Results 1 to 8 of 8
Scrapping air conditioner units and furnaces
    BAMF23 started this thread.
    Mar 2013
    Minonk,IL
    32
    Hello Fellow Scrappers. I have a question about scrapping a/c units and furnaces. I have quite a few of them to break down. I have never broke these down before but it seems pretty easy but I'm just concerned about the Freon/refrigerant. Is there anything to worry about? Any Tips/ advice. Thanks.
    Phantoms001 is offline Metal Recycling Entrepreneur
    Phantoms001's Avatar
    556
    165
    It really depends on who took the old A/C unit out (a furnace will not have any refrigerant). If someone was going to keep an A/C and use it somewhere else, a tech could "pump down" the system and leave a lot of refrigerant in the condenser. The easy way to tell is start to open the valve and see if you get any gas coming out. I doubt you have one with a charge, the proper thing to do is to just recover the refrigerant, most of the time a pump down is just used for repairs, but it is quite possible depending on where you got the system. Most companies would WANT to recover the refrigerant because it has a significant value, but I have see homeowners with AC units for sale that had a charge in them (despite being used).
  3. The Following User Says Thank You to Phantoms001 for This Post:
    Mar 2013
    Minonk,IL
    32
    I Figured the furnace didn't have any. The a/c unit and furnace are from my girlfriends mom and stepdads house. They had a family friend who owns his own business replace both the a/c unit and furnace this past spring. I'm not sure if he recovered it or not because I haven't scrapped them yet. Plan on doing it tomorrow morning.
    6,996
    I wouldn't just go cutting lines to find out if there's a charge because gas and oil will start spraying everywhere..we are only allowed to comment on the legal of doing it, and that is to have a person that is certified and has the proper equipment to evacuate the system. Are there other ways? Could be but you will have to look elsewhere.
  6. The Following 5 Users say Thank You for This Post by KzScrapper:
    1,928
    1,690
    If its an central air type a/c, the freon will be removed from it when they disconect it. Watch when turning it and laying it on the sides, Moving the compressor, Cutting the copper lines and rads off cause the oil will run out.
    Wear gloves, They can get dirty in there
  8. The Following User Says Thank You to greytruck for This Post:
    6,996
    Quote Originally Posted by greytruck View Post
    That is not true...I have recycled a number of disconnects that still had a charge...Also have helped install new units that came with a charge.
  10. The Following 2 Users say Thank You for This Post by KzScrapper:
    218
    130
    Depending on how they was disconnected the tech can easily close the liquid line(smaller line) and run the compressor for a short time. Doing this while watching the gages,if the line is short enough,the refrigerant can be pumped back into the outdoor unit. Again while reading the gages the suction line will then be closed and the refrigerant will be captured in the unit. If the valves are on the unit then the only way to tell if unit has juice is to crack a valve quickly and make a determination .
  12. The Following User Says Thank You to kbob for This Post:
    1,928
    1,690
    Quote Originally Posted by KzScrapper View Post
    Thanks for the heads up KZ. All of them I get are from calls to pick up and the installers have already drained them.
  14. The Following 2 Users say Thank You for This Post by greytruck:
    1. Industrial air conditioner need help
      By Chadcam in forum Scrap Metal Questions and Answers
      Last Post: 11-25-2015, 10:49 PM
    2. Air Conditioner Value
      By nyjetsfanx93 in forum Scrap Metal Questions and Answers
      Last Post: 09-22-2015, 11:25 AM
    3. air conditioner radiators
      By Mstra in forum Scrap Metal Tips and Advice
      Last Post: 12-10-2014, 08:35 PM
    4. Scrapping an air conditioner
      By jackshmuc in forum Scrap Metal Videos
      Last Post: 07-16-2012, 11:11 PM
    5. Industrial air conditioner need help
      By Chadcam in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 09-20-2011, 01:51 PM
