Well jsut this week it would havbe been possible to get about 110 gallons of 8 month old gas (they say it is bad, though I don't know if that is correct) and probably 4-8 55 gal drums of either used motor oil or waste vegetable oil. These often come in steel drums or in plastic (blue plastic) drums.
Now I wish I had a multi fuel engine like in the old duece & 1/2's that could burn everything down to pine needles (well almost). Then I could build a genny to run off this engine that can burn any of the fuels I've seen.
I'm trying to find out if any of you know of other good uses for large amounts of oil like this. I would guess I could probably find 200-800 gallons per month of heavy fuels or oils but I need to find a way to make this worth getting even if it means building or buying a furnace/burner.
For those who don't know, and this is really awesome, you can actually make a freezer, air conditioner, refrigerator and other cooling appliances by using the heat from the oil(s) through a known reaction process (been around for about 120-150 years) and is EXTREMELY simple and most units don't have any moving parts or some very minor parts.
I guess it could be used to cool some large buildings in the summer and heat in the winter.
anyone have any suggestion for what could be done with this?
