Hiya Metalheads!
So here is my delimma (other than being a rookie and having a local scrap yard that doesnt like to answer questions) I have a stack of towers that I thought scrapping was a good idea. Now I read that some components are worth more to sale online if they still work. My line of thinking was that if the tower is old enough to have a floppy drive that it wouldnt be worth reselling due to being antiquated. Is this dumb on my part?
Now assuming I am going to scrap all of the towers...how far do you break them down? I got the basics down...case, boards, memory, power supply, wiring, drives etc. My question is for the sake of time vs maximum dollar signs...do I take apart the drives, power supply etc. I did take EVERYTHING apart on the first one out of curiosity. Its freaking cool to find gold and other shiny things inside.
Next, I was told too seperate Hi grade and mid grade boards but my scrap yard says they only pay 7.5 cents a pound for all boards. Confusing?!?!?!?
After breaking down the first one I ended up with these piles: Insulated wiring, Aluminum (heat sinks, driver case and disc), Hi grade boards (Mother and driver boards, Mid and low grade boards (all the rest), Copper (anything I could find on boards or elsewhere even the itty bitty fan motors), Magnets (from hard drive) and of course the steel case and frame. Am I on the right track?
I guess what I am looking for in a nut shell is justification for the hour it took me to break it down as far as I did vs the 5 minutes I see it done online! for example I was told when it came to motors "if it is bigger than a box fan, remove the motor before you scrap it" I get that. I just need the same rule of thumb for towers.
Thanks in advance for any and all suggestions or advice!
- 19 Compute Towers and confused...pls help!
