Results 1 to 10 of 10
Nice little wire stripper
| Off Topic Discussions
    GeorgeB started this thread.
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    I had this saved to bookmarks, and I clicked on it just now, and instead of the one I had booked marked, this one shows up. Must say, it is really nice.
    Looking to get a wire stripper in a couple of weeks to go through all my wire and turn what I can into #2 copper.
    The Authentic Manual Wire Stripper Stripping Machine | eBay
  2. The Following User Says Thank You to GeorgeB for This Post:
    NJ
    156
    55
    I like how there are guides to sharpen the blades yourself.
    "Easy does it, first things first, do what you can. Believe me, I too have been through the wringer." Bill W.
    Ecycle Atlanta's Avatar
    Outside Atlanta
    734
    289
    I own one of the previous models (the blue one a little way down the page). I dont do a lot of stripping anymore because of time constraints, but if i ever slow down i will have a pile ready. It is a great device. I had noticed a few of the design flaws and rigged this to work more efficiently, but now i see that they added parts to fix them....NICE! It also helps build the forearms, but is really suprisingly easy to use. The blade stays sharp a lot longer than i thought it would, but keep checking to make sure it is sharp and it will go through the cover real easy. I give it 2 thumbs up
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    Quote Originally Posted by shendog View Post
    Thanks for the review. Seriously leaning towards this one. I know there is drill powered ones, but sometime like this would be more better for me.
    2,863
    349
    What kind of wire are you going to strip? I have never used one before but if you'r going to strip thin wire like the wire out of electronics it might not work so good. To me that kind of wire is not worth stripping. If your wire is thick like they use to wire a house then it would work better. On that kind of wire it's better for me to use a box knife and I can strip wire just as fast.
    kcscrapper is offline Metal Recycling Entrepreneur
    585
    76
    I have the older one but I only strip #1 wire with it but works great
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    I will strip anything and everything minus really small wire....that just goes for insulated wire.
    depending on how small I will just use a handheld stripall stripper
    I have to say that is a nice looking stripper, but if the blades were better quality would they need sharpening. ??
    NewbyScrapper's Avatar
    Northern California
    263
    1,475
    Geo, I too, have the older version, which works extremely well. A bit of a learning curve to get the rollers and the cutting blade "just right". I have used it down to 14ga stranded wire, so far.
    Their newer model looks much "prettier"
    Mech: I'm surprised how long, one blade stays sharp. Of course, I haven't measured the total length of cable stripped, but it has been considerable.
  11. The Following User Says Thank You to NewbyScrapper for This Post:
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    Im sure, unless the blades are made out of some sort of really good material (what, I am not sure), then they would need sharpening. I am sure, like everything else, they will get dull after a while. However, according to the pictures in the ad, you just need an angle grinder and whatever that cut off disk is, and you can sharpen them up within minutes!
    Definitely leaning towards this one for sure, unless I see something better that peaks my interest.
    I am looking to be as portable with my tools as possible. Never know what type of jobs you will get, where portability is an essential asset!
    Quote Originally Posted by NewbyScrapper View Post
    Yeah, I have seen a LOT of good reviews on the other model. Main reason I booked marked it originally. Apparently, they have come out with the "guiding" system for the older one as well.
    1. $14 wire stripper
      By rca987 in forum Scrap Metal Recycling Tools & Equipment
      Last Post: 06-15-2013, 05:50 PM
    2. My wire stripper
      By Coreyokc in forum Scrap Metal Recycling Tools & Equipment
      Last Post: 05-17-2013, 08:59 AM
    3. Granulator/wire stripper help
      By ecsider in forum Scrap Metal Recycling Tools & Equipment
      Last Post: 01-21-2013, 12:17 AM
    4. Wire stripper
      By roboutlaw in forum Scrap Metal Recycling Tools & Equipment
      Last Post: 01-18-2013, 07:02 PM
    5. making a wire stripper
      By scrappy in forum Scrap Metal Tips and Advice
      Last Post: 09-23-2011, 10:14 PM
