Page 1 of 4 123 ... LastLast
Results 1 to 20 of 66
Reminder about whether to strip wire or not
| Scrap Metal Tips and Advice
    Scrap man started this thread.
    Scrap man's Avatar
    NY
    657
    Just a quick tip about certain wire-
    I find that some wire is actually worth more unstripped than stripped. The insulation is so thick and/or the copper is so thin that the weight of the insulation actually makes up for the lower price.
    Thejapster's Avatar
    Holly Hill Sc
    68
    I have been wondering about that myself
    sjones99's Avatar
    iowa
    266
    26
    If you figure in how much weight you have lost per lb received it will be close to the same...unless your time isnt worth anything..lol
    junkdude1959's Avatar
    Springfield,Ohio
    159
    305
    My time is valuable to me as a on call towing and recovery operator, in between calls I strip my copper wires and bust out copper from electric boards and such. I can see your point if your busy on something else, but Ill take the higher dollar anytime...just my thought dudes
    Phithy McNasty's Avatar
    NW Arkansas
    I strip all the wire I get. I figure if the yard is paying x amount they are doing so for a reason. It's profitable
    165
    23
    Has anybody that strips wire ever actually weight what they start with and what they end with? Up until recently, the only wire I would strip was cable out of computer monitors and TVs (only the heavy gauge stuff). Not too long ago I scrapped degaussing cable
    Turns out I was actually making nothing (or close to nothing.) If I stripped the small gauge wire, I was actually losing a little.
    But over all, I don't strip wire, just like I don't strip lead out of car batteries. It would end up being too much of a hassle and I would end up getting payed about the same.
  7. The Following User Says Thank You to TheMetalizer for This Post:
    Scrap man's Avatar
    NY
    657
    I don't think you guys understand what I mean.
    Say, for example, you get a 10 ft peice of wire, 1/8 inch thick with insulation, but the actual copper inside is only a few millimeters thick. Unstripped, the wire weighs a few pounds, but just the copper weighs a few ounces. If copper price is $3 and insulated wire price is $1, the wire is going to be worth a few bucks, but just the copper would be less than a dollar.
    I'm don't mean that all wire isn't worth stripping, just certain sizes
  9. The Following User Says Thank You to Scrap man for This Post:
    I agree that some stranded wire is worth the effort and some is not. I am in the A/C business and find some wire is say 18 Ga. with a thin insulation and others have a very thick insulation yet same wire size.
    I will test a wire if it strips easy it gets stripped. If it gives me a hard time it goes in the can. When I clean the wire from the units I try to leave the wire as long as possible, making it faster and easier to strip!
  11. The Following User Says Thank You to injunjoe for This Post:
    Scrap man's Avatar
    NY
    657
    If the wire is over 2 or 3 feet, I find it's harder to strip
    For me, the longer - the better. Especially if it's solid core. I just keep walking backwards; stripping as I go.
    Again I agree. I find setting wire in vise and getting each length of wire ready takes much longer then the actual time to "score" or slice the wire.
    I say score because some wire will strip if just scored yet others work better to slice the insulation.
    If I can just pull my blade down 8 foot of wire it saves much time starting and stopping with shorts
  15. The Following User Says Thank You to injunjoe for This Post:
    Scrap man's Avatar
    NY
    657
    Burning wire is illegal, bad for the environment, and really bad for your health.
    sjones99's Avatar
    iowa
    266
    26
    Get caught burning wire and see if ya like the fine!...i bet ya wont
    Scrap man's Avatar
    NY
    657
    Really? I thought it was a federal law. Where are you located?
    sjones99's Avatar
    iowa
    266
    26
    Its illegal everywhere!..some people are just ignorant to the laws...burning insulation is the same as burning tires
  20. #16
    Miles City, MT
    158
    50
    Just google illegal to burn tires or wire then what state.
  21. #17
    165
    23
    Kris Kringle, I dont think anybody is trying to rain on your parade. But... burning wire is illegal no matter where you are in the United States. It has been illegal since I think the 1960s, along with burning tires and plastic.
    Here is a press release from the el passo attorney's office outlining a man sentenced for burning wire: http://www.epcounty.com/CS/blogs/ca_...%20Release.pdf
    You can not burn wire because it is in violation of the federal Clean Air Act.
    And I'm pretty sure burning wire is known to release carcinogens. My guess is that it is best to not do it.
  22. #18
    sjones99's Avatar
    iowa
    266
    26
    I DIDN'T SAY TIRES and BTW I did google Texas Illegal Wire Burning Also If it was Illegal wouldnt you think the scrap yards Would't Buy it?
    They will buy anything for the right price....i`ve heard not sure though that scrap yards in arizona wont accept any burnt copper no matter what
  23. #19
    Miles City, MT
    158
    50
    The reason I said tires was I had better luck finding the laws about burning wire if i put tires in the search.
  24. #20
    I asked my yard if they take burned wire. They won't, though I didn't get the idea it's illegal. I am thinking, illegal or not, it's pollution, but then again so is just about everything else nowadays.
    1. A simple way to strip stranded wire
      By metalworks55 in forum Scrap Metal Tips and Advice
      Last Post: 08-20-2013, 10:58 PM
    2. Smallest gauge copper wire you will strip?
      By thxdts in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 12-22-2012, 03:06 PM
    3. BX Wire - Strip or Not?
      By BigRyan in forum Scrap Metal Questions and Answers
      Last Post: 12-22-2012, 02:34 PM
    4. Best way to strip thick wire like this?
      By Backwell in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 02-22-2012, 10:33 PM
