Results 1 to 15 of 15
Oxidation in Al
    krdandu started this thread.
    Aug 2013
    Bologna, Italy
    Lightbulb Oxidation in Al
    Hello,
    I have been facing a serious problem recently transporting Aluminium overseas. I am talking about baled Aluminium radiators.
    There seem to be some water already trapped in between the fins and during the transport the metal is getting oxidized. I
    recently had a serious claim which is way too much to not do anything about it. Does anyone have a solution for this kind of
    an issue.
    Thanks in advance.
    6,810
    hello krdandu, welcome to smf : ) I have no real solutions to offer, but a couple of questions. Have you seen photos of the end damage, and certain the claims haven't been exaggerated? Are the bales wrapped in shrink wrap, or in a sealed container, anything to inhibit excess salt air/water access ?
  3. The Following 4 Users say Thank You for This Post by Bear:
    Aug 2013
    Bologna, Italy
    Yes we have seen the photos and they are being evaluated and yes they have been exaggerated but oxidation did agree. Shrink wrap a bale of metal scrap ?! We do not do that, cant imagine how one can do it as well. Well we just loaded them direct into a shipping container and unfortunately no, we dont have anything in place for inhibition. This is the reason why I am posting here to get some ideas on what I can do to inhibit. Thanks for replying.
  5. The Following User Says Thank You to krdandu for This Post:
    Cole is offline Metal Recycling Entrepreneur
    Ashkum, Illinois
    44
    Not really an expert on any of this, but i know the company i work for uses desicants to suck water out of things. it will absorb water.
    Aug 2013
    Bologna, Italy
    Hello Cole,
    Can you suggest me any products that the company uses so I can check them out ?
    NobleMetalWorks's Avatar
    East Bay California
    687
    301
    Aluminum oxidizes very quickly, and rapidly forms an aluminum oxide coating that inhibits further oxidization, we are talking about a very very small percentage of the Al the that gets converted to Al2O3.
    I assume that they are directly melting the Al instead of refining it, and this is why they are claiming the Al2O3 is causing issue, but this doesn't make a lot of sense to me if I am looking at the problem from a metallurgical viewpoint.
    Refining Al is a very tricky thing, but even if they were refining, the very act of doing so reduces the Al2O3 to Al. The key is the Cryolite. They should be using it when they melt Al as part of their flux anyway, so it shouldn't matter if there is a very thin layer of oxidation on the Al.
    There are also other concerns you might want to consider. If you shipped this, and the method of shipping exposed the Al to salt water spray for example, it could create a layer of crusty looking Al2O3 that would look like corrosion, but in reality would be a mixture of Al2O3 and dried salt. This might be the pictures they are sending you. In this case, your shipping insurance should cover this contingency, and if not you might want to look into doing so on your next shipment.
    There is a very simple way to prevent most of the oxidation, without incurring the cost of wrapping in plastic. I am going to post a few examples, but unless I know how it's bundled, and how it's shipped, I cannot give you a really good solid answer. If yo provide that information I'll follow the thread and post here the changes.
    First, you can remove any layer of Al2O3 by subjecting the Al to a solution of Sodium Hydroxide, or lye as it's commonly called. This will remove anodizing and the oxide layer on your Al. I am not sure how best to accomplish this on a large shipment of your type of material, but it does remove the oxidation.
    If I were you I would ask if it's only the outside material of the bundle that is oxidized, rather than the entire bundle. If this is the case, then it's exposure to air, salt water spray, or something else that is causing the actual oxidation.
    If it is only on the outside layer, you can spray the outside with soapy water, like a dish soap, and allow it to dry. This is simple to remove, and will not cause any problems during the smelting or refining process, it will simply burn off.
    Another way, if you are shipping in large c-containers is to inject an inert gas into the container after loading. Or even better, covering in plastic drop clothes and injecting the inert gas under the plastic drop cloth before being loaded. The inert gas will not allow air to oxidize the Al. However, if there is water inside the radiators, you are still going to have the problem with oxidation. Matter of fact, water readily oxidizes Al. But this doesn't make a lot of sense to me either, most people put radiator fluid in their radiator, which is a oil based liquid. If this is what is in your radiators you cannot get out, I can't see how this would cause oxidation.
    You could heat the radiators to evaporate off any water, but this also might cause extra oxidation if there is water, and not radiator fluid in your radiators. The other problem is that there might be some noxious or dangerous off gas in a process like this, that might be illegal where you live to produce and exhaust without the proper permit or license. I don't know enough about the laws that govern that type of thing in your country.
    All these problems or issues however, would be the same for any load of radiators that your customer is purchasing. If they suggested wrapping them in plastic, it would seem this would only increase the problem because plastic would create a greenhouse affect. And in doing so water would evaporate, and then condense on the plastic and eventually be transferred back to the bundled/bailed radiators, probably making the situation much worse.
    Has your customer given you any examples or pictures of what their other customers do to prevent the oxidation of the Al? If they process a lot of this type of material, I don't see how they wouldn't know the best way to ship it, but then again I don't understand either way it's an issue.
    Scott
  9. The Following 6 Users say Thank You for This Post by NobleMetalWorks:
    Ashkum, Illinois
    44
    I honestly couldnt tell you the name of the product. IM pretty sure you could google search desicants and find out a lot more.
    3,404
    Like Noble says, I'd suspect exposure to the salt-water spray and surface oxidation (similar to surface rust on a car). I know there are products to apply to the aluminum to prevent this, just can't think of them right now. I know if you went to the Lets Talk Snow forum and asked, you'd get "snowed" with offers.
    Let's Talk Snow.com Discussion Forums - Powered by vBulletin
    Aug 2013
    Bologna, Italy
    Hey Scott,
    Thanks for taking the time to explain. I did pick up quite a lot of information from your post. And yes the company is not refining the scrap they are melting it direct.
    Well due to the strict regulations we make sure there isnt much of residual radiator left left in the radiators before bailing them. The water getting in there is usually
    from rain ( storage and transport ) and shipping. Sometimes we get baled scrap direct from the supplier while other times we cut the attachments and then bale them
    at our own facility. As of today we do not add any chemicals or blow them with air oranything like that.
    Cole,
    I know some of them but they are limited by thier absorbtion capabilities.
  13. The Following User Says Thank You to krdandu for This Post:
    East Bay California
    687
    301
    Quote Originally Posted by krdandu View Post
    Hey Scott,
    Cole,
    Okay so it sounds, if the radiators are in fact completely free of water, that wrapping them in plastic still might work, but I wouldn't do it. If you are just receiving and shipping the problem exists with the people shipping to you and you are just transferring the problem without knowing, or it's happening during the shipment to your customer, or your customer is using the excuse to beat you up over pricing. If you are knocking off the pipes and bailing them yourself, then I still can't imagine a situation where it is your fault.
    Depending on how your bailer works, you could eject the bail on top of a plastic sheet, then wrap the sheet around the bale and melt/seat the plastic. There are also shrink plastic product sold for industrial scale use that will shrink to fit the bale once heat is supplied. I believe this is done under a heat lamp, or hot air induction. If you used this method with injecting inert gas they would never be able to blame any oxidation on you.
    If I were you, I would look over your shipping insurance, specifically the part about damages during shipping and/or force majeure. If it was an act of nature, that could not be helped, it could be covered by force majeure, such as rain, salt spray, etc. If the shipping company didn't handle your material properly you might talk with them as well. Also, if I were you, I would notify your customer and explain to them this was totally unexpected, and that you will be turning it over to your insurance, so they might expect a call or an insurance inspector sometime in the future. In doing this, letting your customer know that there might be a nosey insurance inspector that will want to poke around their facilities, might just circumvent their current position, meaning they might just change their mind. Getting other entities involved that will be nosing around looking for the actual cause will make someone trying to pull a fast one on you, think twice.
    Hope this helps.
    Scott
    3,703
    3,699
    here on the golf coast I have to keep my al rads inside or with in weeks I will loose 20% due to the salt humidity and rain.
    6,810
    Quote Originally Posted by olddude View Post
    haha@ golf coast, are you in FL? ; )
    sawmilleng's Avatar
    Central Kootenays, BC, Canada
    859
    712
    Cole,
    Are you shipping in enclosed containers? If so, I am surprised that much more than light surface oxidation is happening, unless you are having a 3rd party load your bales in a secondary location. Presumably they might be treating your goods in a less-than-desirable way.
    Could the container have been submerged in water briefly---maybe a big storm washing waves over the container which might have been above deck?
    I tend to agree with Scott's position that having an insurance inspector come snooping at the customers site will straighten out a lot of facts very quickly. Even if you don't have insurance it might pay to hire a 3rd party inspector to go have a look on your behalf.
    Jon.
    brandon's Avatar
    North Carolina
    787
    If you are looking for a cheap desiccant, get you some cheap, dry coffee creamer, open a couple in a shipping container just before you close it up to ship.
    My fortune cookie said:
    3,703
    3,699
    Ya but Ill always miss Oklahoma.
    1. clean or dirty.. oxidation make a difference
      By 89yota in forum Scrap Metal Questions and Answers
      Last Post: 06-07-2012, 06:05 PM
Tags for this Thread
