just got back and it goes as follows,tin .085/lb...dirty aluminum.11/lb...electric motors .20/lb ...clean aluminum .35/lb......copper bearing .15/lb ,did not do any copper or brass
thats really low prices, heres the current prices for my area
February 20, 2013 - TOPEKA, KS PRICE SHEET
Material 1/99 Lbs. 100/499 Lbs. 500 + Lbs. Quote
Code Copper/Brass
005 #1 Copper 2.95 3.05 3.15 2.95 3.15
006 #2 Copper 2.80 2.90 3.00 Grade & Weight
004 Light Copper 2.55 2.65 2.75
Insulated Copper .30-2.50 (depending on grade & copper %) 0.30 2.50
105 Red Brass 2.05 2.15 2.20 2.05 2.20
106 Yellow Brass 1.80 1.90 2.00 Grade & Weight
100 Auto Radiators Clean 1.75 1.85 1.95 1.75 1.95
101 Auto Radiators Dirty 1.35 1.45 1.55 1.35 1.55
102 Heater Cores Clean 1.25 1.35 1.45 1.25 1.45
Aluminum
306 Aluminum Cast (Clean) 0.45 0.50 0.55 0.45 0.55
303 Aluminum Mix (Clean) 0.50 0.55 0.60 0.50 0.60
315 Extrusion & Clean Aluminum Wire 0.60 0.65 0.70 Grade & weight
322 Aluminum Wheels (Clean) 0.65 0.70 0.75 0.65 0.75
319 Aluminum Radiators (Clean) 0.45 0.50 0.55 0.45 0.55
320 Aluminum Radiators (Dirty) 0.25 0.30 0.35 0.25 0.35
335 Aluminum Copper Radiators (Clean) 1.40 1.45 1.50 1.40 1.50
336 Aluminum Copper Radiators (Dirty) 1.15 1.20 1.25 1.15 1.25
304 Dirty Aluminum (O/S-Cast) 95% alum 0.40 0.45 0.50 0.40 0.50
327 Aluminum Transmissions/Heavy Brk 0.13 0.15 0.18 0.13 0.18
318 Aluminum Wire (ACSR) 0.30 0.35 0.38 0.30 0.48
Aluminum Cans
Less Than 50 Lbs. 50 - 99 LB 100 - 199 LB 200 - 499 LB 500 LB
300 0.55 0.58 0.60 0.62 0.65 0.55 0.65
Miscellaneous Other Metals
400/1 Stainless Steel Alloy 304 0.50 0.55 0.60 0.50 0.60
131 Clean Die Cast (Zinc) 0.25 0.35 0.25 0.35
132 Dirty Die Cast (Zinc) 0.10 0.15 0.10 0.15
240 Magnesium 0.25 0.35 0.25 0.35
154 Lead {Hard lead .05 less} whl whts-10 0.35 0.40 0.45 0.35 0.45
151 Batteries 0.20 lb.
230 Catalytic Converters ~~~~~~~~~~~~~~~ASK FOR PRICE ~~~~~~~~~~~~~~~
Iron Per Ton Code Per Ton
500 Mixed Scrap & White Goods $195
512 Unprepared P/S (shearable)
$220
501 Cars with tires (5 max) $205 519 Torch Iron/Heavy Cast 20-60
502 Cars no tires
$210
516 Baler Tin-clean $210 520 #1 Motor Cast (2' x 2') $270
511 Prepared #2 (3' x 18") $240 521 #2 Stove Cast $240
510 Unprepared #2 (Shearable) $210 051 Electric $480
515 Prepared #1 P/S (3' x 18") $260 050 Sealed Units/Compressors (Drained) $300
517 New Steel Clips $260 Steel Wire 0-$60
I would have to say there must be no compatition for them,those prices are the lowest i have heard since the crash of 2008 in S Florida today tin $210.00 a ton electric motors .34 old sheet ..55 6063 excrusion .72 might have to find a new yard if i were you.
i thought i was getting low balled ,i have worked with them in the past with good results ,live and learn
Come down rt. 91 to Holyoke.
Here is what I got 2 days ago. #1 copper 3.20#, #2 copper 2.90#, extruded al .70#, yellow brass 1.90#, insulated copper 1.15#
kinda of low... boss
here on Bolduc site are a list of current prices in northern Vermont if this help anyone. the prices are low but they general post their prices on their website
do a search for bolduc auto salvage
you drive up north of Montpelier from Weathersfield? (I'm thinking you're near Ascutney?)
