Results 1 to 17 of 17
best sasall blade ? your thoughts
| Scrap Metal Tips and Advice
    EcoSafe started this thread.
    back in my car scrapping days i tried probably a dozen different brands several of them were "name " brands always went back to Milwalkie hands down. your thought. I had one of the few Dewalt 35 volt cordless sawsalls made till some one stole it out of my truck. it was so powerfull it was a wrist buster so they pulled it off the market pretty quickly.
    I don't use sawzall blades much. I have a knack for bending them. I prefer a 4 1/2 angle grinder with a thin cutoff. Slices through just about anything I ask of it.
  3. The Following User Says Thank You to IdahoScrapper for This Post:
    The Diablo blade is the best hands down! It lasts longer then others and best part is when cutting motor windings it cuts with out snagging the wires making it much easier to pull the wire out from the other side!
  5. The Following 3 Users say Thank You for This Post by injunjoe:
    11
    Best Blades
    I went and purchased a set of fire & rescue blades. They seem to do the job. There double toothed. Cut thick steel and pretty much a car if you want. They are thick blades that dont bend that easy and last a longer time. I reviewed blades before i went with them. I think the ones i went with were milwaukee blades
    Saroro's Avatar
    242
    72
    We have a line of tools at work called the "Spyder Scraper". It's a scraper you get for your sawzall. I just saw today that the same company came out with double sided sawzall blades! (Can't believe I didn't think of that and make millions first...) They have teeth on both sides of the blade. Not sure of the companies quality, but the idea is fantastic.
    Faith x Needs = Motivation
    where did you buy those blades Scrappy?
    dherik's Avatar
    Des Moines, IA
    305
    60
    those spyder tool's are freaking genius!
    11
    They were Lenox Fire Rescue. This is the guy i bought mine through. Dirt Cheap Prices
    Quote Originally Posted by Dumpster Dee View Post
    HERE IS WHERE I BOUGHT MINE: CHEAP!!
    http://cgi.ebay.com/120682419957?ru=...fvi%3D1&_rdc=1
    CMHN's Avatar
    Berwick, Pa
    380
    49
    I use DEWALTs DEWALT DW4865 9-Inch 10TPI Demolition Bi-Metal Reciprocating. They are made for Fire and Rescue and my local Hardware store sells them. I cut a full size school bus apart with only 5 of these blades. that was cutting it down to fit in my 6'X10' trailer. It was a lot of cutting and these blades proved themselves to me. I buy them 10 at a time now and always have them on hand.
  12. The Following User Says Thank You to CMHN for This Post:
    rca987's Avatar
    938
    I use "The Torch".
    218
    130
    The torch is hard to beat!When buying a blade keep in mind the material to be cut and speed of the blade recipicating
    4,977
    1,257
    Quote Originally Posted by saroro View Post
    we have a line of tools at work called the "spyder scraper". It's a scraper you get for your sawzall. I just saw today that the same company came out with double sided sawzall blades! (can't believe i didn't think of that and make millions first...) they have teeth on both sides of the blade. Not sure of the companies quality, but the idea is fantastic.
    junk!
    On, Can
    101
    56
    Quote Originally Posted by rca987 View Post
    I use "The Torch".
    AKA "The Gas Adjustable Wrench"?
    Jonniebrass's Avatar
    Massachusetts
    1,007
    582
    I used lenox thick metal. I cut 1/4 plate. It was a boiler and cut it down the middle to get out of basement. Did not last too long though but cut good. Lasted longer when I kept dripping oil in cut. Other ones I tried sucked.
    wavecrazed's Avatar
    219
    I found a link to a company selling like 100 blades for 70 It is in the auto recycling rag
  19. #16
    2,864
    350
    I agree with Idaho, 4 1/2" angle grinder with a thin cutoff blade. When cutting copper off a stater with a sawsall you waste too much copper, the cutoff blade is thin and gives a smoother cut, also use it for checking diffrant metals like copper, ss, brass. I don't normaly cut thick metals sence I mostly do electronics.
  20. #17
    mocanaqua , pa
    18
    I'm a fan of Diablo. They cut well and last along time. I always had a problem bending any type of blade until I leaned to take my time and let the saw cut. And its important to keep the guard up against what your cutting.
    1. Stripping is all in the blade
      By tigerbeetle in forum A Day in the Life of a Scrapper
      Last Post: 03-10-2016, 05:44 AM
    2. dual blade circular saw
      By Copper Head in forum Tools and Equipment
      Last Post: 12-22-2011, 08:31 PM
    3. cut off blade results
      By EcoSafe in forum Tools and Equipment
      Last Post: 06-27-2011, 07:41 PM
    4. Commercial paper cutter blade
      By Silence in forum Scrap Metal Questions and Answers
      Last Post: 06-03-2011, 10:06 PM
    5. Good Sawzall blade
      By Randy_B_Scrappin in forum Tools and Equipment
      Last Post: 04-17-2011, 04:27 PM
