Well the dreaded upcoming winter is creeping closer and closer every day.
I got a 2 stall garage to heat here in iowas cold winters anyone have a suggesting of what type of heater I should get?
Wood stove is out so hoping something will work.
infrared is nice not sure how it would work in a small shop
If you go with electrical heat then infrared would probably be the most cost effective. I use 2 eden pure infrared heaters in my house because I have an electric central heating furnace that costs way too much to run. I have saved about $50/month running the infrared heaters. They are not loud at all and blow some heat.
Reznor heaters.. various sizes and btu's great brand with a long track record.
How about a cheap propane wall heater?? They make them look like an electric baseboard heater.
You can get them at Big R or TSC farm stores. A 100lb pig would last all winter.
100 lb'er
I'm guessing wood is out because you need something that will operate unattended. Have you considered waste oil, corn, or wood pellet heaters?
The type of stove you would choose depends on whether you can get a deal on the fuel....got any farmer relatives in the corn growing buz? Pellet and corn stoves have a little auger that pushes fuel into the burner when necessary. Up in my corner of the world, lots of people use pellet stoves for heat.
I've looked into waste oil heaters but they are a little more maintenance and I'm not sure they are allowable in an attached garage. I'm pretty sure they are ok for use in a detached workshop building. Waste oil heating would be ideal for a guy who scrapped out cars since they have to drain the oils anyway.
Hope this helps,
Jon.
That would be helpfull too and what I would probably get since the girlfriend has too many worries about a wood stove even tho we have homeowners insurance but maybe they dont cover them I will have to look she just aint crazy about it. With a toasty garage to go along with big screen tv and satelite probably why she not keen on me staying too toasty out there as I may not wanna come in lol
The corn stoves seem to be mixed reviews on that and a bit more then I want to pay on those but that was a few years ago maybe they better now? Thanks its worth checking out lots of helpfull suggestions. I just dont want to break down stuff in basement seems too messy which iam with tearing down stuff. I just got to town then clean up.
It seems to me that the venting (chimney) required for pellet and corn stoves is the same as propane or natural gas....so it can be pretty simple. Up here in the great white north they allow wall mounted vents so it is a pretty cheap install--a heck of a lot less than a wood stove chimney.
One other idea might be to find a plain old used home heating furnace that burns standard heating oil. They should be a dime a dozen on craigslist as people change out their home heating to higher efficiency furnaces. Find a cheap tank for oil (also on craigs) and you could be into decent heat for your shop for pretty low bucks. You'll have to install a slightly better chimney than a gas furnace but still way less costly than a wood stove chimney.
Natural gas heat in most places is the cheapest heat you can get but it seems to me that it doesn't lend itself to installing by yourself since there are lots of rules that need to be followed. I AM assuming that you want to do it in a least costly way so that the lady of the house doesn't start to get feeling left out!
Jon
We switched over to a pellet stove last year. the fuel saved will pay for the stove this year so 2 year return on investment. but you want to heat the garage which would be quick bursts of heat while you work and none when you don't. propane turbo heater is what i would suggest will heat the place up quick. or one of the other electric or renzor heaters to do the same thing but with less emphasis on heating quickly.
also looks like a sweet jet engine when your running it
here is a pic![]()
NH, Is that one of the styles that sound like a jet when they ignite??
That part irritates me when I'm concentrating on something
yeah mechanic the ones that i'm talking about sound like a jet and look like one as well. They make short work of a garage or basement and are affordable and portable could get one at sears or other appliance centers from $150-300 depending on size of the room you want to heat. no real instillation and the speed that it will get a room warm enough to work in is why I suggested it but good call they are loud.
Im not too worried about the noise as I wear a hearing aid so I doubt ill get too annoyed and if I do ill just turn it off which is what I do if the girlfriend starts yelling at me about something haha. Yours and mechs idea is what I would be looking for to have in the garage as its a decent price and hopefully heats it well enough. Thanks guys much appreciate each comment of helpful suggestions which is what is also great about this forum.
