Results 1 to 11 of 11
Rebuilding a 75HP motor
| Off Topic Discussions
    406Refining is offline Metal Recycling Entrepreneur
    406Refining started this thread.
    406Refining's Avatar
    Apr 2017
    Billings, MT
    253
    316
    Hey everyone,
    Hope you're all keeping busy with your scrap ventures. I recently bought a 75hp electric motor from a farmer that was cleaning out their field. Since I currently have the highest prices on scrap electric motors in town ($0.10/lb) I usually get a few calls every once in a while for big motors. Anyhow, I figured it would be interesting to document what it takes to have one of these units refurbished for selling. I know scrapping them could bring in a good amount of copper, but if a motor this size can sell for a few thousand dollars it may be worth selling vs. scrapping.
    The pictures don't do justice to the size of this motor, but it's about 18" in diameter and about 3-4 feet long.
    The first thing I did was make sure it spins freely and inspected the wiring:
    I removed the back fan guard to remove all of the loose dirt/sand that was sitting in the bottom of it. Since it was sitting out in field there's quite a bit of it.
    I've also cleaned the wiring area out of the random junk and wasp nests in there. The good news is that this unit passed the motor winding resistance test (not burned out) so we'll see what the rebuild shop says tomorrow about going through it to prep it for selling.
    Current Investment: $120
  2. The Following 8 Users say Thank You for This Post by 406Refining:
    t00nces2's Avatar
    Jul 2014
    Sarasota, FL
    1,710
    1,187
    Quote Originally Posted by 406Refining View Post
    Hey everyone,
    Wow! 75HP? That's a bigg'un. I used to work on 5HP circulation pump motors that looked physically about that size.
  4. The Following User Says Thank You to t00nces2 for This Post:
    WhiteSquirrel's Avatar
    May 2020
    Ontario, Canada
    102
    17
    Looking forward to seeing this progress!
  6. The Following User Says Thank You to WhiteSquirrel for This Post:
    matador's Avatar
    Nov 2013
    Big Wonderful Wyoming
    2,309
    1,782
    I didn't know they made them that large. Whelp, guess I'm not bringing you that trailer for awhile now
  8. The Following User Says Thank You to matador for This Post:
    Jun 2017
    Las Vegas
    1,321
    3,210
    Great project! Looking forward to following your progress!
  10. The Following 2 Users say Thank You for This Post by JJinLV:
  11. #6
    hills is offline Metal Recycling Entrepreneur
    hills's Avatar
    Sep 2017
    1,629
    842
    Interesting project. Looking forward to seeing the progress as well.
    Looks like you've got a couple of high volume water pumps there too. ( The red things) They're pretty durable. It's been close to 20 years since i've worked on one of those, but of memory serves, the shaft seals have to be repacked every so often. (Not expensive or hard to do.) I'm thinking the impellers inside would be fairly good size and made of brass. Might be worth it to crack one open if they're just going to scrap.
  12. The Following User Says Thank You to hills for This Post:
  13. #7
    Apr 2017
    Billings, MT
    253
    316
    Those are some high volume pumps sitting there! I got 5x of those pumps and 5x 15hp motors at an auction in Cody, WY for $50 each. I was hoping to salvage the complete assemblies with frames, but the frames had cement poured in the middle. They had to be disconnected from everything which was kind of a pain, but I walked away with a good deal and about 80 pounds of #2 ins. from the motors. I'm still unsure what I'm going to do with those pump assemblies. On one end I could see scrapping them to get them out of the way, and on the other end I could selling them for $50 each (they have quite a bit of rust around the flanges). I haven't tried popping one open, but the props are either brass or stainless. I'll get one of them cracked open later today and post some pics.
    The motors are a completely different situation. Since 4 out of 5 of the motors are identical I could see holding onto them to build a mega quad axle shredder which would make disassembly of ewaste a quick task. The real question is do I really really need a shredder that big. I mean just because you can do something that big doesn't mean you should. It would be cool, but we'll have to see If I end up selling them I could see each one going for $300-$400 each. They'll probably sit on the shelf for another few months before they finally get listed.
  14. #8
    Apr 2017
    Billings, MT
    253
    316
    I finally got a chance to put the motor on the scale and see it's real weight. It came in at 765 pounds. Not as big as I thought, but not a small one either. I dropped it off at the rebuild shop yesterday and The rebuild shop just tested it and the unit runs! They're going to clean it, replace the bearings (they are slightly worn out), and repaint the unit for $400. They also have a buyer for the unit already! I have to negotiate out the details on the shipping (buyer is in Idaho), but I would call this experiment a success so far.
    Current investment: $520
  15. The Following 4 Users say Thank You for This Post by 406Refining:
  16. #9
    May 2020
    Ontario, Canada
    102
    17
    That's awesome! Love it when a plan comes together like that!
  17. #10
    matador's Avatar
    Nov 2013
    2,309
    1,782
    Glad to hear that it worked out! Hopefully you end up making a nice chunk of change on that motor. So nice to see it getting some use instead of being scrapped, and glad to see that there's now room in your warehouse. I'm on it- I'll take care of that empty space :P
  18. #11
    Apr 2017
    Billings, MT
    253
    316
    The finished product:
    Tomorrow I call the prospective buyer and get a deal worked out for the motor!
  19. The Following User Says Thank You to 406Refining for This Post:
    1. Synthetic motor oil
      By Otto in forum Off Topic Discussions
      Last Post: 10-14-2015, 06:56 PM
    2. selling used motor oil?
      By HeavyMetalScrap201 in forum General - Let's talk business
      Last Post: 09-14-2014, 06:15 PM
    3. Electric motor
      By Mick in forum A Day in the Life of a Scrapper
      Last Post: 10-27-2012, 03:06 PM
    4. Our first big motor
      By BandB in forum A Day in the Life of a Scrapper
      Last Post: 06-10-2012, 12:32 AM
    5. Outboard Motor
      By injunjoe in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 11-29-2011, 06:39 AM
