Results 1 to 14 of 14
value of a clothes dryer
Hybrid View
    708bigbuck started this thread.
    708bigbuck's Avatar
    53
    What is a clothes dryer worth at the scrap yard? I'm guessing proably $2-3.
    Andrew's Avatar
    Jul 2010
    61
    89
    Re: clothes dryer
    Well light iron around here is worth 195 a ton so your looking at around $8-$10 for every 100lbs
    wayne1956's Avatar
    Cleburne, TX
    704
    195
    Re: clothes dryer
    This may sound trivial, but when scrapping a dryer I have found that it can be worth the effort to remove the back and see if anything has fallen to the bottom. I got a dryer recently that had a bunch of change caught in the fan that sucks the air through the rear vent. When it was all said and done, I had retrieved just short of $19 in change and also a broken heavy 20" sterling silver chain. I have heard of folks finding small gold rings, but I have yet to find any gold myself. I will shake a dryer, and if I hear anything loose in the bottom I will see what it is. Also, do not forget to remove the wiring harness, as the insulated copper is worth a lot more than what you are getting for the steel price. I have about 50# of insulated copper hoarded right now waiting for prices to go up.
  4. The Following 5 Users say Thank You for This Post by wayne1956:
    scalemomma is offline Metal Recycling Entrepreneur
    Jun 2013
    Southern MD
    33
    47
    Quote Originally Posted by wayne1956 View Post
    Excellent! Never thought of a dryer as holding hidden treasure.....now I know! Thanks!
    1LooseCannon's Avatar
    Feb 2015
    Washington State
    18
    55
    I opened up my 1st one last week and was surprised to find $1.40. Now after reading this thread I'll be opening them all.
  7. The Following User Says Thank You to 1LooseCannon for This Post:
    Toronto, Ontario, Canada
    Wayne1956 I never let a dryer leave my truck until I have smashed it apart. Over the years I have found thousands in dryer's not to mention other things like Jewelery. In fact thats the only reason I take dryers. They are too light for the amount of space they require. Like the new fridges. They weigh almost nothing and take up a lot of space.
  9. The Following 2 Users say Thank You for This Post by jjk:
    165
    23
    I completely agree with the drier thing! It always makes me happy for me to pick one up. Picking up a drier is a bit like picking up a lotto scratch ticket in my mind, except you dont have to pay for it.
  11. The Following 2 Users say Thank You for This Post by TheMetalizer:
    Oct 2010
    I never pass up a dryer, I am out there looking so why not pick them up. That is just more money in my pocket. I do take the cord off and also take the back off to look for treasure.
  13. The Following User Says Thank You to Ky lady scrapers for This Post:
    SuperDave is offline Metal Recycling Entrepreneur
    SuperDave's Avatar
    May 2012
    Usa
    448
    526
    what about the electric motor? I like taking those apart.I take all the copper then the casing is sometimes cast alum. or the older ones cast iron.
    Even if you don't take it apart you can get paid for electric motors.
  15. The Following User Says Thank You to SuperDave for This Post:
    2,863
    349
    Don't foreget the heating element they nichrome worth 2.00lbs at the yard I use. Pull the motor and check the windings sometimes it's aluminum. The front panel behined the nobbs is aluminum unless it's an old one. Always check for change, I found 22.00 in one. If broken down right should be worth 8-10$
    WMSTR is offline Metal Recycling Entrepreneur
    Mn
    131
    80
    My Yard pays $6.00 per dryer so I take the back off hit the motor out cut the #2 ins out. And then if its a gas I pull the brass fiting off. Then I take off all the others metals so I can to make the dryer as light as I can. Screw the back on and your good to go!
    God is great, scrap is good, and people are crazy
    Its better to be scrapping and thinking of God than sitting in church thinking of scrapping
    4,761
    6,023
    So if it weighs 100 lbs you are getting .06 a pound for it, 150 lbs and it's .04 a pound...
    ParkerFlyer4's Avatar
    north west
    407
    423
    ...and maybe you'll find the match to one of your old pair of socks!
  20. #14
    wadarbr549 is offline Metal Recycling Entrepreneur
    wadarbr549's Avatar
    May 2013
    southern ohio
    413
    175
    i found a class ring once that was solid gold ,and lots of change over the years.ive done really well pulling the back seats out of cars and also in the trunks of cars over the years
