Page 1 of 3 123 LastLast
Results 1 to 20 of 52
    BurlyGuys started this thread.
    BurlyGuys's Avatar
    Waterford Michigan
    1,591
    1,109
    What's the most useless waste of time thing you've ever broken down for scrap?
    What say you?
    John Terrell (248) 224-2188
    Burly Guys Junk Removal LLC
    http://www.burlyguys.com
    MisScrap's Avatar
    MD
    92
    135
    hard drives...?
    Yep...hard drives!
    301-829-2329-tel
    301-956-9352-cell
    countrysiderecycle@verizon.net
    http://www.countrysidecommunityrecycling.com
    "It's better to be thought of as a fool then to speak and remove all doubt!"
  3. The Following User Says Thank You to MisScrap for This Post:
    Russell's Avatar
    Chicago,Il
    815
    495
    Where do I begin? Anything I can't make an additional 10$ an hour at BARE MINIMUM breaking down, I don't touch. I value my time. I'll remove a motor from something but that doesn't mean I'm automatically gonna break the motor down.
    I used to think TVs were cool. Then I realized they end up being worth little more than steel weight, when you factor what you make vs how much they weigh.
  5. The Following 5 Users say Thank You for This Post by Russell:
    numbers's Avatar
    Kansas
    167
    1,421
    The most useless waste of time?
    The first laser printer that I took the time to take everything apart. Interesting, but what a waste of time. Now, it's just pull the memory and a accessible cards, the cartridge and throw the rest inside of a fridge for shred. It isn't worth my time to go much further.
  7. The Following 3 Users say Thank You for This Post by numbers:
    Don't care for printers either^^ and even though I break regular washers and dryers down the stack-able apartment types can be a real PITA so sometimes I just grab wire and move on.
  9. The Following 2 Users say Thank You for This Post by KzScrapper:
    BurlyGuys's Avatar
    Waterford Michigan
    1,591
    1,109
    Now THIS is information I can USE! What NOT to break down! LOL!
  11. The Following 2 Users say Thank You for This Post by BurlyGuys:
  12. #7
    1,876
    1,642
    Boom boxes. not much inside of them. But sterio receivers are great
  13. The Following User Says Thank You to greytruck for This Post:
  14. #8
    3,436
    3.5 foppy drives, unless they have the nice aluminum frame. Dish washers, the motor is a pita to get out and the bodies have a lot of plastic.
  15. The Following User Says Thank You to BRASSCATCHER for This Post:
  16. #9
    Germany
    57
    1. A Condensation Dryer looking for the motor, never again!!!!! and 2. A Teletype system - just some cable and the rest was shredder food.
    metal Detect around the tree before you Pee.!!!
  17. The Following User Says Thank You to jassiejames for This Post:
  18. #10
    34
    I used to pass dishwashers for the pita of taking apart, then I got a 10lbs sledge and now they just fall apart. The only thing I dissect now is towers, everything else gets bashed.
  19. The Following 2 Users say Thank You for This Post by james2144:
  20. #11
    Massachusetts
    351
    145
    Everything is useful it all ends up being $$
  21. The Following 2 Users say Thank You for This Post by landmine:
  22. #12
    volvoscrapper's Avatar
    New Jersey
    209
    289
    floor standing air purifier. tiny motor, a switch, a few wires, gobs of plastic fan blades, plastic housing, plastic plastic. I did one via unscrewing, and the screws were just endless, followed by prying and smashing. The second one I found went straight into a smash blanket and I wound up with a mountain of fragmented plastic that was sharp as glass. no more air purifiers!
    they look like this
    agree w/boomboxes too
  23. The Following 3 Users say Thank You for This Post by volvoscrapper:
  24. #13
    BurlyGuys's Avatar
    Waterford Michigan
    1,591
    1,109
    Quote Originally Posted by volvoscrapper View Post
    they look like this
    My yard takes those for shred.
  25. #14
    CTscrapman's Avatar
    CT
    179
    190
    I once took apart a magnetron out of a microwave broke it all the way down. Thats fifteen mins i"ll never get back.
  26. The Following User Says Thank You to CTscrapman for This Post:
  27. #15
    Massachusetts
    351
    145
    It finally came to me, one that was useless.
    A projection TV,
  28. The Following 2 Users say Thank You for This Post by landmine:
  29. #16
    ParkerFlyer4's Avatar
    north west
    407
    423
    If I have never broken something down before, I do. It's fun seeing how things work, and what is in them. Advice on this site is very good, but I like finding out on my own (the hard way sometimes.)
    That being said, there are many things I have broken down completely and will never do them again:
    Printers - take what is easy, the rest in shred.
    vcrs - pull wires and Aluminum motor mount, the rest in shred.
    radios - cut cord, shred
    toasters - cut cord, shred
    coffee makers - cut cord, Junk!
  30. The Following 5 Users say Thank You for This Post by ParkerFlyer4:
  31. #17
    I pretty much agree with you except don't forget the heating wires from the toaster (not sure what's in the coffee maker for heat) cause that is ni-chrome wire.
    http://www.scrapmetalforum.com/disma...sell-them.html
    http://www.scrapmetalforum.com/scrap...um-anyone.html
    http://www.scrapmetalforum.com/scrap...me-$$$$$$.html
    http://www.scrapmetalforum.com/day-l...t-insides.html
  32. The Following 3 Users say Thank You for This Post by Mechanic688:
  33. #18
    Copper Head's Avatar
    Up North
    1,883
    579
    not saying its useless but sure is no end - an old old turn table
  34. The Following User Says Thank You to Copper Head for This Post:
  35. #19
    Hypoman's Avatar
    1,268
    2,772
    pool pumps for those blow up pools....... stupid things.
    Know the true value of time; snatch, seize, and enjoy every moment of it. No idleness, no laziness, no procrastination: never put off till tomorrow what you can do today.
    Lord Chesterfield
    Thomas Jefferson
  36. The Following User Says Thank You to Hypoman for This Post:
  37. #20
    1,876
    1,642
    Quote Originally Posted by landmine View Post
    A projection TV,
    I will agree they take a bit of time to take apart, but they got those DLP chips in them. around $60+ a lb
  38. The Following 2 Users say Thank You for This Post by greytruck:
  39. Similar threads on the Scrap Metal Forum
    1. Scrap Metal Forum? - This is the best thing I've come across in a long time
      By CaliforniaMetalRemoval in forum Off Topic Discussions
      Last Post: 11-09-2012, 07:34 AM
    2. Broken e-scrap?
      By xXGrime in forum Scrap Metal Questions and Answers
      Last Post: 08-20-2012, 09:32 PM
    3. This is probably the funniest thing I've heard in a long time
      By ScrapperNJ26 in forum Off Topic Discussions
      Last Post: 04-15-2012, 07:36 PM
