Results 1 to 20 of 22
Breaking stuff down, is it worth it?
    mrsamsonite started this thread.
    USA
    436
    104
    Hello,
    I recently bought a scale on amazon to help me find out if it is worth it to break stuff down. I recommend everyone to have a scale because it helps you to know how much you will be making and if it is worth it to break stuff down. Here is the link where I bought my scale 600lb limit scale for $80:
    Amazon.com: 600 LB Pounds Platform Bench Shipping Weight Computing Counting Scales: Office Products
    This scale helped me to find out if it is worth it or not to break stuff down. When you break stuff down you have to make sure that you are subtracting what you would get if you didnt break down from what you will get for breaking down. Then you will be able to know how much more profit you will be making (or loosing) by breaking down. For example:
    A T.V
    without breakdown: @.05/lb. (e-waste) 65lbs = $3.25
    with breakdown: (copper, alu, brown board, wire)= $7.25
    What you made from breaking down (7.25-3.25)= $4.00 ( took 15-20min)
    I found that smaller tv's are worth it but, a lot of the bigger T.V's have aluminum wire instead of copper wire and you can actually loose money if you break it down. Here is what I found:
    no break down: @.05 (e-waste) 110lbs= $5.50
    with break down: (copper yoke, alu wire, e-waste,etc)= $3.30
    What you make from breaking down $3.30-$5.50= -$2.20
    So with this bigger tv. I actually lost $2.20 because I broke it down opposed to just recycling as e-waste.
    A general rule is if there is lots of weight from discard (trash) after breaking stuff down you might want to think about recycling the item as is (without break down) because you will get the extra weight. Keep in mind that you can actually loose money when breaking down opposed to recycling as is. So, I recommend buying a scale.
    Another very important thing for scappers if you are just starting out is that you have to:
    1. Know ALL of the different classifications of all of the metals (contaminated, painted, thickness, everthing)
    2. Know what the prices are to every classification.
    If you dont know these two things you will have a hard time determining whether it is worth it to break something down or not. You will not know what is "up for grab" when you are breaking down. This goes for picking up too, if you dont know what something is worth then you wont know if it is worth it to pick it up.
    I apologize if there is already a post on this matter but, I felt it was important to share this, especially the usefulness of a scale and knowing the classifications and prices. This stuff is probably more for beginners in the forum. I am also a beginner (about 6 month full time) and always learning new stuff all the time. So I hope that this helps some of you out there
    thanks
  2. The Following 9 Users say Thank You for This Post by mrsamsonite:
    Dunemaul's Avatar
    East Orlando FL
    1,064
    157
    the fact you can sell whole tvs just means you win.
    Born to think, destine to succeed.
    BurlyGuys's Avatar
    Waterford Michigan
    1,591
    1,109
    Yeah, I want that deal...
    John Terrell (248) 224-2188
    Burly Guys Junk Removal LLC
    http://www.burlyguys.com
    USA
    436
    104
    So you guys cant sell whole tvs? Here in California we can sell tvs @ $.05/lb. but, it can get a little complicated. TVs are highly regulated and each house hold (address) can only drop off four tvs. If you drop off more than 4 the state will call you and confirm that the tvs came from your address. So, what a lot of scrappers do is they collect the address where they picked up the tv and give it to the scrap yard and they log that address in. Only some scrap yards (the more ghetto ones) allow you to do this but, other yard require an ID and they use the address on that ID.
    As far as disposing of TV's that are already broken down: the dump take two per day with/out any fee.
    How do things work in your state?
  6. The Following User Says Thank You to mrsamsonite for This Post:
    In Maine, the dump charges $5 each for a TV or computer monitor. I tear them apart for electronic components and haul the glass to Goodwill under their recycling agreement with Dell/Reconnect.
  8. The Following User Says Thank You to Mick for This Post:
    USA
    436
    104
    At goodwill do they take your name down or is there a limit on how many you can turn in?
    USA
    436
    104
    I believe california funds the tv recycling program so that is why we can recycle them and also dump two off per day at the dump.
    2,864
    350
    I would be happy to get .02lbs for tv's in my area. 5.00 charge per tv at the dump and if it is a big tv the charge gos up to 10.00. same charges for the tubes.
    Quote Originally Posted by mrsamsonite View Post
    No and no.
    May 2012
    Metro-West , Mass.
    93
    54
    In My area of Mass. Everyone ( Towns and Private yards that will take them ) charges a Min. of $ 25.00 for a TV , with larger TV's a Lot More and don't even ask about the big old wood console units $$$$ . I have been reading up everything I can find here on TV's as there are 6 on the curb within a 1/2 mi. of the house , but the high disposal cost it is a turn off .
    Bandit
    5,728
    6,814
    haha, funny how this turned into a TV commercial ; ) The last big old "wood" (not real wood, wish it had been, was the only reason I chose to go so far to get it, it was only a particle board imitation of wood) TV I got turned into a nice workbench out behind the barn. Once it's deteriorated enough to be totally useless, it'll get tossed in a brushpile somewhere to be burned with the brush
    May 2012
    Metro-West , Mass.
    93
    54
    WOW , Your able to burn brush !
    Doesn't most of the Fall-A-Partical Board Furniture start to Deteriorate as soon as it is put outside , ( or leaves the showroom floor ) ?
    When we find it in a storage locker it just gets broken down and trashed , don't even bother trying to give it away .
    5,728
    6,814
    This was a 91 model, looks like the rain washes them away a little slower, it was extremely thick too, over an inch in places, and heavy, very heavy. Even just the tube from that thing is more than I care to lift, keep putting off hauling it to Goodwill. It got away from me and I dropped it two or three times getting it out the door, down some steps, across a gravel driveway, and up into the trailer. Must have made the woman who gave it to me feel real good ; )
    USA
    436
    104
    Thanks a lot mick for the advice. I went to Goodwill today and turned in some scrapped monitors with now problems. This is a great resource for me thanks a lot!
    Green Bay, WI
    377
    38
    Goodwill by me still won't take them
  19. #16
    USA
    436
    104
    Im going today to drop off most of the rest of my inventory. this is awesome.
  20. #17
    May 2012
    Metro-West , Mass.
    93
    54
    Goodwill here in Mass. appears to only take working TV's and Computer's & Monitors along with a few other charities and they all say they Only want newer one's and will test them before taking them in.
    The scrap yards and town's around here start at a $ 25 fee and go up ( Way Up ). Found one place that will take them from the public for a fee of $ 2.50 a pound .
    There are a few National Recycling companies in the area , but it looks like they only want to deal with large commercial accounts for Secure Disposal for $$$$
    Anyone ever deal with any of these companies ? They have Local Warehouses here in Mass.
    Electronic Recyclers International
    E-waste and Electronic Recycling Centers | Recycle Corporate, Consumer and Government Electronics
    Computer Recycling USA
    Advanced Electronics Recycling Inc.
    Bandit
  21. #18
    May 2012
    Metro-West , Mass.
    93
    54
    I have been Googling all afternoon , found a link on here to the Dell recycling web sites and the closest one to me , living west of Boston is in Southern New Hampshire , Goodwill of Northern New England , and they even give you directions on how to " Safely "box and label broken monitors .
    It looks like this will solve the Computer Monitor Disposal Problem , Now I just have to find one for TV CRT tubes .
    Computer Equipment Recycling with Reconnect
    Goodwill Industries of NNE
    Bandit
    Ps
    Hi Mick
    Does Northern NE Goodwill take CRT Tubes too ?
    Pps
    The Magic I got from You at Cole Farms , worked Like a Dream , LOL
  22. The Following User Says Thank You to Bandit for This Post:
  23. #19
    USA
    436
    104
    For the tv's I just take all of the copper and everything out of the crt TV/monitor then put the back cover back on the so that it looks like a normal tv. I think goodwill will take the tubes also but, if you put the back cover back on they are easier to handle and stack.
  24. #20
    Hi, Bandit. I was wondering... That was a few years ago.
    I've pretty much quit making Magic except for my own use. (For others, Magic Salt is used to treat snow and ice.)
    Be sure to check with the Goodwill store nearest you. The one by me isn't listed but they take CRTs. Had a couple tv tubes that they took, too. Not sure if they were actually supposed to, though. BUT, the game changes if you tell them you're a business.
    1. Breaking down cell phones...Is it worth it? (PICS)
      By MOscrapper in forum General Electronics Recycling
      Last Post: 12-24-2012, 06:15 PM
    2. Is this lot of computer stuff worth it
      By digbmx4130 in forum General Electronics Recycling
      Last Post: 07-02-2012, 10:00 PM
    3. E- stuff
      Last Post: 12-08-2011, 06:57 AM
    4. Stuff just happens
      Last Post: 09-06-2011, 04:42 PM
    5. Worth breaking down.
      By mhlyons in forum Scrap Metal Questions and Answers
      Last Post: 08-12-2011, 09:59 AM
