Results 1 to 13 of 13
oil changes
| Off Topic Discussions
    HT1 started this thread.
    HT1's Avatar
    Jan 2014
    NE Florida
    249
    24
    oil changes
    I did not want to hijack the synthetic oil change thread, but it brought up something I have found odd. I schedule all the maintenance on a large fleet of industrial equipment and it all calls for an oil change every 250 Hours which is 4 times a year if ran a good solid 8 hours a day.
    Now lets say I drive my car 50 MPH for 250 hours that is 12,500 miles of course the manufacturer recommends an oil change every 3000-5000 miles is my car engine such a P.O.S. compared to a forklift engine???
    V/r HT1
  2. The Following 3 Users say Thank You for This Post by HT1:
    matador's Avatar
    Nov 2013
    Big Wonderful Wyoming
    2,309
    1,782
    I'd assume it has to do with higher RPMs, and more starting and stopping. Our White 2-105 uses a Perkins diesel. When we're plowing (The hardest job on a tractor), we're running around 1600-1700 RPM, and it's pretty consistant. You throttle down at the ends to turn around, but that's about it. An "hour" is measured at the engine's rated speed (Our White's is 2300 RPM), so if you run it at half that speed (1150 RPM) for an hour, it only registers as 1/2 hour on the meter.
    My Audi cruises at 65MPH around 2600 RPM. I drive on the highway mostly, so I do 5000mi OCIs. But, in the cities, there is a lot more starting and stopping. 90% of my mileage is on the highway, so my car likely has it a little easier than one in the city that has varying RPMs, loads, and acceleration....
  4. The Following 2 Users say Thank You for This Post by matador:
    NatureRecycleFlorida's Avatar
    May 2015
    Florida
    171
    143
    most oil changes are factored with dirt use or other forign debris entering the engine from use so a forklift is not going to see the same abuse perhaps as a vehicle driving across a varied road surfaces .
    most car owners manuals tells if you see a lot of off road use change oil at this amount miles so on.
  6. The Following 4 Users say Thank You for This Post by NatureRecycleFlorida:
    Scrappah's Avatar
    1,056
    318
    This kinda goes along with NRF was saying:
    I was reading up on high performance air filters awhile back and one of the manufacturers was saying that the reason your oil gets dirty is because of what the air filter misses. Fine dust gets drawn into the motor through the inlet side of of the crankcase.
    Going with what HT1 pointed out: Think of all the eighteen wheelers running nearly 24/7 over the highways. There are two drivers in the truck with each driving a ten hour shift. At 55 mph they would probably be logging somewhere around 1,100 miles a day.
    Didn't want to create confusion in the synth oil thread but they go really long intervals between oil changes. Somewhere around 30 - 50 thousand miles ?
    Just guessing but most run Delvac synthetic. They have an oil bath air filter. They have auxiliary oil coolers and gallons of oil stored down in the base pan.
    Back in the day, my old Ford pickups used eight quarts for an eight cylinder oil change. Nowadays i buy my oil in a five quart jug. Seems like an oddball size but it's just enough for most oil changes now.
    Maybe that's part of the difference between heavy equipment and automobiles ?
  8. The Following 3 Users say Thank You for This Post by Scrappah:
    MattInTheHat's Avatar
    rock hill, sc
    1,464
    1,140
    oil changes
    I thought I remembered my buddy saying he got oil changed in tractor trailers roughly 12000 miles.
    I googled it and the average is 15000. depending on the engine some are more and some are less.
    roughly an oil change every 2.5-3 weeks for a solo cross country driver running 10 on 10 off
  10. The Following User Says Thank You to MattInTheHat for This Post:
  11. #6
    Scrappah's Avatar
    1,056
    318
    I've worked with a couple of guys that logged over a million miles when i was plowing snow. The story i got from them was different. Can't remember exactly what the oil change intervals were but they seemed awfully long at the time.
    This might help explain why:
    How often / How much? (Oil Change Question) | TruckersReport.com Trucking Forum | #1 CDL Truck Driver Message Board
  12. #7
    May 2015
    Florida
    171
    143
    1100 miles for an otr team they are lazy truck stop cowboys .
    I logged in average myself in a day non team at around a 1000 miles a day for one year only 7 days off.
  13. The Following User Says Thank You to NatureRecycleFlorida for This Post:
  14. #8
    Quote Originally Posted by NatureRecycleFlorida View Post
    How did you manage that if you were crossing DOT scales at the state lines??
    There used to be a guy at the local fair that had an older car that he swore had not had an oil change in years and he drove it to all the fairs in like a 3 or 4 state area. I can't remember the exact figures now or the name of the product he sold but it was an accessory oil filter with lines that mounted on the inside fender well (remember them) and the adapter for where the original filter screwed on. It used toilet tissue as the filter medium and you did not change the oil, you just took the cover off and removed the T.P. and put in a new full roll and top the oil off. That oil in that engine looked like new as there was no dirt at all in it. My dad bit on it and I do remember the Rambler he drove had about 40,000 miles on the same oil. If I had not seen it myself I would not have believed it.
  15. The Following User Says Thank You to Mechanic688 for This Post:
  16. #9
    HT1's Avatar
    Jan 2014
    NE Florida
    249
    24
    I said industrial equipment. maybe construction equipment would be better term, my equipment is in a dusty nightmare far worse off them my car.
    I can buy into the diesel engines are better because they generally run at one RPM all the time(balls out) so they can be optimized for that.
    but the guy under the tin foil hat thinks there is some built in breakage here, maybe the oil filters on our cars are poor, and the ones on our equipment are better... remember when those big american engines had HUGH oil filters,
    my foreign car has one the size of the one on my lawn tractor.
    I remember when I was in the Navy. Honda gave my unit an award for our maintenance program, we had a record number of hours on a Honda 135 over twice the expected life expectancy of the motor "2000 hours" we where laughing our ass off we had a couple of engines with 8000 hours! these where security boats they ran 24-7 mostly at idle. we ran them a week 168 hours give or take so every week the entire fleet was switched out so the maintenance could be done 150Hr oil change. Honda never really intended for 135 and 150 to be used anyway but recreationaly which would make 1000 hours a milestone.
  17. The Following User Says Thank You to HT1 for This Post:
  18. #10
    May 2015
    Florida
    171
    143
    yes set the cc at 70-75 for 11 hours with 2 5 minute breaks with the fuel range at 1000+ miles per fill up(two 150 ga tanks .
    no traffic mostly at 7pm-7am drives so no city traffic mostly open roads
  19. #11
    Texcan's Avatar
    Sep 2015
    17
    174
    About 25 years ago we toured the Fleetguard filter plant. They had a demonstration on air filtration for diesel engines which we were shown a bottle with 4 oz. of fine dust. We were told that is the amount of dust that would cause the rings to fail in the live of the engine, if it was poured in all at once or over thousands of hours it would cause the failure on the majority of engines.
    Not sure if it worked that way in the real world, but this was there lab results.
  20. #12
    Here is a little more info for my #8 post. Evidentally there is at least one company that has kept and refined the "toilet paper" oil filter idea.
    I stumbled across this and wanted to put it up in case there was any interest.
    Frantz Oil Filters Official Site
  21. The Following User Says Thank You to Mechanic688 for This Post:
  22. #13
    bigburtchino's Avatar
    California
    1,643
    4,369
    I'm not doubting that the "toilet paper" oil filter would work. I have a hard time keeping toilet paper stocked in my house. With those oil filters needing to be refilled with TP rolls too! Might not work out for me as my GF and teenage daughter use more TP then I, if my trucks start using TP too! There's going to be a problem on my end!
  23. The Following User Says Thank You to bigburtchino for This Post:
