Results 1 to 13 of 13
Automotive Air Bag Inflators
    jbrown40004 started this thread.
    USA
    10
    Hello Everyone,
    I am new to the forum and I have done some searching on the topic of my post but I have not found any information on scrapping automotive air bag inflators.
    I have a contract with a local air bag manufacturing facility to manage their scrap inflators.
    The inflators that are rejected from the manufacturing process are deactivated and then collected for recycling. They are all steel. Just for emphasis: They are not live airbag inflators but have been deactivated.
    The bigger scrap yards in my area do not want the material because of the perceived risk of handling a potentially dangerous device and because most of the scrap inflators are cylinders that once held compressed gas.
    The facility will generate a large quantity of this scrap; approximately 40-60 tons per month.
    A local recycler has agreed to accept the inflators. Their plans are to shred them before they are sent on down the line. They intend to pay shred steel price plus some.
    I am looking to maximize the price paid for this material.
    Any ideas on how this scrap could be handled other than the shredding?
    What grade do you think these should be?
    Any ideas or comments would be appreciated.
    I look forward to your responses and I appreciate the opportunity to participate in this forum.
    I'll post some pictures of the material once I'm allowed to by the moderators of the forum.
    BarrenRealms007's Avatar
    Arkansas
    398
    203
    Look on the bags and see if there aren't some gold contact's that you can remove.
  3. The Following User Says Thank You to BarrenRealms007 for This Post:
    Craasher's Avatar
    Alabama
    209
    78
    I dont know if you would get any higher price on the materials since you said its all steel than shred anyway. If you would get a better price from a yard than the recycler you can cut holes in the tanks and eliminate the "compressed air tank" scare but I really dont think you would get anymore than shred anyway. Might be better to just drop off the loads without handling them and collect a check.
    177
    Quote Originally Posted by jbrown40004 View Post
    Wow, someone needs to help them with their quality assurance program!
    Bill
    USA
    10
    I am not all that familiar with the grades of scrap steel but would this size material not fit the definition of a HMS #1? The longest pieces are only about 16".
    USA
    10
    Quote Originally Posted by BarrenRealms007 View Post
    The only part that could potentially have gold would be the terminals for the wiring harness connnection.
    How can I check them to see if they have any gold in them?
    RustyDollars's Avatar
    Central Wis
    426
    438
    Cut one in half and see how thick the walls are. If it's 1/8" or greater than you could get prepped price in my area anyway.
    USA
    10
    Quote Originally Posted by RustyDollars View Post
    Thank you. Please excuse my ignorance. What is the "prepped" grade and how does it compare to shred or HMS?
    USA
    10
    I just answered my own question about the "prepped" grade by doing some research. Thanks
    Central Wis
    426
    438
    They called it prepared steel up here but it probably should be call HMS 2.
    ISRI 203 (HMS 2): Wrought iron and/or steel scrap, black and galvanized, 1⁄8 inch and larger in thickness.
    Definetly worth more than shred.
  12. The Following User Says Thank You to RustyDollars for This Post:
    5,728
    6,814
    Sounds like they're similar to small fire extinguisher cylinders, and some people cut those in half all day long. I use a metal cutting blade on a 10" miter saw for lots of cuts. What type metal, are they magnetic?
  14. The Following User Says Thank You to Bear for This Post:
    USA
    10
    They are various sizes; all steel. I will get some pics up soon. That will help.
    They are mostly cylinder shaped, definitely at least 1/8" wall thickness, 0.5" to 1.5" diameter, 4" to 16" in length.
    The company that had the contract before me sold some of the material directly to a brake drum manufacturer which had its own furnace onsite. Does anybody have any experience with selling directly to the end-user like that?
    Thank you all for your thoughts.
    Arkansas
    398
    203
    If you can remove some of the pieces inside the connector and send me a picture I can look at it and prbably give you an answer.
    1. selling parts is a mixed bag
      By travistemple202020 in forum A Day in the Life of a Scrapper
      Last Post: 11-14-2012, 03:02 PM
    2. Looking for mulch bag for an electric mower
      By ilyaz in forum More than Scrap Value
      Last Post: 01-10-2012, 11:27 PM
    3. Left holding the bag
      Last Post: 01-10-2012, 12:43 AM
    4. picked up my $10 bag of goodies from CL today
      By EcoSafe in forum Scrap Metal Spots
      Last Post: 12-27-2011, 07:05 PM
    5. Automotive Recycling
      By Kris Kringle in forum Automotive Recycling
      Last Post: 12-21-2010, 08:22 AM
