falls, SD 57104
    1-605-271-2616
  15. The Following User Says Thank You to pcscrapper for This Post:
    florida
    96
    30
    Do those little tabs that are hanging on the screen contain gold? Ive always tried to pull them out so they are still connected to the board bc i thought they might add value to the board.. ??
    the plexi glass sheet comes in handy for all kinds of projects.
    billygoat's Avatar
    630
    99
    Quote Originally Posted by bnbsfsd View Post
    I sell the flat screen monitors whole to a friend of mine, who is a repair tech, for $10.00. He repairs or parts them out on the side and then tries to sell them for extra money. While it might not be big bucks, it allows me to flip them quickly and keeps me in touch with him to (hopefully) give me a possible lead somewhere down the line.
    ryanw's Avatar
    TX
    1,312
    526
    Are you saying $8 per removed screen, or the unit as a whole? Just asking because of ease of shipping.
    Mr G
    NobleMetalWorks's Avatar
    East Bay California
    687
    301
    The screens have rare earth minerals associated with them.
    I have been looking into how viable it might be to refine rare earth minerals, and may take a stab at it in the next year or two. I know of a few other people interested in the same sideline. As rare earth minerals become more and more difficult to source, the value of this type of scrap will only increase. It's like money in the bank if you have the space to store them until people start to refine rare earth minerals.
    I believe in the future a considerable amount of rare earth minerals that are used in industry are going to come from recycle sources. If you took silver as an example, 40% of all the silver used in manufacturing in the United States comes from recycled material. If not for recycled silver, the industry that relies on silver in the United States would come to a grinding halt.
    Scott
  20. #16
    ryanw's Avatar
    TX
    1,312
    526
    I'm sure if you or someone else develops a way to make this recovery profitable, there will be an endless supply of material. There was one company that posted on here that they buy lcd screens, but after contacting him, I was told that they only charge for them..intact or not.
  21. #17
    pcscrapper's Avatar
    657
    576
    They would have to be whole, NO SCRATCHES
    But the real question is finding someone that is willing to take em.
    Quote Originally Posted by rawresale View Post
  22. The Following User Says Thank You to pcscrapper for This Post:
  23. #18
    5,728
    6,814
    well! scratch that then ; )
  24. The Following 2 Users say Thank You for This Post by Bear:
    1. Non-Functioning LCD screens
      By technologyrecycling in forum General Electronics Recycling
      Last Post: 04-29-2014, 04:01 AM
    2. LCD "number" readouts
      By DrJamesDaddy in forum General Electronics Recycling
      Last Post: 11-30-2012, 01:12 PM
    3. how not to sell lcd screens
      By jghilino in forum General Electronics Recycling
      Last Post: 11-26-2012, 04:51 PM
    4. Replacement LCD screens
      By parrothead in forum General Electronics Recycling
      Last Post: 08-03-2012, 11:06 AM
    5. Replies: 3
      Last Post: 06-27-2012, 10:00 PM
