Results 1 to 20 of 29
do you clean up lower quality tv yokes??
| Scrap Metal Tips and Advice
    DakotaRog started this thread.
    DakotaRog's Avatar
    Aug 2014
    1,611
    602
    I haven't scrapped a large number of tvs but enough to know that some are 'sweet" and give up their bounty nicely (Cu deguassing, larger yoke that is easy to come off and then is fairly easy to get clean). And some are "arggggggggggh" pains (Al degaussing, smaller yokes that have no set screws so they cann't get pulled off nice off of the tube, lots of glue or whatever the crud is on them). These poorer quality yokes, what do you do with them; try cleaning up or does your place just take them as they are and give you less money for them?
    My non-ferrous guy does have 3 levels of Cu and although I've never sold any #3 maybe these qualify? I should check it out by next time bringing one and see what they say. Maybe that's the end of the story. But if a guy does need to clean them up, try chiseling them off, throwing them in a fire, etc.?? Just seeking some advice. Thanks!
    Usually I grab that epoxy with my wire cutters and roll (twist) the cutters and it should pry most of it off the copper. The little tiny bits left my yard doesn't say anything about. Even the red and natural colored they threw together. All #2
  3. The Following 5 Users say Thank You for This Post by Mechanic688:
    saabsw's Avatar
    May 2012
    Pittsburgh
    59
    100
    I'm also wondering this. I have 2-3 pounds of copper in yokes that have glue and glass still stuck to them. I cant get myself to just sell them as is, and if I did do that I wouldn't know which pile to throw them in. I want to just take a hammer and beat the crap out of them, but I don't know if that will do it, also, I live in an apt. so I try to keep the hammering to a minimum.
    Out of the few hundred I have done, I don't think a one had any glass, maybe bits of epoxy and/or plastic, and no tape.
    Hammering might be the only fast way to clean them up.
  6. The Following User Says Thank You to Mechanic688 for This Post:
    goobieguy's Avatar
    Upstate NY
    57
    238
    Sometimes when I just whale on 'em with the hammer, the junk chips right off, other times it compacts more with the wire and is truly a nightmare. What works best for me is just what Mechanic described - grab the cutters and "roll" the epoxy away.
    Aug 2014
    Minnesota
    120
    136
    Roll it in a towel and smack it with a hammer a couple of times.
  9. The Following User Says Thank You to mnrecycler for This Post:
    I smashed them with a hammer in a metal tub, separated the steel and most of the glue and tape and turned in as #2.
    Now that Goodwill no longer takes TV's or monitors in my area I don't mess with them.
    msmoorad's Avatar
    Durban, South Africa
    690
    715
    Quote Originally Posted by saabsw View Post
    try to clean of as much glass as possible
    u or sumone else could get cut later on when ur taking it to the yard.
    as far as glue/epoxy- a little bit stuck on is OK
    elkton,md
    1,062
    8,524
    I do a lot of TV's. The yokes in your pic I put aside, when it gets cold out I leave them out side a few days. By then epoxy is brittle and I smash with a tamper. Very little effort is needed. Al degassing , my yard lest me put it in with # 2 ins. wire.
  13. The Following User Says Thank You to junkfreak for This Post:
    Rubber, shot filled hammer is much quieter and often times works as well as a regular hammer.
  15. The Following 7 Users say Thank You for This Post by KzScrapper:
  16. #11
    DevinThaScrapper's Avatar
    Nebraska
    588
    120
    I just pull it all out and throw in pile along with all the spooled copper from mother boards, tv yokes also. Whence I get a bucket full I smash it under a tarp and it will smash anything and everything off of it if you hit it right, chisels usually work good for tape and glue also. Good luck
  17. The Following User Says Thank You to DevinThaScrapper for This Post:
    4,977
    1,257
    clean it up the best you can IT IS SCRAP!!!!......It is going to be more than likely melted down and the impurities will be removed (I guess).........I clean mine to a reasonable standard and move on to the next one..........Remember we are dealing with scrap and the yards account for this in their pricing
  19. The Following 4 Users say Thank You for This Post by mikeinreco:
  20. #13
    1,878
    1,642
    Quote Originally Posted by junkfreak View Post
    Put it in the freezer. Then smash it with a hammer. The glue brakes off quite easy when frozen
  21. The Following 3 Users say Thank You for This Post by greytruck:
  22. #14
    DakotaRog's Avatar
    Aug 2014
    1,611
    602
    Thanks, I hadn't thought about the freezer and the glue although some have probably been around since last winter. I'll try that this weekend. Then again, if they take these messed up ones as #3 Cu, there's only 10 cents a pound difference between that and #2 (which most of my Cu is).
  23. #15
    6,123
    11,885
    Hammer...smash..repeat as necessary. Whether you freeze it or fresh out the tv carcass.
    Throw on some
    an get to smashing. For bonus points..yell "HULK SMASH!" while you do it, preferably while outside or around others. The reaction is priceless.
    Oh an use the towel, or an old table cloth, or even one of those plastic tarps if you have one that is no good anymore. Easier clean up, an yes..for the love of all cold beverages everywhere, PICK UP THE **** GLASS! Don't break glass an you won't have to worry about it.
    Have fun.
    Sirscrapalot - STOP! Hammertime..
  24. The Following User Says Thank You to Sirscrapalot for This Post:
  25. #16
    Soobthang's Avatar
    Everutt WA
    101
    107
    I'm currently cleaning up a bunch by soaking in gasoline, softens up the epoxy to where i can just scrape it off with little effort. I would usually use acetone but I don't have any right now and gas is way cheaper.
  26. #17
    Quote Originally Posted by Soobthang View Post
    Why go to the extra time, expense and mess...It's #2 and will never be #1.
  27. The Following 6 Users say Thank You for This Post by KzScrapper:
  28. #18
    Soobthang's Avatar
    Everutt WA
    101
    107
    Quote Originally Posted by KzScrapper View Post
    I get $2/lb for #2. Not a hassle for me, doesn't take much time at all aside from soaking but I have plenty of other things to do while it soaks.
  29. #19
    2,864
    350
    My first question is were do you get glass on the yoke? Why is everybody trying to clean all the epoxy off the copper? Your not going to up grade the copper and your taking weight off. The copper from yokes is #2 copper so put it the #2 bin. How hard is that?
  30. The Following 3 Users say Thank You for This Post by happyscraper:
  31. #20
    Especially when your only getting $2 a pound.
    1. Copper Yokes
      By DrJamesDaddy in forum Scrap Metal Questions and Answers
      Last Post: 09-29-2013, 07:18 AM
    2. Lower than Low-Grade?
      By MeyeLastRide in forum Low-Grade Electronics Recycling
      Last Post: 12-09-2012, 01:10 PM
    3. Hello from L.A. (Lower Alabama)
      By Sambocus in forum Introduce yourself
      Last Post: 05-22-2012, 04:23 PM
    4. TV yokes
      By Dugong in forum Scrap Metal Tips and Advice
      Last Post: 06-06-2011, 10:07 PM
    5. Lower Del scrapper
      By torchedmonkee in forum Introduce yourself
      Last Post: 11-01-2010, 12:26 AM
