Results 1 to 8 of 8
black cast help
| Scrap Metal Identification
    cummins started this thread.
    cummins's Avatar
    ontario
    573
    black cast help
    Can any one help me with the difference between black cast and regular cast iron. Noticed black cast was at 1.70 a pound. Might have a concetion to buy a couple completely striped cracked cat blocks. They've even been through the Sault tank and are clean.
    Haven't had much luck on Google mostly pots and pan and maker markings haven't found anything about engine blocks yet. Thanks for the help
    Apr 2015
    2,076
    616
    Quote Originally Posted by cummins View Post
    No way your getting $1.70 lb for black cast, think you may have meant $1.75 per hundred weight, $35.00 short ton.
    Black cast would be soil pipe aka sewer, stove cast and probably include bath tubs and sinks and hot water radiators.
  3. The Following User Says Thank You to alloy2 for This Post:
    cummins's Avatar
    ontario
    573
    I took a load of hms 1 in Friday had a look at the price sheet while I was waiting for my paper work. 160 ton. Asked about striped engine blocks from cat and she said some of the high out put blocks are black cast and they would test them first. News to me. Figured I ask here. Grey and black cast are different . Trying to figure easy way to tell so I don't buy and lose money.
  5. The Following User Says Thank You to cummins for This Post:
    cummins's Avatar
    ontario
    573
    170 a ton sorry
    Apr 2015
    2,076
    616
    Your yard probably used a hand held XRF to determine the alloy composition of any cast suspect of being high grade.
    What they're looking for is Chromium and Nickel or a combination.
    This type of cast at the foundry is worth in the neighbourhood of $800.00 ton and is used in high heat applications requiring abrasion resistance like large pumps used in the mining industry. Some English gasoline and diesel engine blocks had a high chromium content,
    Chevy small block with 010 cast into the blocks have a high nickel content.
    Some but not all diesel engine cylinder liners could be made from a chromium / cast iron alloy.
    There are methods of identifying a metals composition using acids which are considered non destructive.
    https://books.google.ca/books?id=jEv...alloys&f=false
    Abrasion resistant cast irons/
    Casting Material: Abrasion-Resistant Cast Iron 12% Cr : Sand Casting, Investment Casting and Die Casting in China
  8. The Following 8 Users say Thank You for This Post by alloy2:
    Apr 2015
    2,076
    616
    The skinny on GM engine blocks alloyed with nickel.
    Identify the block casting number, which you can find on the top of the bell-housing ridge (where the transmission connects). If you see a "++" after the casting number, then it's a high-nickel block.
    Remove the harmonic balancer and crankshaft pulley from the front of the crankshaft. Remove the water pump and timing cover from the front of the engine. Identify the block casting just above the crankshaft main journal.
    Note the numbers you see there. They indicate the block's nickel and tin content by volume. If you see an 010 and 020, the block has 10 percent tin and 20 percent nickel by volume.
    An 010 or 020 by itself indicates the block's nickel content as 10 or 20 percent, respectively.
    Read more : How to Identify a Small Block and a High Nickel Block on a Chevy | eHow the block casting number, which you can find on the top of the bell-housing ridge (where the transmission connects). If you see a "++" after the casting number, then it's a high-nickel block.
    Note the numbers you see there. They indicate the block's nickel and tin content by volume. If you see both an 010 and 020, the block has 10 percent tin and 20 percent nickel by volume. An 010 or 020 by itself indicates the block's nickel content as 10 or 20 percent, respectively.
  10. The Following 2 Users say Thank You for This Post by alloy2:
    Maple Ridge, BC, Canada
    254
    103
    ALL Chrysler/Dodge V8 engine blocks from 60's to mid-late 70's (at least) are also high nickel.
    Apr 2015
    2,076
    616
    Simple solution to problem just ask the yardman to see an inventory of their black cast then ask for or purchase a small sample to perform some acid testing on.
    Nitric acid is commonly used to identify metals, a small drop onto a filed clean surface free of oil will produce colors specific of those used in the alloyed metal. Adding a bit of heat will definitely speed up the chemical reaction.
    If your paranoid of using acids use a grinder for spark testing.
    Identifying metals for welders, good information for the scrapper.
    Lots of charts. Metal Composition: Analysis , Tests and Charts
    Metal Tests : How To Identify Metals For Welding : Maine Welding Company
    1. aluminum prices cast versus die cast
      By endmill in forum Scrap Metal Prices
      Last Post: 04-04-2014, 09:10 AM
    2. black friday
      By tsmith53149 in forum Off Topic Discussions
      Last Post: 11-24-2013, 03:36 PM
    3. Black walnut
      Last Post: 10-23-2011, 10:26 PM
    4. Harddrives.... Cast or Die Cast?
      By Recyclinggirlie in forum Scrap Metal Tips and Advice
      Last Post: 10-20-2011, 10:02 AM
    5. Old cast iron motosr and how to tell cast iron from steel ?
      By Ironhead in forum Misc. Metal Recycling
      Last Post: 06-13-2011, 07:05 AM
Tags for this Thread
