Results 1 to 9 of 9
Hybrid View
    auminer started this thread.
    auminer's Avatar
    Allen, TX
    1,228
    576
    Not all TVs are the same. Let's make a list...
    So you got a truck full of TVs. You're stoked to break them all down & grab all those copper degaussing cables, and those beautiful yokes that slip right off the tube, and the miscellaneous other goodies inside a television.
    But you start breaking them down & learn that many of the degaussing cables are aluminum. And many of the yokes are bonded to the tube & won't budge.
    This may be a task too large to bite off, but that's never stopped me before.
    But what I'm looking to do is to put together as all-inclusive of a list as I can, of all the TV makes & models out there, & what the degaussing cables & yokes are like. That way, if you're sitting at a curb debating about whether to grab that TV & its hard-to-get-rid-of CRT, you'll be able to refer to the guide & know what you're taking/passing up.
    So, tonight's 4 TVs:
    Total and absolute leverite, this TV. Aluminum degaussing cable, bonded yoke. GRRR The only thing worth grabbing on this pile of junk was the 3x4x1/2 brick aluminum heatsink. Cut the cord & leverite where you find it.
    Not much better. The yoke wasn't bonded but the cable was aluminum. Worth grabbing if you're hungry, I guess.
    Best TV of the bunch. Decent length & thickness cable & easy-free yoke.
    Pencil-thin & short copper degaussing cable, bonded yoke. Leverite.
    If you can take pics, post them along with the info above, and I'll build an excel spreadsheet listing all the manufacturers & models along with specs regarding the degaussing cables & whether or not the yokes are bonded. Any other data we need?
  2. The Following 2 Users say Thank You for This Post by auminer:
    6,126
    11,842
    will post some late rbut just had to say...Bonded Yokes suck. Seriously. THEY SUCK! I'd use meaner words but I fear the ban hammer, and would miss you all terribly if I was sent to time out. :P
    Sirscrapalot - Not looking forward to all the picture taking an posting for later.
    Gravitar's Avatar
    Central Texas
    1,086
    1,258
    Ok, I will toss in some stuff I've found:
    #1: Obviously, the Sony Trintrons. Huge copper degaussing cable. ALWAYS pick these up.
    (Sorry about what's on the screen, I just took a pic of the one in my house. I'm not trying to promote Bravo in anyway.)
    #2: The very new Zeniths are very easy to strip. That is the only good thing about them. There is maybe ONE transformer aside from the flyback. The degaussing cable is not wrapped in tape but it's in a white rubbery plastic that makes it easy to pull the aluminum wires out of. All you have to do take your needle nose and pull the aluminum wire through the sleeve. Also, the yolk is covered in epoxy and is a pain to get the copper off the ferrite. The one I did is still sitting in a bucket somewhere in my garage, I don't want to mess with it.
    #3 A lot of the newer CRT's have tiny little degaussing that takes forever to strip. You would be better off selling it as #1 insulated.
    That's it for now, I'm sure I will put some more stuff on this thread in the future.
  5. The Following User Says Thank You to Gravitar for This Post:
    Central Florida
    629
    115
    i did a crt analysis on here a bit ago
    1,928
    1,690
    Old Zeniths and RCA then GE tv's are the worst ones id have to say. The Zeniths have way to many screws and RCA glue the yoke to the tube most of the time, same with the GE tvs. Sony tvs are cheaply built, same with there cpu moniters. When ya smash the yoke it unravels.
    Just from my experience
    2,863
    349
    I don't do tv's any lomger but I used to do alot of tv's. I've never seen a tv with a yoke that I could not take off by unscrewing the two ss clamps and giving the yoke a good hard twist. The copper is always hard to get off tv yokes but if you smash the with a hammer and pick the fertite out you can get some nice #2 copper and it dosen't matter if it has glue on it. Yes some tv's have alluminum degaussing cable also don't foreget the copper that goes across the tube that is atached to the four corrners of the tube. Also you can get #2 insulated copper wire and a large low grade board with alot of aluminum heat sinks and ic chips.
    submarinepainter's Avatar
    1,026
    1,230
    I just cut the cord and another scapper takes the rest . I rather do radios lol
    May 2012
    rochester
    43
    hear is what i found on the cables
    sanyo- almn
    sony (except trinitron)-almn
    rca 27"-almn
    apex 27"-copper
    jvc 27"-copper
    sharp 24"-almn
    daewoo 13"-copper
    panasonic 27" almn
    Twisted is offline Metal Recycling Entrepreneur
    Kansas
    50
    22
    Picked this 42 inch Vizio up, broken and no back!
    Back Pic
    1st board
    2nd board
    3rd set
    4th set
    Only board that wasn't double green that I took a picture of, cause of all the goodies I stripped off it.
    This TV had a about 2 lbs of extruded alm, 3 lbs of cast alm (wall mounts), Little over 1 lb of wire, some tin, and the transformers. Was well worth the time.
