I have 127 - just over 1K lbs total - of 115 VAC, 1 amp transformers. These were removed from stoplight control boxes and were working units prior to be pulled from service a few years ago. The only part info on the transformers states "ACI Powermag, Inc (seem to be out of business), 32892P2, 98/02. I was able to get the voltage and amperage from the control box maintenance guide, but no other info or specs were mentioned. Each unit has a wiring harness consisting of 5 individually insulated strands leading to a 5 pin connector that plugs into a power board. The connectors have nice gold pins.
Does anyone have any leads/suggestions on selling these as working parts or should I just scrap the transformers as electric motors, cut the wire and sell as #2, and throw the connectors in the gold pin connector pile?
Thanks in advance for any help!
