Results 1 to 11 of 11
Log splitter input needed
| Tools and Equipment
    BurlyGuys started this thread.
    BurlyGuys's Avatar
    Waterford Michigan
    1,591
    1,109
    I am considering getting a log splitter for breaking down motors. What size is sufficient? I am finding little 6-7 ton electrics, and I am finding 22 ton gas units. Is a 6 ton unit big enough to break down electric motors?
    Any input would be appreciated!
    John Terrell (248) 224-2188
    Burly Guys Junk Removal LLC
    http://www.burlyguys.com
    ks
    2,187
    2,513
    Don't know bout splitting motors but them 6 ton spliter are bout helpless for splitting logs. More tons on the log splitter the better. Let me know how well that works
    boise, ID
    1,605
    469
    How big of motors are you going to do with it?
    61
    19
    I've seen them used for taking tires off from aluminum wheels, but not for motors.
    I'd recommend you getting a professional grade splitter. Specifically, I prefer Timberwolf. I just don't think an electric will have enough oomph for what you want. I always considered electrics for little, kindling-sized stuff. Go with a two-stage gas Honda for reliability - minimum of 5.5 hp. Horsepower is important, but even more than that is PSI of the hydraulics. Get as much as you can afford - better too much than too little. Hint - "ton" is a selling point and doesn't really mean much.
  6. The Following User Says Thank You to Mick for This Post:
    Eastern Ontario
    294
    139
    Same advice here. I tried out one of those little electric ones once, couldn't split anything but the stuff that was perfect.
    The better pro models have the ability to swap out the splitting heads. Might be handy if you decide to experiment with different head geometries for splitting, breaking, crushing etc.
    Keep us informed, I was thinking of doing the same thing, but I'm happy to let you do the experimenting.
    RustyDollars's Avatar
    Central Wis
    426
    438
    As others have stated, stay away from the small electric ones. I have a 27 ton and wouldn't want anything less. My advise: Get as big of one as you can afford and one that operates horizontally and vertically. You will quickly appreciate not having to lift heavy objects up onto the deck. Another nice feature to consider is an automatic cylinder return.
    218
    130
    I pull wire only with mine and have a 9 horse Honda and 13 gallon a min. Pump.When I pull the wire out I am pretty close to a idle.Very minimal hydro.power being used.I also split wood with it and thats where more power is used.So will the splitter use be diversified?
    BurlyGuys's Avatar
    Waterford Michigan
    1,591
    1,109
    Will it be diversified? Probably. Anything that puts good power into pressing on something has GOT to have multiple uses.
    I just wanna break stuff!
    Thanks for all the great input guys. You've given me a lot to consider!
    2,864
    350
    Can you use a log splitter to make a bailer, to bail plastics or al. cans.
    Certainly. I saw a modified splitter somewhere awhile back. Had a box built around it out of plate to contain the cans, then 2 end plates to compress it. Prolly make more sense if I can find it again. Might be later tonight.
    1. Found a broken truck, input needed. Ford Ranger
      By andrew1990 in forum Tools and Equipment
      Last Post: 12-11-2012, 10:09 AM
    2. input need asap
      By mongo in forum General Electronics Recycling
      Last Post: 09-26-2012, 08:00 PM
    3. New Website - Input Please
      By erg in forum General - Let's talk business
      Last Post: 07-19-2012, 03:31 AM
    4. CRT Log Document
      By takenbyvultures in forum TV and Monitor Recycling
      Last Post: 11-29-2011, 10:53 AM
    5. Like some input on processing
      By High Voltage Processing in forum General - Let's talk business
      Last Post: 11-08-2011, 10:54 AM
