Results 1 to 20 of 20
Cell Tower Amp Board
| Ebay Traders
    AuburnEwaste started this thread.
    AuburnEwaste's Avatar
    Metro Detroit
    773
    32
    Gold Plated Cell Tower Amp Circuit Board for Gold Precious Metal Recovery | eBay
    I was able to purchase a few of these as samples to see how they do on ebay. I have access to a bunch more if they sell. They are from cell phone tower amplifiers, not sure how thick the plating is on them.
    I have never done an auction style listing, I always do buy it now, so who knows. Any thoughts or suggestions welcomed.
    1 lb and 5 oz. will cost you 8.00 or 9.00 to ship so hope you figured that into your price. Otherwise you will be giving it away.
    If you have a few, I'd try one at an auction and see how high it goes. Right now you don't know the market price for it. Plus if you had multiple bidders you could do second chance offers to the other bidders. Might get a bidding war going.
    Metro Detroit
    773
    32
    I can ship this in a flat rate envelope for 4.95 anywhere in the U.S, I should be ok. I really do not know what to expect in terms of price, but if my calculations are correct these could be very profitable. I only paid for the Copper content so I do not have much into them. I do have it as an auction style listing to test the waters.
    sawmilleng's Avatar
    Central Kootenays, BC, Canada
    861
    713
    Does it make any sense to pull the board from the gold plated chunk of metal? And maybe even sell them separately? I'm assuming the metal is some sort of heat sink--(copper?) plated with gold. The board is probably a high grade telecom board, so you know what to expect for that.
    I'm thinking that there are experienced board buyers who can probably tell what to pay for the board but unless you separate the metal piece and give the dimensions of it people are guessing on how much gold plate is on the metal. Is it plated on all sides?
    Definitely board porn, though!!
    Jon.
    Metro Detroit
    773
    32
    The dimensions are given in the listing. I left the board on because it has a part number that can be looked up. If people know where it came from they can make a better guess of how thick the plating is. The Copper is completely plated on all sides.
    Jeremiah's Avatar
    Virginia
    437
    147
    It's an interesting piece. I'm going to forward the link. You say you can get more?
    Metro Detroit
    773
    32
    I can get about 50-60 of these if I want them. It did not sell and didn't get many bids. I still have it up as a buy it now.
    Jeremiah's Avatar
    Virginia
    437
    147
    My suggestion is to contact jghilino with this gold-plated board and see if you guys can work something out. With his contacts in mind, I would ask him to run an auction on it and see how it does. This would tell you approximately the market value of this board. After some people run some tests on it you may be able to increase the price.
    wavecrazed's Avatar
    219
    my buyer said you can trim the gold fingers on a telecom board
  10. #10
    HiTechMike's Avatar
    Mar 2014
    United States
    200
    167
    Were you ever able to find an outlet for these kind of gold plated boards?
  11. #11
    Metro Detroit
    773
    32
    I sold them on ebay. Most buyers want to pay you for the Copper and that that is about it.
  12. The Following User Says Thank You to AuburnEwaste for This Post:
  13. #12
    NobleMetalWorks's Avatar
    East Bay California
    687
    301
    Cell phone tower equipment is shielded, depending on the electronics it is protecting. It is usually the heaviest plating. Even at that, the actual value shouldn't be more than about 65 cents per sq inch. I process a lot of this type of material. The shielding used is sometimes copper with gold plating, silver alloy plating or other base metals. By cause gold wears easy, it is also almost always alloyed with other metals when plated so as to prevent excessive wear.
    When I am able, I will post the actual thickness with a link to a gold plating calculator so you might better understand the actual value.
    Also keep in mind that any chips, proms, eproms etc will also be of the highest quality. If any of this type of material is included with the boards you purchased, you may want to read the number off the top, or bottom of the chip and google it. Also checking eBay may show what individual chips might bring if you were to remove them and sell individually. I have pulled working proms, eproms etc, that brought up to $35 dollars each.
    Scott
  14. The Following 5 Users say Thank You for This Post by NobleMetalWorks:
    sledge's Avatar
    Central Indiana
    2,717
    4,534
    I agree with Noble.. There are some HARD CORE chip collectors out there.. You find something rare.. they eat it up like Sunday Supper!
  16. #14
    HiTechMike's Avatar
    Mar 2014
    United States
    200
    167
    Quote Originally Posted by NobleMetalWorks View Post
    Scott
    What are the real light silver boards composed of? Aluminum plated with something? I also have some real light brass looking gold plated board. I would guess aluminum because of the weight.
  17. #15
    HiTechMike's Avatar
    Mar 2014
    United States
    200
    167
    Here is what the scrap yards analyzer said of the board in the above picture:
  18. The Following User Says Thank You to HiTechMike for This Post:
  19. #16
    P and W and S?
  20. #17
    HiTechMike's Avatar
    Mar 2014
    United States
    200
    167
    P and W and S?
    Phosphorus, Tungsten, and Sulfur. I am assuming.
  21. The Following User Says Thank You to HiTechMike for This Post:
  22. #18
    HiTechMike's Avatar
    Mar 2014
    United States
    200
    167
    What is your take on no gold showing on the analyzer?
  23. The Following User Says Thank You to HiTechMike for This Post:
  24. #19
    etack's Avatar
    Buying Tantalum capacitors
    United States ohio
    503
    443
    I disagree with Noble. I have done quite a few cell tower gold plate items. Those plates are low grade with a real thin plating. The 3G systems that have been removed all had junk for plating the connectors.
    These are the plates I had. similar to yours.
    [IMG][/IMG]
    Sample #1 : 147.4g starting weight = 0.016 g Au ( 13 milligrams)
    Sample #2 : 217.6g starting weight = 0.025g Au (20 milligrams)
    These are the connectors that are also low grade.
    [IMG][/IMG]
    They have value but its not great.
    The Al/Au plated ones are better and will have similar yields but the platting is easier to remove.
    I love GP Al
    Eric
  25. #20
    East Bay California
    687
    301
    Quote Originally Posted by HiTechMike View Post
    Its an interesting alloy. Keep in mind that shielding is not only employed for frequency shielding. There is also electrical and heat. Considering this alloy, I would suggest that the copper is for heat and / or frequency shielding, the tungstun, phosphorous and sulphur for electrical and perhaps heat shielding.
    There are many different alloys, and many times it is difficult to understand why metals are alloyed in specific ways in specific percentages. Also consider that and XRF analysis only will report what metal is within a few atoms of the surface, unless a specific type of XRF analysis. This means in short that you are only reporting the top layer of metal, which means that their may me another metal or alloy under plating, or not. The only way to be sure is to score or break the metal and analize the internal metals as well.
    Gold shielding should look almost dull and buttery, thin plating tends to be very shiny. The thicker the gold plating, the more dull and buttery.
    I would also like to note that often, gold and / or silver is plated over Aluminum.
    Scott
  26. The Following 2 Users say Thank You for This Post by NobleMetalWorks:
    1. Pic's of Satellite Amp board
      By Mechanic688 in forum A Day in the Life of a Scrapper
      Last Post: 01-25-2014, 11:48 PM
    2. cell phone board weights
      By GeorgeB in forum Telecom Recycling - Cell phones, tablets, PDAs etc
      Last Post: 01-23-2013, 07:10 PM
    3. Replies: 9
      Last Post: 09-17-2012, 08:38 AM
    4. Mother board and cell phone scraps
      By francescogalazzo in forum Introduce yourself
      Last Post: 03-10-2012, 02:55 PM
