Results 1 to 20 of 36
trying to mount a winch
    bigdog72 is offline Metal Recycling Entrepreneur
    bigdog72 started this thread.
    bigdog72's Avatar
    honey brook PA
    274
    14
    so a while back I picked up a winch and I really want to get it mounted and start using it. now I know there are a hundred ways to do this so let me tell you my situation. I want to mount it to my truck to use for pulling stuff onto my trailer. why? well I borrow my friends trailer for cars since I dont have a big enough one yet and I can't add something permanent to his trailer. my first thought was something along the lines of a double receiver with the winch on a standard hitch mount, the problem I saw was it will be hitting the jack stand since it doesn't move, I also didn't know if it would drag on the trailer because of the angle. so now I'm thinking of a bed mount, something like a piece of angle across the bed then the winch on a plate mounted to the angle. I didn't know if just the angle would be enough or if I would need extra support. I thought I would employ the great minds of the forum since most of the time you guys think in a way I never would have. the goal is to have something that will get the job done but be able to be removed for when not in use. thanks all for your help
    Lee County, Iowa
    149
    I would use a receiver mount on the trailer I used a notched piece of angle to mount around the jack I will take pictures when I am home tonight the cable may rub the back of the trailer slightly but have never had it cause problems
    3,404
  4. The Following 2 Users say Thank You for This Post by Mick:
    bigdog72's Avatar
    honey brook PA
    274
    14
    joe thanks pictures would be great and mick we have the same winch! how do you like it?
    3,404
    Quote Originally Posted by bigdog72 View Post
    I've never had a winch before so don't have anything to compare it to. Seems to be real strong, though. I pulled a 2000 Buick LeSabre with four flat tires that had been sitting for a year and buried several inches. Couldn't get the tilt bed even with the ground and it still pulled that car up on it like nothing.
    Patriot76's Avatar
    Buffalo Commons
    2,955
    10,580
    Assuming the trailer has an upright structure to mount a winch, I would weld the winch to a 1/4 in to 3/8 in. plate big enough to span several supports. Most supports I have seen are 1/4 in. angle iron or channel so I would lean towards this thickness. Next I would bolt it to another plate on the back side of the structures. When you have your own trailer, unbolt it and weld it to the new trailer or just bolt it. Make sure the bolts are rated for more than the pulling capacity of the winch. Industrial bolts have three lines on the bolt head.
    joef1812, You have to remember that he's using a couple of different trailers, that's why he's looking at a truck mounted one.
    How about a mount that you can pin and unpin like they do a plow?? The only drawback is getting electric to it, maybe borrow the trailer plug-in during winch time.
    auminer's Avatar
    Allen, TX
    1,228
    576
    My wench prefers to sit in the passenger seat. How do you guys talk yours into riding in the bed? That would be sooo much better cuz then I could set the AC, and the radio station & volume how I want it, not how she wants it.
  10. The Following 4 Users say Thank You for This Post by auminer:
    Lee County, Iowa
    149
    still not home but will get those pictures I have one winch and I move it between trailers and have it in front or back of my trucks as I need it I have also had it chained to trees hooked to a charged up battery when I needed it somewhere I couldn't drive
    cummins is offline Metal Recycling Entrepreneur
    cummins's Avatar
    ontario
    572
    best way is to cut a hitch off a truck at the wreckers and weld it on the tongue of your trailer, and weld 2x2 or what ever the reciver size onto the botton of the winch plate is so you can take it on and off like you would a ball or pintal hitch on your trailer or car. plus you can use your winch on your truck as well incase your buddie pulls off the side of the road to far when pulling over for a leak.
    Lee County, Iowa
    149
    sorry the picture isnt the best but i think you can get the idea. i went back and re read the original post and this may not work since it isnt your trailer but just an idea
    bigdog72's Avatar
    honey brook PA
    274
    14
    cummins thats a great idea I might do that in the future. once again my dad comes to the rescue and gives me a couple good ideas, I should have something done tomorrow so I'll post pics.
    joe thats one of the ideas I had but it wont work with my buddies trailer, I do like the whole receiver concept and might try it at some point
    cummins's Avatar
    ontario
    572
    this is another idea. this is what my buddy did on my current trailer when i wasn't there. then he welded a cheap bolt on receiver on the bottom of the winch plate. its backwards from what i asked him to do but it works. We did have to weld a few braces in because that piece its welded to was flexing, next vehicle we scrap with a class 3 hitch on it well do it the other way around. fix it.[IMG][/IMG]
  16. #14
    bigdog72's Avatar
    honey brook PA
    274
    14
    thats what I will probably do once I get a trailer for cars
  17. #15
    bigdog72's Avatar
    honey brook PA
    274
    14
    got it rigged up, not too sure how it will handle big pulls but theres one way to find out! now I can finally get my one car back on the trailer
  18. #16
    grouchyolddude's Avatar
    CO
    209
    786
    Soooooo disapointed... I thought the title said trying to mount a "wench"...
    "Some people try to turn back their odometers. Not me, I want people to know WHY I look this way. I've traveled a long way, and all of those roads weren't paved"-Will Rogers
  19. The Following User Says Thank You to grouchyolddude for This Post:
  20. #17
    cummins's Avatar
    ontario
    572
    let me know how that works out. all you need is a old mini van with 4 flat tires and a locked up trans. (just cause their heavy)
  21. #18
    bigdog72's Avatar
    honey brook PA
    274
    14
    old dude sorry to disappoint, and cummins the first really test will be a 85 chevy c30 box van if we cant get it to start
  22. #19
    Just watch when your putting the strain to it that the bed rails don't try to spread.
  23. #20
    bigdog72's Avatar
    honey brook PA
    274
    14
    yeah I have some concerns about it but we'll wait and see how it works
    1. Score, motherload, or otherwise awesome thread. - my new winch
      By bigdog72 in forum Scrap Metal Recycling Tools & Equipment
      Last Post: 07-03-2013, 06:06 PM
    2. This thead is a question - what size winch do I need
      Last Post: 06-11-2013, 12:01 PM
    3. Winch recommendation?
      By Mick in forum Scrap Metal Recycling Tools & Equipment
      Last Post: 02-21-2013, 10:21 PM
    4. New Winch
      By Semo Scrapper in forum Scrap Metal Recycling Tools & Equipment
      Last Post: 03-10-2011, 04:27 PM
    5. Winch...who has the best brand?
      By IdahoScrapper in forum General - Let's talk business
      Last Post: 12-16-2010, 05:46 PM
