Results 1 to 7 of 7
Making an honest dollar.
    alloy2 is offline Metal Recycling Entrepreneur
    alloy2 started this thread.
    Apr 2015
    2,265
    638
    Gold is a soft metal easily worn free by abrasion in a tumbler, the brown powder along with some copper that also found its way into the mix.
    The copper gold mix in the flower pot, copper is removed via a DC electric current, copper is plated onto the copper sheet. after a couple of days the copper is nearly completely removed, the electrolyte now saturated with the brown gold powder. The remaining copper chemically removed.
    I now have 65 grams of gold powder to further refine,
  2. The Following 2 Users say Thank You for This Post by alloy2:
    Apr 2015
    2,265
    638
    Another day another dollar.
    If the visitors have nothing to say, neither do I
    mike1 is offline Metal Recycling Entrepreneur
    mike1's Avatar
    Rochester indiana
    685
    371
    Um gross.so how many of those grams do you think will be gold in the end ? What purity do you get from that I wonder also how much money do you spend on such a process is it costly?.
    hills is offline Metal Recycling Entrepreneur
    hills's Avatar
    Sep 2017
    1,620
    841
    It's amazing how resourceful people can be. Some folks don't have much but they make the most of what they do have to work with.
    Apr 2015
    2,265
    638
    Same idea, use a box to catch the small bits, no heat - de-populate with a roofers hatchet.
    Pons and fingered ram in a tumbler abrade the gold off, by pulling the pins like he did in the video He's getting a tad more gold over the method I use as the solder acts as a collector.
    My method is faster, no nitric acid used at all, just a bit if cyanideand a dash of peroxide, the gold is plated onto steel wool then dissolved in dilute sulphuric acid leaving the gold behind.
    The flower pot, a fellow gave me all his waste solutions, I cemented everything down as metals using scrap iron which were primarily copper. The copper sponge went into the unglazed flower pot. With electrolysis plated the copper over to the copper sheet leaving the gold behind in the flower pot.
    The brown liquid is super saturated with gold, filtered over to the Vision ware pot waiting for further refining.
    [IMG] [/IMG]
    hills's Avatar
    Sep 2017
    1,620
    841
    I was just playing around awhile back and experimented with depopulating the boards. Had an old 4" planer / jointer that wasn't being used anymore and tinkered with planing the back side of the boards. That seemed to work pretty well.
    If you can imagine .... anything that poked through the board and was soldered on the back .... was effectively de-soldered. A few taps on the board and everything falls out.
    I was thinking that a milling machine would give you real good accuracy for board shaving purposes.
    When you think about it .... just about everything on the board has value. Even the copper foil laminate traces would add up some weight pretty quick.There's value in the solder and there must be a fair amount of nickel too. It might be that the best money would be in the base metals and PM's the frosting on the cake. I've heard a figure of $ 20,000.00 / ton of recovered metals from circuit boards going to refiners that have a really good process.
    Apr 2015
    2,265
    638
    Latest addition to my lab ware, Kipp's Apparatus.
    The Super Bong.
  9. The Following User Says Thank You to alloy2 for This Post:
    1. Air Conditioners What's an Honest Man to Do?
      By ocedy in forum A Day in the Life of a Scrapper
      Last Post: 03-31-2016, 10:23 PM
    2. Money making tip for Ebay sellers by making steampunk lamps
      By copycat in forum Scrap Metal Tips and Advice
      Last Post: 03-11-2015, 12:41 PM
    3. Money making tip for Ebay sellers by making woodstove ecofans
      Last Post: 02-28-2015, 08:40 AM
    4. Need honest advise
      By Gberic32 in forum Introduce yourself
      Last Post: 10-20-2014, 10:18 AM
    5. How honest is your yard?
      By Scrap man in forum General - Let's talk business
      Last Post: 07-09-2011, 01:58 PM
