so i've been scrapping appliances and the guy is only paying $100/ton. my truck is a 88 ext cab long box and i use a trailer, but some how i can't seem to make it past 200 a load and i confronted the yard owner his scale is not zeroed out before i get on there. He cames if he starts the day and one of his trucks goes on the scale he maxes it out and it may have 1500lbs reading on the scale after the truck is off and he says it can't be clear cause it misses his day up. I told him thats bs.
Problem is his scale says my truck weights
1) 5280lb first load with a trailer after being emptied
2) 6000lb second load with no trailer after being emptied
3) 6500lb third load with trailer after being emptied
4) 7200lbs 4th load with trailer after being emptied
i am pissed off and confronting him did not work. What would you do?
next closest yard is 1 1/2hrs away and it took $40 gas 1 way and that was only 1550lbs in the truck
