Results 1 to 12 of 12
Uses for Transformers
Hybrid View
    Yunkman is offline Metal Recycling Entrepreneur
    Yunkman started this thread.
    Nebraska
    512
    520
    I have a pile of power supplies from computers. Has anyone attempted to reuse those in other applications? I'm thinking.......my bug zapper went south on me and I took it to an electrician who said the transformer is bad. The starter is okay and so are the light tubes.
    Has anyone tried using those transformers for other devices? (I like to tinker in my old age and haven't blown myself up yet)
    Alabama
    764
    1,062
    You have to look at the output voltage and whether it's ac or dc. I don't know what the bug zapper transformer output is, but the computer power supplies have 3.3, 5, and 12 volt DC outputs.
    The only thing I've actually used one for is powering a computer fan just to use as a fan and running up hard drives with the covers off to play with. One thing you do have to do is jumper two of the wires in the motherboard plug to make the power supply work. I believe these two are connected to the ON/OFF switch/button on the computer. On a Dell, they are the last two, black and grey I think. On some others there is a green wire with black next to it not necessarily in the last position. Jumper these and it should come on.
  3. The Following User Says Thank You to Pnutfarmer for This Post:
    2,529
    2,906
    I pulled a small bucketfull of the transformers from computer supplys apart yesterday.
    They were the yellow taped ones that are placed inside the powersupply box, not bolted in, just placed thete and only connected by the two wires.
    They were the average 60gms+ each.
    The iron core inside them is 'stacked' laminations, not the interlaced sort.
    Because of that I could break them in half using earmuffs (most important!) A hammer and cold chisel.
    I just placed them on the bench vise and put the cold chisel across both windings on top of the copper wire and bashed them.
    They break a bit, turned it over and did it again untill the ends seperate.
    Then I just pulled each end apart and pulled out the wire and wound it into a ball.
    I have another one to do, so I will get exact weights.
    The laminations tended to stay together. When they do that, I put them into a fridge compressor case and tack weld it shut.
    So I get heavy metal insize prices for it.
  5. The Following User Says Thank You to eesakiwi for This Post:
    spinroch's Avatar
    675
    1,981
    The small transformers go in the copper bearing bucket. Anything more than that and you are wasting your time and losing money.
    F1 Recycles
    www.f1recycles.com
  7. The Following 2 Users say Thank You for This Post by spinroch:
    Nebraska
    512
    520
    They've been taking up space in my old pickup for wayyyyyyyyy too long. Maybe cut off the wire and they're doomed for the scrap pile.
    I'll keep the chicken feeder and the Dr. Pepper bottle.
    Quote Originally Posted by Yunkman View Post
    I usually sell mine to my local yard, they buy them for same price as motors and transformers. .20 a lb now. Without the wire.
  10. The Following 2 Users say Thank You for This Post by Mechanic688:
    Nebraska
    512
    520
    Now why didn't I think of that. Of course.....they are copper wound motors. That would be .15 at my yard.
  12. The Following User Says Thank You to Yunkman for This Post:
    Alabama
    764
    1,062
    Dr Pepper bottle.....now THERE is something with lots of uses. You can store various liquids in it including water like the one in my shop fridge now. You can write the contents down on it with a sharpie so you don't drink the last three ounces of 2 cycle oil.
    I like to use them for markers in the peanut field. That yellow cap shines so you can see it from the sprayer when you get back from a refill. It always helps to fill it about a quarter full of sand to keep the wind from toppling it over.
    Also, fill half full of water, put your sprayer tips or brass filters in and shake vigorously to clean them up nice.
    Cut it in half and you have not only a sweet funnel, but a nice cup for holding virtually anything.
    The neck and cap make an easy way to tie them on your electric fence gate so you can see when it's shut.
    Bore a hole in the cap and use it as a sprinkle bottle.
    Fill with water and use to water your wife's African violets so you don't get water on the leaves and kill them (again).
    When you finally wear one out, there are low-cost replacements at many nearby stores for only $1.59 ea. Oh, and you can drink the original contents!!!
  14. The Following 4 Users say Thank You for This Post by Pnutfarmer:
    Jul 2014
    Eastern KY
    30
    Retro on here gave me a 110v to 12v inverter he made from an old computer setup. Ask him how to do it; I'm sure he'll oblige.
    He said the output was technically something like 11.58v (Close enough for government work), so it'd run a CB Radio, etc.
    Just tossing an idea out there.
  16. The Following 2 Users say Thank You for This Post by Sidewinder:
  17. #10
    Nebraska
    512
    520
    Quote Originally Posted by Pnutfarmer View Post
    Good ideas there, Pnut. I also might add that I once ran out of gas and then found a little gas in a popbottle, left the lid loose and turned it upside down in the carburetor. It dripped enough to get me the three miles to a gaspump. Might not work in a fuel injected vehicle today. The bad side, that Dr. Pepper is addicting. Been there / done that. Long live sweet tea; there's Tradewinds and Gold Peak and those bottles are MUCH stronger. I'm getting on the cooler kick myself and fill a few bottles with water to take along.
  18. The Following User Says Thank You to Yunkman for This Post:
  19. #11
    Alabama
    764
    1,062
    Cool gas trick. I'll file that one away for later use.
    On scrapping the power supplies, the yard near me buys them as dirty aluminum because of the heatsinks in them. It's less than electric motor price, but better than steel.
  20. #12
    What about all the copper wound coils and chokes and transformer?? You could always pull the heat sinks with a pair of pliers.
  21. The Following User Says Thank You to Mechanic688 for This Post:
