I got this pressure washer any advice how to scrape it to get the most out of it
does it work at all? Even just low pressure?
If it works, sell it as is.
If it doesn't, then remove/disassemble the pump as most of it should be brass.
If the motor runs, sell it. If not and you're inclined to do so, tear it down for the aluminum. The carb might have a bit of brass in it.
The frame would probably go as light iron/tin.
If the hose/wand is still usable, sell that on Craigslist.
I Third That
Might just be an electric washer???The carb might have a bit of brass in it.
And what if it's a Steam Jenny or a Hotsy; a hot water high pressure washer? What are the coils inside made of?
