Results 1 to 20 of 21
Boat motors
| Vehicle Recycling
    Mick started this thread.
    Boat motors
    I got about 8-900 lbs of boat motor parts yesterday from a regular of a couple years. There are several 2-cylinder blocks. Looks like the only iron is a little pin that is easily cut off and the piston sleeves. Any tips on getting those sleeves out or just cut them with a sawzall? In the past, I've taken them as Irony-aluminum, but the way things are going, I'm maximizing what I get - within reason.
  2. The Following User Says Thank You to Mick for This Post:
    Mick, Those sleeves are usually pressed in I think. Don't know of a good way to heat the whole block to drive the sleeve out, just wouldn't be feasible.
    Thanks. I know they're tighter than sh--. What if I cut them from inside on two sides? Irony aluminum is 0.20/lb and extrusion is 0.70/lb. Just seems a waste to lose .50/lb over two sleeves.
  5. The Following User Says Thank You to Mick for This Post:
    c4f5's Avatar
    northeast CO
    387
    112
    With a BFH
  7. The Following User Says Thank You to c4f5 for This Post:
    Quote Originally Posted by c4f5 View Post
    With a BFH
    Like this one? Weighs 40 pounds.
    http://s1209.photobucket.com/albums/...ent=510014.jpg
    Dallas TX
    1,979
    158
    cutting torch with a smallish tip. No need to melt the whole block just a small cut.
  10. The Following User Says Thank You to easyrecycle for This Post:
    I've tried breaking the block with a sledge. No go.
    I read somewhere about using a welder to run a few beads inside to shrink the sleeve and pull it. Haven't tried it yet.
    Have wondered how hard it would be to cut through it with a band saw, then pop the sleeve loose.
    Cutting torch seems easiest as suggested by easyrecycle.
    If heating the entire block would get it out, then I would think putting it in an old oven would work? Unless it needs to be hotter than that.
    Oct 2010
    234
    71
    Can you take those blocks in as part of a larger load of cleaned aluminum, so that even with the sleeves still in, your contamination for the entire load is still under the 5% or 10% or whatever your yard allows before it is considered contaminated? I'm able to do that here when some material is just way too much of a hassle to clean, with specifically sleeves being one of the items I won't remove.
  13. The Following User Says Thank You to zito for This Post:
    There's just too many for that to work. Got another load today. I didn't even get the first load looked clear through, but counted at least 12 blocks without even going through the tubs. Now, today I got more but didn't even start to count the blocks.
    Here's a couple pictures of the first load:
    http://s1209.photobucket.com/albums/...tmotors001.jpg
    http://s1209.photobucket.com/albums/...tmotors003.jpg
    And the load from today:
    http://s1209.photobucket.com/albums/...5-22-11001.jpg
    http://s1209.photobucket.com/albums/...5-22-11002.jpg
  15. The Following User Says Thank You to Mick for This Post:
    nice loads, Mick.
    26
    Mick,
    Found this thread while researching my marine repair source and am wondering if you ever found an effective way of removing these sleeves.
    Also a poster above mentions yards allowing 5-10% contamination before declaring "dirty" aluminum. The yard I'm using is only allowing 2% (and that is based on an instant judgment call made at weigh-in). I am wondering if there shouldn't be more of an industry standard that would apply.
    Quote Originally Posted by vijunk View Post
    Mick,
    No. I'm just holding onto them for now to see if I come up with something.
  19. The Following User Says Thank You to Mick for This Post:
  20. #13
    Dallas TX
    1,979
    158
    Just looked at the photos...some of the lower units look to be in good shape. I would sand blast them an see if any repairs where made to them. If not an they are in good shake even after paint is removed. The take GOOD photos an find the S/N an list them on ebay. People who are repair there motor for there boat an do not want to buy a whole new top or lower unit would be happy to buy your top or lower unit for a rebuild. I have seen some of them sell for as much as 400 to 800 each.
    Lower units sell faster...people who are boating an hit the lower unit need to replace it because the top unit is fine..the lower unit was damaged...they are your high bidders as they dont want to buy a whole new unit...
  21. The Following User Says Thank You to easyrecycle for This Post:
  22. #14
    I wished I thought of sooner, I had the same thing.
    Put on the safety glasses and use the Hydraulic Log Splitter
  23. #15
    elkton,md
    1,062
    8,524
    Hey mick, just wondering about any progress on boat motors.
    Have an opportunity for steady supply.
  24. #16
    diggydiggy's Avatar
    Jul 2014
    Columbus, Ohio
    50
    26
    Hey Mick, if you have a good relationship with your yard, sometimes they will meet you in the middle so to speak. Ask for .50 and then take the .45 thats offered.
  25. #17
    Hey guys just a heads up...Mick is Recycling with the Good Lord now.
  26. The Following 3 Users say Thank You for This Post by KzScrapper:
  27. #18
    Quote Originally Posted by KzScrapper View Post
    In case anyone missed it;
    http://www.scrapmetalforum.com/scrap...ick-smith.html
  28. The Following 3 Users say Thank You for This Post by Mechanic688:
  29. #19
    elkton,md
    1,062
    8,524
    Yeah. I realized that after I posted. There are still ways he can answer. I sure that the good Lord will guide me, per Mick's instructions. May he rest in peace.
  30. The Following 2 Users say Thank You for This Post by junkfreak:
  31. #20
    bcrepurposing's Avatar
    Northern Central MN
    152
    Boat motors
    it is possible to grind the sleeves out or shave them out by honing / boring. talk to a machine shop and see what they would take to do it. since they arent trying to make them usable it may be much cheaper.
    you can make a home made press from heavy steel and a bottle jack that would apply enough pressure to push sleeves out if you can access them. last one i made was strong enough to fold 3/4" iron plate in half using homemade dies.
    have you tried using a weed burner? for car size sleeves you can modify a cutting torch set up using fittings to accept a piece of pipe that can function simularly. probably need oxy / acceteline for enough heat. just lp may not produce enough heat on weedburner. make stand to hold it pointing in cylinder but slightly abovr so it doesnt snuff and do something else for 15-20 minutes.
    "Reuse, Repurpose, Recycle..." - BC Repurposing Motto
    www.bcrepurposing.weebly.com
    https://www.facebook.com/bc.repurposing
    1. This thread has a tip for you - Don't pass up that junk boat ---- take it with you
      By scrapGAME in forum More than Scrap Value
      Last Post: 12-10-2012, 07:32 AM
    2. Burned Boat
      By street_sweeper in forum A Day in the Life of a Scrapper
      Last Post: 05-08-2012, 01:29 AM
    3. I think I'm going to need a bigger Boat...Er I mean Truck!
      By thortek in forum General Electronics Recycling
      Last Post: 04-05-2012, 03:27 PM
    4. Free boat 18'
      By WMSTR in forum General - Let's talk business
      Last Post: 03-07-2012, 07:04 AM
    5. I need a boat to go to the scrap yard!!
      By metalworks55 in forum A Day in the Life of a Scrapper
      Last Post: 09-15-2011, 07:54 AM
