Results 1 to 16 of 16
    newattitude started this thread.
    Whats the difference between SS solids? (The numbers)
    My yard board has SS listed and they are all different numbers like 301, 306, etc. Anything I've ever taken is was bought as 301. How can you tell if you have something different? Is it by item? like, only certain items are made with certain number SS?
    2,864
    350
    The yards I use don't go buy the numbers, if the magnet dosn't stick and it sparks when hit with a grinder it goes in the ss bucket. Sorry I couldn't be of more help.
    admin's Avatar
    684
    336
    I know that some types of stainless are slightly magnetic, where as others are not magnetic at all. That's one way to tell but I'm not sure which of the stainless types have a slight magnetic pull and which don't. Hopefully someone more knowledgeable in stainless will chime in.
    Mesa, AZ
    20
    86
    I know next to nothing about stainless steel. But someone threw out a bunch of stainless steel compression fittings a few weeks back, so I did a little Googling. The fittings were all marked with 304 and 316 (if I remember correctly). Not that this article helps you much with the yards (and how they determine the difference in grades), but >>> SAE steel grades - Wikipedia, the free encyclopedia
    BigRyan's Avatar
    206
    134
    My local yard does the same thing. However, if I suspect I have anything better, I'll save it for a trip to the "bigger" yard, where they can have someone look at it and determine if it's worth more to them or not.
    5,728
    6,814
    I had a bunch of SS 316, the only way I knew it was 316 was because the compression fittings used to join it said so. From my googling what I found pointed towards the different numbers not being of greater or lesser quality, but of having different makeup characteristics(ingredients), giving them differing qualities in differing environments. I am also certain if it is still a usable product, go with Ebay or Craigslist for FAR more than scrap value
    Huh. Thanks everyone for all the replies. It just had me wondering since there was 5 or 6 ''numbers'' of SS listed. I don't know why today of all days it bothered me enough to ask about it!
    Thanks PFSNewb for the links, that does explain quite a bit
    When I bring in SS screws and smaller fasteners and clamps from monitors/tvs that are non-magnetic and too small to label, they go as SS Solids and usually pay close to what the better SS pays. Usually not enough weight for me to get too excited about the final payout but I would be a fool to just throw them in with shred. Bohemian could shed more light on this.
    Saint Louis, MO
    762
    There is 200 series SS high chrome content low nickel content and high steel content. 300 series 5 to 10 percent nickel 20 percent chrome balance steel. 400 series low nickel content usually 2 percent or 3 percent and some chrome and a high amount steel in it. Anything with more nickel then that is going to be a high temp alloy example hasteloy x, inconel, monel, cobalt, etc.
  10. The Following User Says Thank You to PistoneScrapProcessing for This Post:
    Ahhhhhhhh......ok, now I know what those high temp alloys are! Thanks PSP!
    tampa
    26
    304 Stainless(18/8) is of course the most common and basic stainless in which most yards will buy at one price... 301 stainless has about 2% less nickel in it and will have a slight magnetic draw to it. Because most 30 is usually some kind of stripping it is thin and will appear to be more magnetic than it is. Most yards should pay 304 price for it in normal amounts. 316 has 2-4 % molybenum in it making it much more valuable upwards of .40 cents /lb . You can tell the difference between 304 and 316 by the spark as the 316 will have a distinct starburst at the end but it takes a known piece to really get used to what you should look for. MAny stainless items are marked in code. astm or pwa numbers and screws usually have numbers on them which you could look up. Hope this helps a bit
  13. The Following User Says Thank You to grabinow for This Post:
    Saint Louis, MO
    762
    Grab there are also a few other elements I left out of the other grades to because they are such a small amount its not worth mentioning. For those who really want to know about stainless I would suggest they Google stainless grades and learn as much as they can about them. I can virtually identify any metal just by looking at. 304 vs 316 can easily be identified by how much more shine it has then 304. Scratch tests work to along with a grinder really help with identifying materials that have nickel in them. I hope that helps.
    3,436
    If you go to www.isri.org you can print out a scrap specifications circular. It's a guideline for all ferrous,nonferrous,glass,paper,plastic,electronic, and tire scrap. It's one of the first things I read through when I started scrapping and gives a good description of all the metals. Also google spark test and read through a few things. There are good online descriptions of what to look for when spark testing metals. One actually had great pictures of spark tests and the different sparks that are thrown by different metals. I will try to find the link.
  16. The Following User Says Thank You to BRASSCATCHER for This Post:
    3,436
    Take a look at Repair and Maintenance Manuals - Integrated Publishing and page through there. Gives some good info on spark testing and chip testing. Basic stuff which is all you need. Hope this helps.
    3,436
    Sorry, it defaulted to the home page but once you get there type in metal identification and look around in there good info on that site.
  19. #16
    canada
    38
    31
    The ISRI guide should be a mandatory read for all scrappers and wannabe's
  20. The Following User Says Thank You to scrapper321 for This Post:
    1. question on whats good and whats not.
      By mmasini in forum Scrap Metal Tips and Advice
      Last Post: 03-24-2014, 02:27 AM
    2. Hard Drive Breakdown Numbers
      By Geiser093 in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 02-04-2013, 02:10 AM
    3. the 41 mile difference
      By travistemple202020 in forum Scrap Metal Prices
      Last Post: 10-02-2012, 09:55 AM
    4. 64" TV Break Down: Here are the numbers
      By mrsamsonite in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 06-10-2012, 08:19 AM
    5. how to tell the difference?
      By weaverman17 in forum Scrap Metal Identification
      Last Post: 10-17-2010, 02:00 PM
