I thought this might make a good forum help thread..
I am pretty cagey when it comes to being inventive and resourceful, so I thought I would share a hack I recently came up with to help protect my newly enclosed back porth from storm threat. Hurricane protection is epensive... Really phucking expensive!
I needed a way to protect my back porch from:
Wind and debris impact
Compromised window wind intrusion
Wanted as inexpensive as I could get for the highest protection value
Needed to store so I would not have to do the same work over and over
Did not want to fight with others purchasing supplies everyone wanted
This ruled out plywood for many reasons and ruled out standard hurricane protections offered by hurricane protection specialists and special hurricane protection materials. I walked through Home Depot looking for ideas and found what I thought would be the perfect solution for the problem. It was five channel galvanized roofing sheet metal roofing. It checked all the boxes. This was the problem and the finalized result...
This is the unprotected southern exposure of my porch...
Here is the protected area...
As you can see, the metal roofing screwed tight to the window and will keep debis from compromising the porch from wind intrusion. The panels are 2'x6' and stack and store easily. They are relatively lightweight and can now be installed in probably 30 to 60 minutes. The only downside is the sharp edges one must take care when handling. I have three roughly 6x6 window areas I covered for $180 using the 12 foot panels and cutting them down to fit the window areas. I used self tapping screws to anchor the panels over the windows and I put the screws back into the holes to cover them and be available when the need arises. It to me and my father in law a couple hours to do the work and stow the panels.
I hope this may help others mitigate hurricane preps.
West wall unprotected...
Protected...
