Results 1 to 20 of 28
    daveward started this thread.
    Mar 2013
    CA, United States
    11
    Looking For Experts in Rigging---just a tad off topic
    The pictures are of a vintage snatch block I picked up and now have a perfect use for...except...
    I don't know if this unit is intended to be used with a 3/8" winch steel cable line, which is what I want to do.
    The markings on the unit show that it's a RIG 25 and 10" Snatch Block It also has the statement: "Max. Rope 3 1/2 CIRC." The actual diameter of the pulley is 6".
    I'm hoping someone has some metal identification and or rigging experience and will say something like: "Nope, you dummy, the width of the pulley means it's for rope....or...."Yep, it'll handle steel cable". Thanks so much.
    BarrenRealms007's Avatar
    Arkansas
    398
    203
    As long as the cable will stay i the pully grove you will be ok. My concern it that the top loop looks like it has been broke and welded back and if that is the case this will be your weak link.
  3. The Following User Says Thank You to BarrenRealms007 for This Post:
    Louisiana
    255
    74
    Make sure you have the right size cable. If the cable is too small over time it will eat a channel into your pulley and cause it to fail. If the cable is too big it won't seat right and it will wear you cable out and cause it to fail under load. I would get different cables and see which one seats into the grove perfectly. It should be stamped somewhere on there the intended wire rope size. Hope this helps a little.
    Mar 2013
    CA, United States
    11
    Quote Originally Posted by BarrenRealms007 View Post
    "Barren...", you have an amazing eye for detail. I double-checked the welded part today and it's the first time I noticed the extent of the weld. You are perfectly correct. Thanks for the great catch.
    EDIT: One thing I should have noted was another marking on the unit: "Max Rope 3 1/2 Circ." This confuses me a bit as it's not clear to me why this pulley would have any complete circles of rope. Hmmm...
    Barren...thanks again.
  6. The Following User Says Thank You to daveward for This Post:
    Mar 2013
    CA, United States
    11
    Quote Originally Posted by toula View Post
    Like you, I assumed there would be a rope size marking, but I couldn't find one, hence this post. Your concern about a smaller cable eating into the pulley is exactly the issue. I'm having second thoughts. Thanks.
    Louisiana
    255
    74
    Circ. = circumference
    Mar 2013
    CA, United States
    11
    OK...that's helpful. Let's say that CIRC is an abbreviation for Circumference. That makes the marking "Max Rope 3 1/2 Circ." even more obtuse to me. What do you think it's telling me? Thanks!
    Louisiana
    255
    74
    It may mean that the largest diameter rope you can use is 3 1/2 inch.
    Arkansas
    398
    203
    The diameter and the circumference are two different things. A 3-1/2" diamter rope would not fit in that pully, a rope with a cir. of 3-1/2" probably would.
    South Central Minnesota
    232
    123
    3-1/2" circumference is about 1" diameter. If you do not plan on using check eBay sold listings for vintage pulley, cinch block, barn pulley or a combination of words that describes your item. You might be surprised at what some of that stuff sells for. The fancier or more unusual they are the more they sell for.
    As a driver I'm always sober, but my truck is always ready to get loaded
    Mar 2013
    CA, United States
    11
    Curiously...a circumference calculator suggests a rope with a circumference of 3.5" would have a diameter of 1.1140846016432 inches. To my eye the pulley is in fact designed for a rope very near 1". Interesting. Now...the key question again. If you have a steel pulley and use a steel cable of 3/8" is that going to grind away the pulley material or not?
    Libertytow's Avatar
    Silverton NJ
    562
    64
    when i was taught you use 1 /12th the sive of the sheav to determine rope sixe /wire rope anything smaller ruins the cable on any snatch block
    Liberty Towing & Recycling
    (732)279-8599
    Cleaning up NJ 1 LB at a time!
    Certified Mobile Scales
    Fully Insured Carrier usdot # 1802487
    WWW.LibertyTowing.Webs.Com
    WWW.TRRecycles.Webs.com
    Mar 2013
    CA, United States
    11
    Quote Originally Posted by Libertytow View Post
    Thanks for the experience. Just so I am clear on the point you make, if the width of the sheave (pulley) is about 1" wide then the cable would be 1/12 of 1"? Or since the pulley is 6" in diameter the cable can be 1/12 of 6"? Thanks again!
  16. #14
    5,728
    6,814
    I take it you're not familiar with "wire rope" ; ) It should also have a tons rating, possibly denoted with a T. Something like say 10T or similar, quite likely on the eye
  17. #15
    Mar 2013
    CA, United States
    11
    Bear...I don't understand why you would say I am not familiar with wire rope. The purpose of this thread is to determine whether I can use wire rope or not. I have been referring to it as steel cable. If that is a problem I am happy to call it wire rope.
  18. #16
    5,728
    6,814
    you're on post number 15 and haven't called it that yet. Anyplace that works with it will note it as "wire rope". From most of the previous posts I actually couldn't tell if you were aware of it at all. It was no doubt scrapped because of the broken eye, which needs replaced
  19. #17
    Libertytow's Avatar
    Silverton NJ
    562
    64
    3/8" wire rope would need a 6" sheave if that helps
  20. #18
    SuperDave's Avatar
    May 2012
    Usa
    448
    526
    Probably would make a good clothesline
  21. #19
    5,728
    6,814
    Dave, I really was in no way trying to knock you, or your post. It just didn't appear most of the posts on this thread were aware that the "rope" etched on the block would be referring to "wire rope", or cable, if you want to call it that, I think most everybody does(including myself). I was simply adding the thought that technically it is called wire rope, and likely what that message was about
  22. #20
    Mar 2013
    CA, United States
    11
    Thank you Bear...I appreciate you post. You may have hit on the real issue. I am the one who needed confirmation that the "rope" etched on the block referred to wire rope or cable or whatever it is commonly called. I am the one who wanted to verify that the rope reference did not mean something like manila rope. I use the term wire rope and steel cable interchangeably.
    Anyway...if you are confirming that the pulley I have is meant to be used with wire rope or steel cable, then you are the man...or...the Bear!
    Thanks again.
  23. The Following User Says Thank You to daveward for This Post:
    1. Need Advice From the E-Scrap Experts!
      By GlobalStrider in forum General Electronics Recycling
      Last Post: 09-18-2012, 02:36 PM
    2. Attention Coax Experts - Quick Question!
      By BigRyan in forum Off Topic Discussions
      Last Post: 08-27-2012, 11:24 PM
    3. Need the experts advice!!
      By krimic26 in forum General Electronics Recycling
      Last Post: 02-20-2012, 09:19 PM
    4. ?/ for the experts lol
      By ozzy214 in forum Scrap Metal Questions and Answers
      Last Post: 12-17-2011, 11:21 PM
