Results 1 to 10 of 10
AMD Ceramic Pentium
    F350scrapper started this thread.
    F350scrapper's Avatar
    May 2014
    Minnesota
    156
    71
    AMD Ceramic Pentium
    Looking at a buyers list AMD Ceramic without cap is going for 27 a pound. I also found an AMD with cap on it today what is that classified as? Green Fiber?
    4,918
    15,581
    Is it a ceramic cpu? If it is ceramic then remove the very thin aluminum cap off. Also the ceramic ones are brown. I use a heavy knife and strike the back of the knife with a hammer. If its a green cpu with a thick cap on top then its classified as "green fiber with heat sink-pins. Mike
  3. The Following 4 Users say Thank You for This Post by miked:
    Abuilder is offline Metal Recycling Entrepreneur
    Abuilder's Avatar
    SE Wisconsin
    436
    226
    An AMD Ceramic without cap is going to look like this. Notice it's grey and rather thick.
    If it's brown or green with a cover(heat sink) it's a fiber.
    Not all fiber AMD chips have a heat sink. The ceramic chips have the AMD name in the ceramic like above. NOT a label.
  5. The Following User Says Thank You to Abuilder for This Post:
    May 2014
    Minnesota
    156
    71
    Yes that's one of them. I also have on like that with a cap on it just can't classify the cap one
    3,419
    Its probably an amd k6 with an aluminum cap. You can pop the cap off and put it with the othe amd chip for $27
  8. The Following 3 Users say Thank You for This Post by BRASSCATCHER:
    Abuilder's Avatar
    SE Wisconsin
    436
    226
    BC
    I almost forgot about those old K6 & K6-II socket 7's
  10. The Following User Says Thank You to Abuilder for This Post:
    Scrappah's Avatar
    1,056
    318
    I sent in an AMD ceramic with cap last week it seemed to go through okay at 27.00 $/lb.
    Was reading about removing the caps on the green fiber w/ pins to upgrade them in another thread. Thought i would give it a go just to see how it would work out and got mixed results. It was a little awkward but the Pentium p-4's seemed to separate okay. Ran into problems with the AMD equivalents. The caps seem to be soldered to the processor matrix so when i pulled the caps it damaged what was underneath. I'm not really sure how well that worked out. It might have devalued them.
  12. The Following User Says Thank You to Scrappah for This Post:
    Jul 2013
    Ohio
    162
    54
    AMD Ceramic Pentium
    both amd and Intel started to solder on around the same time. I think 05. anything before should pop off pretty easily.
  14. The Following User Says Thank You to foobar for This Post:
    3,419
    Little heat will pop them off
  16. The Following User Says Thank You to BRASSCATCHER for This Post:
  17. #10
    armygreywolf's Avatar
    Germantown, WI
    1,085
    193
    It's not solder it's some propietary epoxy and twenty minutes at 275 and they pretty much come right off.
  18. The Following 5 Users say Thank You for This Post by armygreywolf:
    1. Not 1. but 2!! Pentium Pro CPU's
      By mudlight2 in forum A Day in the Life of a Scrapper
      Last Post: 01-15-2015, 04:03 PM
    2. This thead is a question - Monolithic Ceramic vs. Multi-layer Ceramic?
      By PinkFloydEffect in forum General Electronics Recycling
      Last Post: 03-17-2014, 10:30 AM
    3. Pentium Pro's for $30 each?
      By Ecycle Atlanta in forum General Electronics Recycling
      Last Post: 03-12-2013, 08:45 AM
    4. Pentium pro
      By hammerdown in forum General Electronics Recycling
      Last Post: 01-21-2013, 06:27 AM
    5. Pentium Ceramic mmx??
      By mikeinreco in forum General Electronics Recycling
      Last Post: 04-17-2012, 07:56 PM
