I am cleaning up some junk in my yard I have been collecting. I was going to truck it to the local scrap yard and try to get a few bucks for it. not sure how best to go about this.
I have an old snowmobile, three riding lawn mowers, few bike frames, some of them aluminum. An old fiberglass boat with an aluminum and cast iron inboard engine and lots of aluminum on it, also lots of stainless on it, aluminum fuel tank, aluminum outdrive, etc. Old motorcycle parts, whatever. All stuff I collected to "fix up" and none of it panned out.
When I called to talk to the guy at the scrap yard he said bring it the way it is and it will be "light iron" At first I thought he said $89 a ton, but then he went on talking and said something like "Just bring it the way it is and for every two thousand pounds you will get $189" Like he had to explain what a ton was. Maybe I mis-heard him and he said $189 the first time. Don't know, gotta call back and find out. Which price makes more sense?
My ? is, can I make more by putting some time into separating metals. If I break down the mowers and pull off the aluminum engine parts. rubber tires, etc is it even worth the effort? Are stainless boat rails worth separate than at the bottom of a pile of mixed metal? Should I just lug it in and maybe make $200 or can I double that by putting in a days work. I am not looking to dissasemble 100 mowers as a business and save the parts 'til I have the copper windings from 100 starters. I just want to not get screwed because I was lazy and took the "light iron" price. Should I bring the easy aluminum separate? Not sure how to proceed.
