Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Grading Electronic Boards and Parts
    Mechanic688 started this thread.
    I thought it would be a good time to start adding some pic's of electronic circuit boards and how one buyer has them graded. Different buyers may have different grading processes. This is only for reference purposes so someone knows what we're talking about.
    These are called large socket motherboards. This is 486 board. The socket is usually 2 1/8 and larger.
    This one is a large socket 370 board.
    This one is a slot processor or Pentium 1 board. Still a large socket class.
    This is an example of a small socket green board. This one is a 478 board. The CPU socket is 2 1/8" and smaller.
    This is an example of the Chinese motherboards, usually small socket;
    Socket 478 Chinese, small socket.
    Socket 939 Chinese, small socket.
    submarinepainter's Avatar
    1,025
    1,230
    Mech do you turn them in this way , I thought one would have to strip the metal parts off?
    Quote Originally Posted by submarinepainter View Post
    If your buyer does not require it, why? You get paid for the weight.
    Now we'll start with the cards and smaller parts
    These are gold finger cards. They plug into the motherboard, and have a gold edge or "fingers" along one side.
    These are classed as peripheral boards, this one is a CD Rom board;
    This is an example of a printer board, still peripheral.
    this is an example of cable co. boards, still peripheral.
    This is a large socket Server board.
    This is a small socket Server board.
    This is an example of a Telecom grade of board, they will be different sizes and grades.
    This is an example of a Rambus Ram stick. This is memory.
    This is an example of a Hard Drive board. They may be different length's.
    And this is an example of a low-grade board out of Tv's, stereo's, vcr's and other brown boards.
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    What are they all classified as? Mobo, or lower?
    Quote Originally Posted by GeorgeB View Post
    George, They all have different classifications
    And then above each picture is what that particular buyer lists them as. Save up a decent load and drive to your favorite buyer then watch them go thru the grading process, everything becomes crystal clear.
    here is his listing without prices as he is not a member here. Each buyer has a little different grading process, I just used this one cause it had pic's to match, made the posting easier.
    "Sorted Boards
    Large Socket Motherboard (no batteries)
    Small Socket GREEN Motherboard (no batteries)
    Small Socket CHINESE Motherboard (no batteries)
    Mixed Socket Motherboard Green and Chinese (no batteries)
    Gold Fingered Cards
    Trimmed Finger Cards
    Peripheral Board (no batteries)
    Dual Socket Server Board Large Socket(no batteries)
    Dual Socket Server Board Small Socket(no batteries)
    Telecom High Grade (no batteries)
    Back Plane Expansion Board
    Mid Grade Green Board
    Low Grade Brown Board
    Gold Tip Connector Ends
    Gold/Silver/Tin Fingered Memory RAM
    Fingerless (trimmed) Memory RAM
    RAMBUS (metal cover) RAM
    Slot Processors
    Fingerless (trimmed) Slot Processors
    Hard Drive Logic Boards
    IC Chips
    Clean Gold Fingers"
  7. The Following 5 Users say Thank You for This Post by Mechanic688:
    USA
    436
    104
    Hello Mechanic,
    Thanks for the thread. Do you have any idea what classification this board is and about how much it is worth?
    http://i38.photobucket.com/albums/e1...617_150200.jpg
    thanks
    Quote Originally Posted by mrsamsonite View Post
    Hello Mechanic,
    thanks
    I was trying to gauge the size of the board, doesn't look too big. I think a buyer would class it as mid grade motherboard or peripheral. Might depend on how many pounds of them you have.
    USA
    436
    104
    Id say its about 8 in long so, yes it is fairly small in size. I wasnt sure if that was gold on the surface of the board. If that was the case I thought it might be worth $$$. Ive been dealing in small quantities for now.
    USA
    436
    104
    About how much do cable co. boards and other peripheral boards go for per pound?
    I think they go for around $ 2.50-2.75 lb. Everyone seems to classify or call them something different.
  13. The Following User Says Thank You to Mechanic688 for This Post:
    USA
    436
    104
    Cool thanks, Im finishing packing my box.
    Quote Originally Posted by chevwizard View Post
    need help fast, I scored a large load of servers and network hubs, how doing grade these very large boards? I also got about 75 wireless internet routers with this load, does anyone know the grade of those boards? I would classify them as high grade, but I'm not sure.....,.????
    You need to find out from your buyer what class of boards you have for sure.
  16. The Following 3 Users say Thank You for This Post by Mechanic688:
    ReciclajeDeOccidente's Avatar
    Mexico
    24
    Hi, whats is the price of this low grade board? I buying 20.000 lbs per month
  19. #16
    1,209
    I agree let the buyer purchase the boards as is, big difference if your shipping to Sipi for toll refining and end up paying for trash.
  20. The Following 2 Users say Thank You for This Post by gustavus:
  21. #17
    URBANERECYCLING's Avatar
    Tampa
    160
    131
    See Dave i have many talents. I speak spanish redneck and New Jersey
    What?????LOL
  22. #18
    sdwyz74's Avatar
    Seattle,Washington
    29
    do you know where i could sell My Cellphone Motherboards as i have hundreds and the guy i used to sell to has Just Disappeared ??? PLEASE ADVISED!
  23. #19
    badkarma506's Avatar
    Mar 2013
    oregon
    159
    31
    calbag in vancouver?
  24. #20
    sdwyz74's Avatar
    Seattle,Washington
    29
    Quote Originally Posted by badkarma506 View Post
    Thanks very much ill look into it and post there per pound price and shipping policys
    1. Help Grading these boards...
      By ScrappinRed in forum E-Waste Grading and Identification
      Last Post: 05-21-2014, 12:27 AM
    2. Need help grading these telephone boards
      By HyderConsulting in forum E-Waste Grading and Identification
      Last Post: 08-02-2012, 04:59 PM
    3. Need some help grading some boards
      By spoiler73 in forum A Day in the Life of a Scrapper
      Last Post: 06-19-2012, 05:55 PM
    4. Need some help grading these boards.
      By node1tech in forum E-Waste Grading and Identification
      Last Post: 05-31-2012, 04:48 PM
    5. There is so much guess work in grading boards for beginners like me
      By Jeremiah in forum E-Waste Grading and Identification
      Last Post: 01-29-2012, 05:57 AM
